High CPU, Memory Usage and 100% Disk Usage on Windows 10, Intel Core i7-5500U, 8GB RAM
Wyrson 6510 16
Why does my Windows 10 laptop with an Intel Core i7-5500U, 8GB RAM and a 1 TB HDD have high CPU, memory and 100% disk usage, and how can I fix it?
Try uninstalling Avast first; in the thread, disk usage dropped from 100% to about 15% after Avast was removed [#16590985][#16590997] Kolobos also noted that the slowdown may have been caused by Windows updates running or getting stuck, so if it happens right after boot you should wait a bit and check whether the updates finish normally [#16590331][#16590502] He asked for FRST logs and proposed cleanup of startup/task entries such as WinZip System Utilities Suite, plus other logged items like BingSvc, True Key and browser homepage/search hijackers [#16590502] The disk SMART was also reported as having many shocks/overloads, so checking drive health with CrystalDiskInfo was suggested [#16590347][#16590459] If Avast turns out to be the cause, reinstall it to test again; if the slowdown returns, switch to AVG instead [#16591073]
  • #1 16590312
    Wyrson
    Hello, I have a huge problem with my laptop. :( He began to lull, slow to act. CPU and memory usage is still high, and disk usage is 100%.
    I have Windows 10
    Intel Core i7-5500U processor
    8GB RAM
    1 TB disk
    Geforce gtx 950m graphics card
    I am a layman when it comes to computers.
    Please help. Thank you in advance.
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    You have to guess what processes are burdensome, can you name them?
  • #3 16590321
    Wyrson
    I'm sending a screen
    • High CPU, Memory Usage and 100% Disk Usage on Windows 10, Intel Core i7-5500U, 8GB RAM Bez tytułu.png (98.07 KB) You must be logged in to download this attachment.
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    It looks like some updates are being installed.
  • #5 16590332
    Wyrson
    By installing updates can your computer be so silent?
    enhanced
    Help: 964
    Rate: 884
    Well, of course with HDD, yes.
    Insert screen from process explorer - from whole.
    safbot1st
    Help: 2719
    Rate: 1585
    Not all the time. ~ 20 minutes have passed since the topic was set up. This should end now. After reset` further "mus"?
    Windows have various ills of this type - stuck services, toxic patches, infections.
    Provide the SMART disk from CrystalDiskInfo.
    Have you recently connected any external USB devices?
  • #8 16590357
    Wyrson
    No, it's over. However, memory usage is still around 50%.
    No, I didn't connect anything.
    Added:
    Screen from Process Explorer.
    Added:
    Cristaldiskinfo:
    High CPU, Memory Usage and 100% Disk Usage on Windows 10, Intel Core i7-5500U, 8GB RAMBez tyt...png (224.72 kB)You must be logged in to download this attachment.
    Moderated By swiercm:
    I merged posts. Please, use the "Change" option when updating information.
    enhanced
    Help: 964
    Rate: 884
    Enter from the whole - you cannot see the slider in the explorer process window?
  • #11 16590449
    Wyrson
    Here you are
    • FRST.txt (63.93 KB) You must be logged in to download this attachment.
    • Addition.txt (56.59 KB) You must be logged in to download this attachment.
    • High CPU, Memory Usage and 100% Disk Usage on Windows 10, Intel Core i7-5500U, 8GB RAM Bez tytułu2.png (197.44 KB) You must be logged in to download this attachment.
    • High CPU, Memory Usage and 100% Disk Usage on Windows 10, Intel Core i7-5500U, 8GB RAM Bez tytułu.png (161.83 KB) You must be logged in to download this attachment.
    safbot1st
    Help: 2719
    Rate: 1585
    As for screen # 2 from post # 6 - the disk survived a large number of shocks / overloads (BF).
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Check if the updates work, maybe something has crashed.
    Do not download programs using download assistants that install malicious add-ons!
    Download only from direct links.
