How can I fix the Access Violation crash in Gothic II: Night of the Raven when the menu appears, especially when music is enabled?
Reinstall the game and mods in the recommended order: G2NK, GMDK, the GMDK patch, the report version for G2NK, Gothic Starter, then System Pack [#16073563] If you use a non-original copy, this fix may not help [#16073563] On Windows 7, also disable DEP for all programs and services except the selected ones, then add every .exe from the Gothic System folder [#16073563] Since the logs mention DirectMusic and there were missing DLL errors before, reinstall DirectX as well [#16077831] One reply also suggested uninstalling Game Manager and launching the game through Gothic Starter [#16069095]
  • #1 16066804
    koxu232
    Rate: 18
    After launching Gothic 2, Night of the Raven, something like this pops up when the menu appears.
    Gothic 2 - Błąd Access violation.
    I've tried everything, but nothing works.
    Windows 7 x64 Home Premium
    Intel Core i5 5200u
    Geforce 920m
    8 GB RAM
  • #2 16066875
    madstorm
    Rate: 66
    Check the VDFS.CFG file in the game's root directory (open the file, e.g. in notepad). The correct structure should be in accordance with the following. In case the content differs from the one specified, copy it to your file (overwriting the data) and save the changes.
    [VDFS]
    DATE \ *. Vdf
    DATE \ *. Mod
    [END]
  • #3 16067015
    koxu232
    Rate: 18
    The content of this file is no different.
  • #4 16068730
    Rafik_ck
    Help: 19
    Rate: 84
    In my opinion, this is the fault of Win 7 that you have because the game on Win 7 may not work, but maybe you will find a fix to get the game to run.
  • #5 16068741
    sosarek
    Help: 9320
    Rate: 15532
    I mean what?
    Have you tried to run the game in Administrator compliance mode?
    Z
    Pka, Poznań, 60-850
  • #6 16069024
    koxu232
    Rate: 18
    On another win 7 computer this game worked for me. Running in Administrator compliance mode, I installed various patches and fixes but nothing helps.
  • #7 16069041
    sosarek
    Help: 9320
    Rate: 15532
    koxu232 wrote:
    On another computer with win 7
    Not by chance in the 32bit version?
    Have you tried updating your graphics driver?
    Z
    Pka, Poznań, 60-850
  • #8 16069095
    Robert B
    Help: 2027
    Rate: 1412
    Exactly what and in what order?
    What resolution are you running at?
    Uninstall Game Manager and run via Gothic Starter.
    It also works on Win 7-64. From G1 to G3 inclusive.
  • Disabling music avoids the Access Violation error
    #9 16070173
    koxu232
    Rate: 18
    I tried this http://pl.gothic.wikia.com/wiki/Blog_u%C5%BCy...ght22/Access_Violation_a_Gothic_II:_Noc_Kruka
    I do not know in what resolution it starts up, but I think 1024x768 because the image is cut off.
    Added after 13 [minutes]:
    I was able to start the game but disabling the music. But what a Gothic game without music :) After turning on the music, acess volation pops up in the menu. Anyone know why this is happening?
  • #10 16071320
    Robert B
    Help: 2027
    Rate: 1412
    Pack the files:
    gothic.ini and gothicgame.ini
    and insert here as an attachment.
    What is your native monitor resolution and what graphics card do you have?
  • #11 16071408
    koxu232
    Rate: 18
    1366x768 resolution. I have no problem with that, the game works in this resolution.
    Intel HD 5500 + Geforce 920M graphics card
    • 1.rar (7.4 KB) You must be logged in to download this attachment.
  • #12 16073563
    Robert B
    Help: 2027
    Rate: 1412
    Uninstall everything and install in this order:
    1. G2NK
    2. GMDK:
    http://www.worldofgothic.de/dl/download_94.htm
    3. Patch for GMDK:
    http://www.worldofgothic.de/dl/download_99.htm
    4. Report version to G2NK:
    http://www.worldofgothic.de/dl/download_278.htm
    5. Gothic Stater:
    http://www.worldofgothic.de/dl/download_168.htm
    6. System Pack:
    http://dl1.worldofplayers.ru/games/gothic/patches/systempack/g2notr-systempack-1.6.exe
    Gothic original? If not, it won't help.
    Also this:
    Q: My game doesn't start, Access Violation crashes after the intro.
    A: Right click on 'start menu' -> 'system' -> 'advanced system settings'. Then you go to the 'advanced' tab, enter the 'performance' settings and the 'data execution prevention' tab.
    Of the two to choose from, you select the option 'Disable DEP for all programs and services except those selected below', then add all files with the .exe extension from the gothic folder 'System' and save. Access volation should disappear after the intro.
  • #13 16074929
    koxu232
    Rate: 18
    Unfortunately, it does not help, but thanks for the trouble.
  • #14 16075251
    Robert B
    Help: 2027
    Rate: 1412
    Maybe you have a damaged disk or memory and thus corrupted files?
    Show SMART disk:
    www.hdsentinel.com
    and Memtestem memory test:
    www.memtest.org
  • #15 16077038
    koxu232
    Rate: 18
    It is not RAM or disk fault. In my opinion, this is due to bugs with directx. Earlier, I had an error about missing dll files. He writes something in the logs about direct music, I guess that's what it is all about.
  • #16 16077831
    Robert B
    Help: 2027
    Rate: 1412
    koxu232 wrote:
    i had an error about missing dll files. He writes something about direct music in the logs
    And the local fairies know what files it is and they know the content of the logs.
    So what's your problem with reinstalling DirectX?
The discussion revolves around an "Access violation" error encountered when launching Gothic 2: Night of the Raven on a Windows 7 x64 system with an Intel Core i5 5200u and Geforce 920m graphics card. Users suggest checking the VDFS.CFG file for correct structure, running the game in Administrator mode, and ensuring the graphics driver is updated. Some users report success by disabling music, while others recommend a complete reinstallation of the game and necessary patches in a specific order. There are also mentions of potential issues with DirectX and hardware faults, such as damaged disks or memory. The game reportedly works on other Windows 7 systems, indicating compatibility issues may vary.
