[Solved] Robin Hood: Legend of Sherwood (2002) on Windows 10: Fix Stuttering & Low FPS Issues
marcin.k. 25374 2
  • #1 17238791
    marcin.k.
    Rate: 9
    I would need help starting the game Robin Hood Legend Sherwood on Win 10. The game is quite old (2002), and as you know, some titles have problems operating on the new system of the majkrosoft. In this case, the game starts normally and goes to the menu. However, after switching on the game, the game stutters incredibly, some 1 - 2 fps. I tried the solution given in this guide:
    https://steamcommunity.com/app/46560/discussions/0/364043054119876781/
    Some helped, I unfortunately did not feel the difference.
    The equipment is Intel Core i5-8400 2.8 GHz, GF GTX 1050Ti 4GB and 2x4 GB Patriot DDR4 2666 Mhz on the ASRock Z370 Pro4 board. I do not think it matters, because on the older Phenom X4 and Radeon HD7770 it was the same.
    Anyone have any ideas?
  • #2 17238983
    daminek1234
    Help: 61
    Rate: 88
    Try to run as an administrator in WindowsXP compatibility mode.
  • #3 17267095
    marcin.k.
    Rate: 9
    It helped to combine both ways. Now you can play :)
