windows 10 - resetting the settings to the initial state of 30% format and does
Hexi 34818 13
How can I fix a Windows 10 reset that stays at 30% and then no longer boots?
If Windows 10 reset is stuck at 30%, first check the hard drive SMART status, because the original problem may be drive-related, and the installation may still finish if you wait longer [#16595206] If the computer then shows "An operating system was not found", the fastest fix is a clean reinstallation of Windows rather than trying to change BIOS settings [#16595357] Create a bootable USB with Microsoft’s Windows 10 Media Creation Tool, not just an ISO file on a pendrive [#16595416][#16595448] In the tool, choose the USB flash drive option so it prepares a bootable pendrive automatically [#16595530][#16595558]
  • #1 16595184
    Hexi
    Rate: 11
    I tried to format windows 10, because something happened to the computer, and a sad face appeared, I clicked to format everything.
    And for some 30 minutes, a little bit more, I'm standing on those 30%, only this circle is spinning and nothing more.
    It wrote to me that sometimes it takes up to a few hours, but recently I did, and it took me less than 90 minutes.
    Greetings.
    Dra98
    Help: 1321
    Rate: 1076
    It would be worth to diagnose the problem, check the hard drive to read SMART first
    Or wait patiently, the installation may succeed.
  • #3 16595208
    Hexi
    Rate: 11
    And if I turn off the computer, something will break down and the website will remain? Because I can still check with the pendrive from the windows 10 creation tool.
    Okay, with 30% I jumped to 90%, I'll write soon if it will come to an end
  • #4 16595306
    Hexi
    Rate: 11
    "An operating system was not found." Ctrl + Alt + Del is restart "
    This problem I have after restoring windows to factory settings after I had a sad face on the screen and the only thing I could do.
    Do you need to install windows with windows creation tool or how?
    Like something in the bios you have to do, but I do not know what.
    Greetings.
  • #5 16595357
    Heinzek
    Help: 554
    Rate: 494
    You do not have to change anything in bios. Something broke down the operating system boot. Since you have been restoring the system, it will be the fastest now as you do a new clean installation.
  • #6 16595391
    Hexi
    Rate: 11
    I'll try a pendrive zbootowanym bootable to do it ... bootleg pendriva boot.
  • #8 16595424
    Hexi
    Rate: 11
    Well, I just downloaded it, I chose the pendrive, iso for another computer, but I think that this pendrive will not boot, only the windows file itself will be.
  • #9 16595448
    Heinzek
    Help: 554
    Rate: 494
    You could only choose a pendrive and install it right away. Pendrive ready to use.
  • #10 16595514
    Hexi
    Rate: 11
    I have not seen this option. Only for this computer or for another, use a pendrive.
  • #11 16595530
    Heinzek
    Help: 554
    Rate: 494
    Hexi wrote:
    I did not see such an option ... Only on this computer or on another one, pendrive.
    If Windows parameters do not suit you then you choose another computer. In the next step, where you can choose the ISO file or Flash drive, you choose a USB flash drive.
  • #12 16595546
    Hexi
    Rate: 11
    Damn, and I chose the second option, but in this case, boot the pendrive with the pendrive along with this file in the pendrive?
    Edited.
    Do not quote the preceding posts in their entirety. RADU23
  • #13 16595558
    Heinzek
    Help: 554
    Rate: 494
    I have not done rufus for a long time but he will rather unzip the ISO and rewrite the flash drive to start.
  • #14 16596220
    RADU23
    Help: 2428
    Rate: 1732
    Again, one topic spans five topics.
    I asked you to continue all your questions on one topic if they concern the same hardware and the same system.
    I've merged themes.
The discussion revolves around a user experiencing issues while attempting to reset Windows 10 after encountering a "sad face" error. The user reported being stuck at 30% during the formatting process for an extended period. Responses suggest diagnosing the hard drive and waiting for the installation to complete. The user later faced an "operating system not found" error after attempting a factory reset. Suggestions included using the Windows 10 creation tool to create a bootable USB drive for a clean installation, with emphasis on not needing to change BIOS settings. The conversation also covered the correct procedure for creating a bootable USB drive using Microsoft's tool instead of third-party software like Rufus.
