[Solved] Siemens EQ.7 Plus L-Series Coffee Machine Power Module: TY6 Triac Identification & Replacement
ttokia 12087 4
  • #1 16446298
    ttokia
    Rate: 9
    Siemens EQ.7 Plus L-Series Coffee Machine Power Module: TY6 Triac Identification & Replacement Siemens EQ.7 Plus L-Series Coffee Machine Power Module: TY6 Triac Identification & Replacement Hello,
    I have a Siemens EQ.7 Plus L-Series coffee machine, E-Nr. TE713201RW / 1.
    A triac fired in the power module: TY6 but I don't know what symbol it is.
    May I ask you for help in identifying this element?
    I am posting photos of this item.
    Before it fired, the coffee refused to make coffee, it was supposed to have, but as I noticed, it only had a grinder but it had no grain and did not "pour" water.
    After several attempts on / off fired. Now when turned on, the display lights up and the grinder had coffee immediately.
  • #2 16446348
    robsons10
    Help: 73
    Rate: 401
    Hello. Triac markings:
    T4
    3570
    Please check the elements in the triac circuit, rectifier diodes on the other side of the sockets, heating circuit as well as the grinder itself. Regards
  • #3 16446363
    ttokia
    Rate: 9
    Thank you very much, I will buy, install, check and write back.
    Added after 48 [seconds]:
    I have one more question, how much does such a module cost and where would it be the cheapest (can it be abroad)?
  • #4 16446411
    robsons10
    Help: 73
    Rate: 401
    In norht about 570 PLN, probably cheaper stimulant. Please, check 0.082 resistor - how can you put o.o1 ohma 3-5Watt
  • #5 17335706
    ttokia
    Rate: 9
    I bought a new module.