    Uninstall: WinZip System Utilities Suite
    Use: https://sourceforge.net/projects/adobeflashup...an%20Remover/RemoveMcAfee_silent.exe/download
    Next to frst.exe, create the Fixlist.txt file with the contents:
    Task: {297F3B54-4470-4A33-855A-3A7CC5762211} - \ ATK Package 36D18D69AFC3 -> No file No file No file C: \ Program Files (x86) \ Opera \ launcher.exe [2017-07-11] (Opera Software)
    Task: {5F151704-A18E-4B98-B2B8-AC2AD613451A} - \ Update Checker -> No file C: \ Program Files \ WinZip System Utilities Suite \ WinZip System Utilities Suite.exe [2017-03-29] (WinZip)
    Task: {6EBAFACE-9C54-44E6-9F85-F5F8F388FB01} - \ klcp_update -> No file No file No file No file C: \ Program Files \ WinZip System Utilities Suite \ WinZip System Utilities Suite.exe [2017-03-29] (WinZip)
    Task: {917D779D-9414-4ECE-931F-0484312B5963} - \ ASUS Smart Gesture Launcher -> No file No file No file C: \ Program Files \ WinZip System Utilities Suite \ WinZip System Utilities Suite. exe [2017-03-29] (WinZip)
    Task: {BBFB719F-BEB2-4E8D-B250-417AFF541FCE} - \ RtHDVBg_ListenToDevice -> No file No file No file No file C: \ Program Files \ WinZip System Utilities Suite \ WinZip System Utilities Suite.exe [2017-03-29] (WinZip)
    Task: C: \ WINDOWS \ Tasks \ Start WinZip System Utilities Suite for DESKTOP-39ISE2P @ Patryk (logon) .job => C: \ Program Files \ WinZip System Utilities Suite \ WinZip System Utilities Suite.exe
    Task: C: \ WINDOWS \ Tasks \ Start WinZip System Utilities Suite with delay for DESKTOP-39ISE2P(_at_)Patryk.job => C: \ Program Files \ WinZip System Utilities Suite \ WinZip System Utilities Suite.exe
    Hosts:
    (© 2015 Microsoft Corporation) C:\Users\Patryk\AppData\Local\Microsoft\BingSvc\BingSvc.exe
    HKLM\...\Winlogon: [Userinit] C:\WINDOWS\SysWOW64\userinit.exe,
    HKU\S-1-5-21-3250712494-2448862615-1402003128-1001\...\Run: [BingSvc] => C:\Users\Patryk\AppData\Local\Microsoft\BingSvc\BingSvc.exe [144008 2015-11-05] (© 2015 Microsoft Corporation)
    HKU\S-1-5-21-3250712494-2448862615-1402003128-1001\...\Policies\Explorer: []
    HKU\S-1-5-18\...\Run: [] => [X]
    Lsa: [Notification Packages] scecli C:\Program Files\TrueKey\McAfeeTrueKeyPasswordFilter
    GroupPolicy: Ograniczenia C:\Program Files\Intel Security\True Key\MSIE\truekey_ie.dll [2016-10-07] (Intel Security)
    Toolbar: HKLM-x32 - True Key - {4BAAC1B8-0800-42C9-8FA6-08B211F356B8} - C:\Program Files\Intel Security\True Key\MSIE\truekey_ie.dll [2016-10-07] (Intel Security)
    FF DefaultSearchEngine: Mozilla\Firefox\Profiles\wszl5sdq.default-1478991760236 -> Поиск@Mail.Ru
    FF SelectedSearchEngine: Mozilla\Firefox\Profiles\wszl5sdq.default-1478991760236 -> Поиск@Mail.Ru
    FF Homepage: Mozilla\Firefox\Profiles\wszl5sdq.default-1478991760236 -> hxxp://mail.ru/cnt/10445?gp=811013
    FF Extension: (Brak nazwy) - C:\Users\Patryk\AppData\Roaming\Mozilla\Firefox\Profiles\wszl5sdq.default-1478991760236\Extensions\0983-1755-439e-1ce0 [2017-03-06] [Brak podpisu cyfrowego]
    FF Extension: (Brak nazwy) - C:\Users\Patryk\AppData\Roaming\Mozilla\Firefox\Profiles\wszl5sdq.default-1478991760236\Extensions\7426-11e3-d74e-e834 [2017-03-06] [Brak podpisu cyfrowego]
    CHR HomePage: Default -> msn.com/?pc=__PARAM__&ocid=__PARAM__DHP&osmkt=pl-pl
    CHR StartupUrls: Default -> "hxxp://mail.ru/cnt/10445?gp=811009","hxxp://multi.xnxx.com/"
    CHR DefaultSearchURL: Default -> hxxp://go.mail.ru/distib/ep/?q={searchTerms}&product_id=%7B09E62BC3-F42D-449A-AE0F-3F1AC6D074C4%7D&gp=811010
    CHR DefaultSearchKeyword: Default -> go.mail.ru
    CHR DefaultSuggestURL: Default -> hxxp://suggests.go.mail.ru/ff3?q={searchTerms}
    CHR HKU\S-1-5-21-3250712494-2448862615-1402003128-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [fcfenmboojpjinhpgggodefccipikbpd] - hxxps://clients2.google.com/service/update2/crx
    S2 0248301500154559mcinstcleanup; C:\Users\Patryk\AppData\Local\Temp\024830~1.EXE [1027864 2016-11-28] (McAfee, Inc.)
  • #14 16590907
    Wyrson
    Thank you very much for your help ! :)
    Unfortunately, after a restart the disk usage is high: /
    I upload a screenshot from the manager.
    • High CPU, Memory Usage and 100% Disk Usage on Windows 10, Intel Core i7-5500U, 8GB RAM Bez tytułu.png (87.58 KB) You must be logged in to download this attachment.
  • #15 16590985
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Uninstall Avast for now and see if anything changes.
  • #16 16590997
    Wyrson
    The use dropped to max 15%.
    Only if I don't have Avast, what antivirus do you recommend?
  • #17 16591073
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    You can try to install Avast again, if that doesn't help, change it to Avg.
The discussion revolves around a user experiencing high CPU, memory, and 100% disk usage on a Windows 10 laptop equipped with an Intel Core i7-5500U processor, 8GB RAM, and a 1TB HDD. Initial suggestions include identifying resource-intensive processes and checking for ongoing updates. The user shares screenshots from Process Explorer and CrystalDiskInfo, indicating potential disk issues. Recommendations include uninstalling problematic software like WinZip System Utilities Suite and antivirus programs such as Avast, which significantly reduced disk usage. Alternatives for antivirus software are also discussed, with AVG suggested as a potential replacement.
