Title: Settlers Heritage of Kings Not Starting on Win7 - Admin Error & Launch Troubleshooting
thompson98000 8712 3
  • Run as administrator does not launch game
    #1 17030753
    thompson98000
    After some time I wanted to go back to the older little game "The Settlers Heritage of Kings", I have win7.
    Unfortunately, after installation, the message "log in as administrator and run" appears, even though my account is the only one on the computer and is the administrator.
    When I try PPM and "run as administrator" or set in properties to always run as an administrator, nothing shows up.
  • XP SP3 compatibility and admin launch fix
    #2 17030903
    atomic99
    Help: 171
    Rate: 338
    In the file properties set "Compatibility", select "Run this program in compatibility mode:" select "Windows XP Service Pack 3" and at the bottom select "Run this program as administrator"
    It is possible that you are missing one of the packages (Microsoft Visual C ++ Package), you can download them from this topic:
    https://www.elektroda.pl/rtvforum/topic3398939.html#16831596
    Also update packages (.NET Framework)
    If you have the game on a disc, check the disc contents in the directory (X: \ support \ DirectX), you have DirectX, install it.
  • #3 17031893
    thompson98000
    I did it all and still only the window "do you want to allow the following program ... etc" is showing, I click yes and nothing appears, nothing is in the processes
  • #4 17032014
    atomic99
    Help: 171
    Rate: 338
    Then you can check patch 1.06 (Patch 1.06 The Settlers Heritage of Kings)
    http://thesettlers.com.pl/download/patche/s5/settlers_5_v1.06.exe
    Unless you have the game version "Platinum Collection / Extra" or "Classic NeXt" then you should already have this patch, check the file version.
    File properties of "settlershok.exe" tab details "File version: 1.6.217.0"
