Xbox 360 Won't Start After HANA Reflow, No Image on HDMI, Voltage & Beep Details Included
pietrucha18 4326 3
  • #1 16749454
    pietrucha18
    Help: 8
    Rate: 72
    Xbox after reflow HANA (temperature max. 180 degrees C). The console does not start, no voltage on the USB voltage
    L6A1 = 5.1V
    L5A1 = 3.3V
    L5B2 = 1.8V
    After pressing the switch, you only hear a beep (signal to switch on or open the drive tray).
    Primary malfunction no image on HDMI (monitor and AV is present).
  • #2 16749565
    robin11
    Help: 57
    Rate: 160
    Hello.Probably to replace the hana chip. The fault, no picture via hdmi already indicated it. You can change the current system to be sure, 80% to change.
    best regards
  • #3 16749853
    pietrucha18
    Help: 8
    Rate: 72
    On the monitor via HDMI, it works on AV, you can also play,
    so if you manage to do without peeling, it will stay completely broken.
    I just have no idea why there is no voltage on the USB.
  • #4 16749939
    robin11
    Help: 57
    Rate: 160
    5v on usb comes out of this system, check for a short circuit. I don't know what console, but the same is bad. best regards
    If there is a short circuit, see the pins in the usb as well as the ceramic capacitors at the usb ports.
