High Network Consumption by Service Host: Local System on Windows 10 Post-Update
Problem99 44811 5
  • #1 16131163
    Problem99
    Hello, I have a problem with computer data consumption because when connecting to any network via the service host computer: the local system "steals" the internet. I have windows 10 today I installed the latest update because 3 weeks ago I restored my computer to factory settings by deleting everything, then I installed jave, free avast and mozille firefox, a week and a half later the download of updates started and here is the beginning of internet problems with updates I had huge problems because no I was able to download them at all. Today I finished downloading and installing updates because only on weekends I have access to a computer but I still have internet problems and finally found out that the service host: local system eats almost all internet while connected to the internet and therefore it is impossible to use the internet on the computer. What should I do ? I need help :(
  • #2 16131653
    310artur
    Help: 980
    Rate: 670
    There are some new updates recently - 2 m was released this week so that's probably them.
    What kind of internet is it that devours it completely?
  • #3 16131846
    Problem99
    I have downloaded and installed all the updates, but I will disable Win Update and see how it will be. And I have the worst internet when downloading is 200 kb / s normally, one person will be able to sit on it but now Host Services: the local system uses almost the entire resource and regular pages load incredibly long ...
  • #4 16131963
    310artur
    Help: 980
    Rate: 670
    In windows 10 it is impossible to download all updates or disable the update, so I don't know what you did ;) In any case, it is not you, but the MS system and servers that decide when and what update you get.
  • #5 17559654
    DlaysQ
    Hello, I did, so I watched the guide of such a certain person. So that you do not use the internet through this "local system" you need to turn off windows update and turn off automatic updates also really helps because if you eat so much net, it means that you are doing some kind of update, so I recommend :) .
