Can the LED power supply be connected to the power supply all the time?
Roxron 32331 43
Can I leave an RGB LED strip power supply connected all the time so I don’t have to reconfigure the controller after every power-off?
Yes, you can leave it connected all the time; a warm PSU with the LEDs off is usually just its own operating consumption, not a problem for the strip. The LEDs are not affected, but the PSU’s life may be shortened a bit, and if it fails it will more likely just stop working than smoke or explode [#16024273][#16024302][#16024318] If the supply gets very hot when the strip is on, the thread suggests it is a poor-quality or undersized unit and you should replace it with a better 12 V supply with some power reserve [#16026011][#16026181]
  • #31 16027601
    Roxron
    Rate: 19
    I understand, thanks for the clarification. Overall it doesn't need 5 meters of tape, 4 would be enough for me, so if I cut off that 1 meter will the consumption decrease? Will these 4 meters of LED then consume the same amount of current and be able to burn out?
  • #32 16027717
  • #33 16027744
    mawerix123
    Help: 482
    Rate: 951
    This power supply with a safe power reserve is enough for only three 3 meters of tape.
  • #34 16027821
    Roxron
    Rate: 19
    And if the LEDs are on only in one color, e.g. Green, will the 4m strips consume 4.8*4=19.2W? Do they always draw 57.7W? And reducing the brightness will also relieve the power supply?
  • #35 16027833
    mawerix123
    Help: 482
    Rate: 951
    Roxron wrote:
    And if the LEDs will be turned on only on one color, e.g. Green
    And if someone decides to change the color and turn them all on :?:
    Roxron wrote:
    will 4m tapes consume 4.8*4=19.2W?
    Yes.
    NO.
    I know what you're getting at :D a set with allegro PLN 49 and a suitable power supply for them costs over PLN 100 ;)
  • #36 16027866
    Roxron
    Rate: 19
    Trying to minimize costs as much as possible, you know :) So theoretically they never consume these 57.7W, because this situation is only on white. Well, not wanting to spend an extra penny on the power supply, you have to limit yourself to 4m, one color and lower brightness. Thank you for your help, if I encounter any problem, I will write, and if not, I will close it.
  • #37 16028454
    zbich70
    Help: 1171
    Rate: 6668
    Additional question - this LED power supply for your only receiver?
    You want to minimize costs on idling power supplies, but you probably have other power-hungry receivers whose power is several kilowatts. You don't care about that?...
    I know people who turn on stoves, boilers, ovens and kettles to the max without the slightest inhibition... until the protection is activated ... and then, attention, they ask how much the phone charger takes, because they want to reduce costs ...
  • #38 16028486
  • #39 16028624
    Roxron
    Rate: 19
    As you wrote above.
    I connected 4m to the power supply and all in all there is not much difference, even with one color the power supply is very warm, at least it does not burn, although I do not know what it looks like after prolonged operation.
    Out of curiosity, I connected the cut meter of tape and set it to white. The power supply was probably even warmer than in the previous case, and the LEDs got so hot that they began to burn. Probably because I left them wrapped on a roll or from too much power. I am only surprised that the power supply reached such a high temperature even with 1 meter of tape. Maybe it will always heat up regardless of the energy demand of the leds?
  • #40 16028887
  • #41 16028996
    idepopizze
    Help: 82
    Rate: 270
    It is also worth finding out how much the LED driver itself consumes for its own use, because it can cause this warm power supply even when the LEDs are not lit.
  • #42 16029266
    Roxron
    Rate: 19
    After connecting the power supply, the output voltage oscillated around 12V, and after about 10 minutes of operation, the voltage oscillated around 12.1V. The power supply got warm, but after these 10 minutes it is warm, not hot.
  • #43 16029705
    kosmos99
    Help: 338
    Rate: 820
    Like the one I had with the tv antenna power supply, at the beginning it was hot even though the current efficiency was only 100mA, and then it cooled down even though nothing in terms of working conditions has changed.
  • #44 16029781
    Roxron
    Rate: 19
    Then I will turn it on for a longer time and observe.
    What power supply do you recommend? Maybe it's worth buying a modular one? Is it better than the plastic one? Because on Allegro, prices do not differ too much. Look for a 12V 6A power supply or choose a 5A like this one?
