Xbox 360 Console: Green to Red Light Transition - Causes & Solutions for LED Issue
pacak24 78060 15
Why does my Xbox 360 turn from green to red after a few seconds, and how can I fix it?
Your Xbox 360 is showing a hardware fault rather than a normal LED problem; in this thread it was identified as a GPU/XCGPU-related issue on a Slim console [#15889302] The suggested repair is reflow or, preferably, reballing the XCGPU/GPU chip, usually done by a service shop, with one estimate given at about 100–200 [#15889302] Another reply recommends a full service: clean the console, replace the thermal paste, and be very careful when removing and refitting the heatsink [#15889461] Some users also mention heating the board from below and with hot air from above as a temporary attempt, but the fault may return after some time [#15889461][#15889302] If the console is an older Xenon/Zephyr model without HDMI, one reply says the repair may not be worth it and selling it for parts can be the practical option [#15891417]
  • #1 15883306
    pacak24
    Rate: 52
    Hello, I have such a problem with my console because after turning on, the green LED lights up for a moment, after about 5 seconds, the red LED also lights up. And I don't know what's going on, how to fix it, what's the cause. Please help
  • #3 15888944
    pacak24
    Rate: 52
    I checked it is error 011, i.e. CPU overheating and now what should I do, how to fix it and what is the cost of such repair.
  • #4 15889302
    Spox_2
    Help: 25
    Rate: 84
    The specified error code is invalid. The code always consists of 4 digits.
    I suppose the error code is 0110. And the console is the Slim version.
    In this case, the XCGPU chip (the heart of the XBOX360 Slim console) is damaged.
    The options are 2 -> doing reflow, possibly CPU reballing. Costs 100-200 depending on who will do it, what etc.
    The problem is that these consoles still publish after some time. It breaks down to six months and the fault returns.
  • #5 15889461
    ghrki
    Help: 22
    Rate: 11
    Sometimes it helps to fluctuate the system, heating on the heater from the bottom and hotair from the top. And of course, replacing the paste. just be very careful when removing and fastening the heat sink.
    You can find the temperature settings on the net, as for rebalancing, it is a better method, but not every service has screens for such systems.
  • #6 15889480
    pacak24
    Rate: 52
    this is error 0011
    Xbox 360 Console: Green to Red Light Transition - Causes & Solutions for LED Issue Xbox 360 Console: Green to Red Light Transition - Causes & Solutions for LED Issue
    Added after 6 [minutes]:
    sorry error, I watched the video on YouTube, I misread the error and now I read it correctly
    error 0102 - Cold February under the GPU
    what to do how to fix it
  • #7 15891090
    pacak24
    Rate: 52
  • #9 15891172
    pacak24
    Rate: 52
    and you can't fix it yourself
  • #10 15891417
    Sirius27
    Level 19  
    Help: 28
    Rate: 47
    You can't be alone when you don't have a lot of knowledge and equipment.
    What's more, your xbox360 is old crap without HDMI, it seems that on the xenon or zephyr disc, which is completely unprofitable to repair, even in the service.
    Sell for parts.
  • Request for Xbox 360 E error-code diagnostics and PC testing options
    #11 15936347
    Aleq
    Rate: 19
    I have the same green diode and a transition to the red diode.
    Xbox 360 E Console model (1538)
    console connected to TV via HDMI cable, (also the same on AV cable)
    or by some home way, can I check what the kaman is about before I send it to the site? how are these error codes checked?
    Is there any option to connect the console to a PC to use some software to practice this console?
    Thanks for the tips, as you can see, the questions are completely green ... :P
  • HDMI connection triggers red LED fault on Xbox 360 E
    #12 20093650
    Spartan33
    Help: 41
    Rate: 97
    Xbox 360 E, the same, after starting the console, it worked for some time, then after connecting the hdmi cable, the red LED after a while, now even the image does not want to jump, it will not have time because the red LED. When I press sync + eject, the green ring flashes 4 times. In the console and in the power supply, the fan works and after about 5 seconds it will end, the red LED on the console, and the orange on the power supply.
  • #13 20098531
    Szymon640x480
    Help: 8
    Rate: 60
    @ Spartan33 please provide the full error code
  • #14 20100369
    Spartan33
    Help: 41
    Rate: 97
    0033
  • #16 21753106
    at529782pl
    Leave for 30 mins with the red ring and switch on again, it has worked for me for 7 years.
The discussion concerns an Xbox 360 console that briefly shows a green power light and then switches to a red light after a few seconds. The issue is identified as an Xbox 360 error condition, initially suspected as overheating, then corrected to error 0102 / 0033 depending on the console. Responses point to GPU/XCGPU damage, cold solder joints under the GPU, or general hardware failure on older Xbox 360 revisions. Suggested remedies include checking the official flashing-lights error guide, servicing the console, replacing thermal paste, performing reflow or CPU/GPU reballing, and in some cases considering the repair uneconomical and selling the unit for parts. Later replies mention similar symptoms on an Xbox 360 E model with HDMI/AV output, fan activity, orange PSU LED, and the need to provide the full error code.
