Win10 problem - Black screen while recovering win10 system to work state
MagisterPro 6693 10
Why does Windows 10 get stuck on the preparation screen and then show a black screen when I try to reset the system to its initial state, and how can I fix it?
Check the drive first by reading its SMART data and running a surface scan in MHDD, because a failing disk was the main suspicion in the thread [#17127224] [#17129544] Boot from Ultimate Boot CD, start Parted Magic, and post the disk health attributes; in MHDD, press F8 to show the full SMART table [#17127224] [#17129529] If you can, run a 2xF4 surface scan and review the results [#17129544] After the disk was unplugged, the Windows installer still stopped at the logo and black screen, so the disk was considered OK and the cause is likely elsewhere [#17129978] [#17130497]
  • #1 17126492
    MagisterPro
    Hello, I wanted to format the computer because it started something mulic, I decided to do it by restoring Windows 10 to its initial state. I chose to delete everything but without wiping the disk. The preparation for the desktop restart started and after a few minutes the system rebooted. Well, now there was a problem because for a moment this windows icon showed the word `` preparation '' and a small dot above the inscription and it kind of got bitten. And then I just see a black screen and nothing happens. I've been waiting for over an hour anyway, restarting doesn't help because it's the same thing. What can I do to fix it or somehow terminate this process - should I wait? Please help :)
    PS: desktop computer, win10 upgraded from 7
  • #2 17126530
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Do you have a working disk? Put his SMART from MHDD.
  • #3 17126641
    MagisterPro
    lately I have an impression that it works slower and sometimes it is very heavy when I do nothing. Plus now I started to receive a message that I can not continue the installation of windows and I have to restart the computer but it does not help I can do it over and over again to no avail
  • #4 17127224
    Kasek21
    Help: 4981
    Rate: 3547
    Download: http://www.ultimatebootcd.com/download.html
    Boot the computer from the pen / disc with the recorded image and run Parted Magic.
    Post the photo after clicking the Disk Health -> Attributes icon.
  • #5 17128030
    MagisterPro
    Well, I ran this program on pena and I wanted to run Parted Magic but I ended up with this "setting up system devices" and then nothing happened. I also tried MHDD but I don't know why but it just doesn't detect the disk. I also downloaded the Gparted program, which I formatted the partitions and wiped the disk. Then I wanted to run the Windows installer with pen but the effect was the same as in the beginning, i.e. the windows icon and then a black screen.
    Added after 19 [hours] 44 [minutes]:
    I was able to see the SMART parameters and what do they show?
    • Win10 problem - Black screen while recovering win10 system to work state 20180326_182845.jpg (5.2 MB) You must be logged in to download this attachment.
  • #6 17129529
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    It doesn't have all the parameters. Press MHDD F8 and then any key to make the program show the bottom part of the table.
  • #7 17129534
    MagisterPro
    Oh please :)
    • Win10 problem - Black screen while recovering win10 system to work state 20180326_190207.jpg (5.06 MB) You must be logged in to download this attachment.
  • #8 17129544
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Perform a surface scan in MHDD (2x F4). After scanning, post the results on the forum.
  • #9 17129816
    MagisterPro
    Here are the scan results only by accident I turned off the scan and then started from then on
    • Win10 problem - Black screen while recovering win10 system to work state 20180326_202900.jpg (5.28 MB) You must be logged in to download this attachment.
    • Win10 problem - Black screen while recovering win10 system to work state 20180326_190121.jpg (1.85 MB) You must be logged in to download this attachment.
  • #10 17129978
    MagisterPro
    I unplugged the disk and started the installation with the pen, but the effects were the same as before, i.e. the icon and the black screen, so it's not the disk's fault?
  • #11 17130497
    Kasek21
    Help: 4981
    Rate: 3547
    MagisterPro wrote:
    so it's not the fault of the disk?
    The disk is OK.
The discussion revolves around a user experiencing a black screen issue while attempting to restore their Windows 10 system to its initial state after formatting the computer. The user initially chose to delete everything without wiping the disk, leading to a failed installation process characterized by a black screen after the Windows logo. Various troubleshooting steps were suggested, including using diagnostic tools like MHDD and Parted Magic to check disk health and perform surface scans. Despite attempts to reinstall Windows using a USB drive and formatting partitions, the user continued to encounter the same black screen issue, leading to the conclusion that the disk may not be the source of the problem.
