[Solved] Windows 10 Reset Stuck at 51% for 2 Hours: How to Fix Initial State Settings Issue
Mrkacper 7179 3
  • #1 17166827
    Mrkacper
    Level 4  
    Rate: 32
    Hello, I have a problem because today around 8 o'clock I started resetting the settings to the initial state and at some point it stopped at 51% and for 2 hours nothing has changed, please help.
    sylweksylwina
    Help: 1877
    Rate: 2341
    Is HDD activity?
    Maybe some driver installation has suspended the installation.
    SHIFT + F10 type taskmgr and look for something not Microsoft or dpinst.
    Kill the process as it will, nothing else is left.
  • #3 17166856
    Mrkacper
    Level 4  
    Rate: 32
    Thanks to so much, I clicked something and it worked out within 10 minutes it ended, thank you for your help.
  • #4 17166858
    Mrkacper
    Level 4  
    Rate: 32
    Added after 36 [seconds]:
    It turned out that something blocked further progress
