Disabling UPC Wi-free Broadcast on Thomson TWG870U Modem: Step-by-Step Guide
veder1 11640 14
How can I turn off the UPC Wi-free broadcast on a Thomson TWG870U modem?
UPC Wi-free can be disabled only through the My UPC website (mojeupc) or by contacting UPC by phone; there is no modem-side setting for it [#16012813][#16012852][#16015880] If the TWG870U is used on a different cable provider’s network or you are not a UPC customer, the UPC website will not let you switch it off, so you need to contact the actual provider [#16015666][#16017291] Disabling the service also means you will lose access to UPC Wi-free in other locations [#16012836][#16012852] The only hardware workaround mentioned is disconnecting the Wi‑Fi antennas, but that also disables your home Wi‑Fi [#16015640][#16017291]
  • #1 16012788
    veder1
    Rate: 47
    Hello, how to disable "UPC Wi-free" broadcasting in this modem ???
  • #3 16012816
    mr_slimm
    Help: 9
    Rate: 12
    Change the modem settings. See Annex.
    • upc_instrukcja_obslugi_modemu_thomson_twg870-eu.pdf (3.34 MB) You must be logged in to download this attachment.
  • #4 16012836
    jimasek
    Help: 3783
    Rate: 2682
    As far as I know, you then lose access to this service in other locations.
  • Verify the MAC before disabling UPC Wi-free
    #5 16012852
    safbot1st
    Help: 2719
    Rate: 1585
    @ veder1 The first thing is that the "UPC Wi-free" SSID in the screenshot you presented does not have to be broadcast by your modem at all. You will be sure when you check e.g. the MAC address. However, I assume that there are no other modems / routers in your location (SSID "UPCxxxxxxx") that have an active service. Windows are "blind" to separate access points and all "UPC Wi-free" merge into one, :D :D :D .
    @mr_slimm There is no such "feature".
    @ goldi74 Will turn off. Only that after disabling the service, he will not be able to use it later, e.g. in the city (from the Internet via UPC Wi-free).
    Reading:
    https://www.elektroda.pl/rtvforum/topic2862252.html
    https://www.elektroda.pl/rtvforum/topic2962336.html
  • #6 16014873
    veder1
    Rate: 47
    I would like to point out that I do not use the UPC internet, but from another service provider. The modem is only UPC and I would like to disable it. GAD DEMYD (I'm not a UPC user) and I want to deactivate this option?
  • #7 16015640
    safbot1st
    Help: 2719
    Rate: 1585
    As in my links: there is no other option, unfortunately, only turning it off via the My UPC page.
    Possibly disassembling the antenna, but then you deprive yourself of wi-fi.
    I don't know where you got the modem-router from, but maybe turn it off on the My UPC page using the account of the person-owner of the device?
    It is different if this someone, as we wrote, uses wi-free ...
    Or maybe your ISP that you haven't specified has an option on its website?
  • #8 16015666
    goldi74
    Help: 1367
    Rate: 1539
    If the modem works in a different cable network, it is impossible to disable the service on the UPC website. It remains to contact the supplier about which we know nothing.
  • #9 16015854
    veder1
    Rate: 47
    GAD DEMYD internet provider is municipal cable tv, and how to upload older soft?
  • #11 16016107
    veder1
    Rate: 47
    GAD DEMYD if I'm not in UPC, how does it pay me telepathically?
  • #12 16016143
    safbot1st
    Help: 2719
    Rate: 1585
    GAWD DEMMIT Check if you are 100% broadcasting the SSID yourself, I wrote how, because it's some strange story that gets done. Does your supplier have a contract with UPC or what ??? And Wi-free sends internet via cable tv or UPC? It is not very logical.
    Linux will be extremely helpful as it will split one SSID into separate access points with their own MACs.
    Just unplug the modem router from the network and see which "UPC Wi-free" disappears (if it goes).
  • #13 16016736
    veder1
    Rate: 47
    I bought the GAWD DEMMIT modem at an auction and it is connected to a cable TV service provider that has nothing to do with UPC. And the bank is the modem that sends UPC WIFI-free GAD DEMYD
  • #14 16017291
    KOCUREK1970
    Help: 3867
    Rate: 5500
    In this light, you won't do anything about it.
    So what if it broadcasts - if there is no UPC signal, no one will connect to this hotspot anyway (the connection may and will be established, but the net will not be there).
    You can also disconnect the wifi antennas (dismantle the modem and disconnect), but then you lose access to your home network via wifi.
    You bought the worst possible equipment - you had to buy Ubee, or Compala, or the old Cisco EPC3925.
    Either buy a blank Cisco EPC 3212 cable modem or a Cisco EPC 3008 cable modem and plug in your own router - then you get rid of UPC WiFree.
  • #15 17465570
    icooz
    Help: 14
    Rate: 43
    I was looking for how to turn off wifi free, the picture shows a solution if someone else was looking like me.
To disable the "UPC Wi-free" broadcasting on the Thomson TWG870U modem, users are advised to check the My UPC page for options. If the modem is not connected to UPC internet, disabling the service may not be possible through the UPC website. Some users suggest contacting UPC directly for assistance or considering hardware modifications, such as disassembling the antennas, though this would eliminate home Wi-Fi access. It is also noted that if the modem is used with a different ISP, the UPC Wi-free service may not be applicable. Users are encouraged to verify if the SSID is indeed being broadcasted by their modem or if it is a result of nearby UPC services.
