Lenovo Y50-70 Laptop: svchost.exe Process at 100% Disk, 30% CPU Usage - i5-4210H, GTX 860M, Win 8.1
Michimi 25419 5
  • Identifying the svchost service causing high disk usage
    #1 15972524
    Michimi
    Hello, I have such a problem with the Lenovo y50-70 laptop with the i5-4210H processor version, the gtx 860M graphics card and windows 8.1.
    Well, the Host of the local system service, the so-called svchost.exe process, takes 100% of disk resources and 30% of CPU resources
    Here screen what services are connected to this process
    http://wrzuacz.pl/file/2991475596516/d.png
    Which service do you need to disable? Could someone direct me?
  • #2 15972553
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    As always, Windows Update.
    But first check that no updates are being installed and that WU works at all.
  • #3 15972588
    Michimi
    After installing all but the optional updates, there is now a problem with another service that includes Itworeker.exe, but sometimes it disappears and it's okay.
    If you know, please let me know what itworker is responsible for in svchoptak for the future
    Added after 58 [seconds]:
    also antimalwere sevice executable can take 100% of disk
  • #4 15972625
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Itworeker.exe is related to the updates, are you sure they are all installed? You can also install some optional.
    After all are installed, you can turn off Windows Update and turn on only occasionally to check for updates.
    With antimalware, this is normal when scanning the disk / files.
  • Restart Windows Update to stop svchost high CPU usage
    #6 15973406
    bercik_gsi
    Help: 5
    Rate: 60
    I see native Win8 / 8.1 services here, which you probably won't disable without consequences. I already had a case (maybe two) with a new machine and a pre-installed system nomen omen Win8. The computer was updating all working day and I had to stay after hours. Until WindowsUpdate let go of the svchost 90-100% CPU, the fan did a bit of a job. After exhausting all updates, svchost should stop, maybe downtime optional.
    Try restarting Windows Update service, or try turning it off and doing so reboot .
