Siemens EQ.7 Z Coffee Machine TK76209RW/05: No Power, Checking Control Module & Display Options
remek_g 16578 15
Why does a Siemens EQ.7 TK76209RW/05 coffee machine have 230 V at the control module but no display or signs of life, and how can I tell whether the power supply or display module is faulty?
The most likely fault is in the control-board power supply: the 10 Ω / 5 W cement fuse resistor is blown, and you should check why it failed before replacing it [#16107676][#16107820] Check the rectifier bridge diode by diode, the 400 V capacitors for shorts, the D1 diode, and the FSCM0465R converter section; another converter on the board uses an LNK304-based stage [#16101195][#16108173] If the resistor/fuse is open, replacing it and then powering the module for a test is reasonable, but keep spare parts on hand in case something else in the supply is bad [#16107820] In the reported case, the resistor markings were traced back to that 10 Ω fuse resistor, and the module was identified as having two converters, with the fault linked to the FSCM0465R area [#16107676][#16108173] The original poster ultimately fixed the machine by swapping in the control board from an identical donor machine [#16269051]
  • #1 16098840
    remek_g
    The Siemens EQ.7 TK76209RW/05 coffee machine shows no signs of life when plugged in and the power switch is turned on. The display does not light up. The control module is receiving 230 V.
    There are no visible damaged components or burnt tracks on the board. I have tried to rule out any cold solder joints. I can’t make any further progress without a schematic of the module. Does anyone have any ideas? Or would it be better to buy a whole new power supply module? Perhaps the display module is faulty, but the power supply is working? How can I check this?
  • #3 16099012
    remek_g
    Siemens EQ.7 Z Coffee Machine TK76209RW/05: No Power, Checking Control Module & Display Options Siemens EQ.7 Z Coffee Machine TK76209RW/05: No Power, Checking Control Module & Display Options Siemens EQ.7 Z Coffee Machine TK76209RW/05: No Power, Checking Control Module & Display Options
  • #4 16099033
    dzi_dziuś
    Home appliances specialist
    Help: 341
    Rate: 1170
    At the very beginning, check the resistance of the indicated resistor and compare it with the value read from the strips http://serwis-tv.com/opornik.html
    You can also measure the voltages on electrolytic capacitors, just don't hurt yourself and short circuit :)
  • #5 16101123
    remek_g
    The resistor value read from the strips should be 100K and within tolerance. The voltages on large electrolytes are trace. On 3 it has 3.8 V and on the other 0.2 V.
  • #6 16101195
    dzi_dziuś
    Help: 341
    Rate: 1170
    Nothing on the marked capacitors either? Are you measuring on the VDC range?
    If the measurement was done correctly, it would indicate a fuse - a white cube that fits in the drawn circle. If it has a break, it would be appropriate to determine why it burned out. At the beginning, you can check the rectifier bridge, 400 V short-circuit capacitors and the LNK 304 converter system itself (resistance between the 5th and 7th legs).
  • #7 16107676
    remek_g
    Actually the fuse (FTR2F 10 ΩJ...) is blown. In the connector, the appearance of the fuse and the fuse manufacturer's card. I don't know how to decipher the markings and what to replace them with?
    CCMTher...pdf (1001.33 kB)You must be logged in to download this attachment. Siemens EQ.7 Z Coffee Machine TK76209RW/05: No Power, Checking Control Module & Display OptionsWP_2016120..001.jpg (336.31 kB)You must be logged in to download this attachment.
    - the bridge only allows about 3 kΩ in one direction - it looks good
    - 400 V capacitors are not short-circuited
    - The LNK304 between the 5th and 7th legs is 1 MΩ one way and 4 MΩ the other way. I don't know what the values should be.
    Anything else to check?
  • #8 16107820
    dzi_dziuś
    Help: 341
    Rate: 1170
    It is a 10 Ω, 5 W, cement fuse resistor.
    To check the bridge, you need to check each diode in it separately. If you exclude this, you can risk replacing this resistor / fuse and connecting the module. Buy some just in case :)
  • #9 16107849
    remek_g
    In the bridge, I checked the transitions between each pair of legs and it's ok.
    If it has capacitors and the LNK403 chip on top, isn't it worth soldering in new ones?
  • #10 16108173
    Piotr2608
    Help: 851
    Rate: 4487
    The system consists of two converters. I do not see the LNK circuit within the damaged resistor.
    The element is responsible for the operation of this converter FSCM0465R and you need to replace it. Also diode D1 should be checked.
    Anticipating the question - I do not know the replacement for this system and the system itself is available in China. Maybe the layout will fit DM0465R (FSDM0465R) . The casing differs from the original.
    dzi_dziuś wrote:
    First, check the resistance of the indicated resistor
    This resistor is not the resistor you thought of :) If anything, this resistor should be behind the cube - you can see a green element (perhaps a choke) within two capacitors, most likely 4.7µF 400V - the second LNK304 based converter.
    PS FSCM0465R I found 2 pieces of this system if anything.
    • FSCM0465R.pdf (450.2 KB) You must be logged in to download this attachment.
    ZimTech Piotr Zimny
  • #11 16269051
    remek_g
    Thank you all for your suggestions. I found an identical machine with a damaged brewing module and used it for parts. After replacing the board, the device works.
  • Blown C26 component on control board
    #12 20649035
    lukasz696969
    I know this is a really old post, but I was wondering if someone would know what component is located on the C26 position of this board. The reason I ask is because last night my machine tripped the fuse while making coffee, and after checking the control board, I found the following component blown. Close-up of a circuit board with a damaged component at position C26. Green circuit board with visible burn marks near position C26. Close-up of a damaged component on a circuit board.
  • #13 20725623
    tomo24
    This is a TRIAK ST T4-3570 4A 600V.
  • #14 21380158
    ETsanov
    Hello and happy new year!
    Does anyone know what is the breakdown voltage of D16? The blue strip indicates it's a zener but unfortunately the voltage is not specified.
    P.S. I used an image uploaded by the previous commenter, hopefully it's not a problem, forgot to take a picture of my board ...
    Printed circuit board with components, including Zener diode D16 with a blue stripe.
    Regards,
    Emanuil
  • #15 21384861
    slawek1111
    Help: 88
    Rate: 91
    D16 is the MBR0540 schotky diode
    Pro Elektro Serwis
    Sportowa 7, Kluczbork, 46-200 | Tel.: 730XXXXXX (Show)
  • Q3 and Q4 transistor replacement fixed LCD power issue
    #16 21442463
    ETsanov
    Thank you very much, the machine is now fixed.
    Leaving this for future reference if someone has a similar situation:
    My machine worked sometimes and sometimes upon turn on the lcd would just light up briefly and turn off - leaving only the power on button light. When that happens it does not respond to any button presses either.
    Traced the issue to near the lcd connector - the second lcd wire is around 2.5 - 3.2 volts when the machine is working like it's supposed to, and 5v when it's not working at all. Ended up replacing Q3 and Q4 NPN transistors with new BC517 which solved the issues.
    Again - thanks for the help! :)
✨ The Siemens EQ.7 TK76209RW/05 espresso machine exhibits no power upon activation, with the display remaining unlit despite receiving 230 V at the control module. Users suggested checking the resistance of specific resistors and measuring voltages on electrolytic capacitors. A blown fuse was identified as a potential issue, with recommendations to check the rectifier bridge and the LNK304 converter. After troubleshooting, one user successfully repaired their machine by replacing the control board sourced from a similar damaged unit. Additional discussions included identifying components like a TRIAK and a Schottky diode, as well as troubleshooting intermittent power issues related to NPN transistors.