The discussion revolves around the safety and implications of keeping an LED power supply connected continuously, particularly for RGB LED strips. Users express concerns about the power supply heating up even when the LEDs are off, questioning whether this could shorten the power supply's lifespan or lead to potential hazards like smoking or exploding. Responses indicate that while the LEDs themselves are not affected, the power supply may experience a reduced lifespan due to constant operation. Users also discuss the quality of the power supply, with some suggesting that a faulty or low-quality unit could overheat. The conversation includes technical details about power consumption, with calculations indicating that a 5m SMD5050 LED strip could draw significant power, necessitating a power supply with adequate capacity. Recommendations for measuring power consumption and considering a higher-rated power supply are also provided.
TL;DR: Leaving a 60 W LED-strip PSU plugged in 24/7 adds about 0.4 kWh / month (≈€0.10) [DOE, 2020]; "it rather stops working than explodes" [Elektroda, kosmos99, post #16024318] Why it matters: Knowing real heat, load and costs lets you choose a safer, longer-lasting supply.
• Typical standby draw (60 W SMPS): 0.5 – 1.5 W [DOE, 2020] • Safe case temperature: ≤ 70 °C surface [UL, 2019] • 5 m RGB 5050 (30 LED / m) at white: ≈ 72 W [Elektroda, mawerix123, post #16027420] • Recommended PSU headroom: 25 – 30 % [Mean Well, 2021] • 12 V 100 W modular PSU price: €15 – €25 (Allegro listings, 2024)
Can I leave the LED-strip power supply plugged in all the time?
Yes. Users report years of continuous operation without LED damage [Elektroda, zlotowa666, post #16025215] The supply draws a small standby wattage, so energy cost is low.
Does standby heat mean the PSU is faulty?
Mild warmth is normal because control circuitry still works [Elektroda, kosmos99, post #16024273] A case hotter than 70 °C indicates overload or poor quality.
Will constant power shorten the PSU life significantly?
Not if the supply runs within specifications. Life depends more on capacitor quality than on uptime [Elektroda, CYRUS2, post #16025004]
Can the PSU smoke or explode?
Failure usually ends in silence—“it rather stops working than explodes” [Elektroda, kosmos99, post #16024318] Catastrophic events are rare but possible with cheap, unventilated units.
How much energy and money does standby draw?
A 1 W standby load consumes 0.72 kWh/month—about €0.18 at €0.25 /kWh [DOE, 2020].
Why is my 60 W supply hot with only half load?
Cheap units run at 50–65 % efficiency at light load; the wasted power becomes heat [CUI, 2021]. Ventilation and quality matter more than rating.
How large should my power supply be for 5 m RGB SMD5050?
Full-white needs ≈ 72 W [Elektroda, mawerix123, post #16027420] Add 25 % headroom: choose a 90 – 100 W (7.5 – 8 A) 12 V supply [Mean Well, 2021].
Does brightness and colour affect consumption?
Consumption falls with PWM dimming and single-colour use. One colour uses roughly one-third of the white load [Elektroda, mawerix123, post #16027833]
How can I measure the actual current safely?
Use a multimeter’s 10 A range in series between PSU and controller.
  1. Disconnect positive lead.
  2. Insert meter probes inline.
  3. Power on and read amps. [Elektroda, mawerix123, post #16027065]
What surface temperature is safe to touch?
Standards limit accessible parts to 70 °C; above 60 °C feels painfully hot [UL, 2019]. Use an IR thermometer if unsure.
Should I buy a plastic plug-in or metal modular PSU?
Metal modular units dissipate heat better, offer screw terminals, and often include EMI filters. Price difference is small (€5–€10) (Allegro listings, 2024).
What edge-case failure should I watch for?
Dry electrolytic capacitors can raise output to >20 V, instantly overheating LEDs [Texas Instruments, 2018]. Shut down supplies that show rising voltage.
How do I test PSU output voltage?
Set meter to 20 V DC, touch probes to V+ and V–. Expect 12 ± 0.3 V. Variations beyond 5 % mean replacement [Elektroda, Roxron, post #16029266]
