Diagnostic Native Host Initiated by Scripts Slowdown: Windows 10 64-bit Computer Solutions
michal1234537 3912 6
  • #1 16345600
    michal1234537
    Hello. I have a problem with the computer because for some time while using it, it starts to work very slowly when I enter the task manager and close the process called "diagnostic native host initiated by scripts", everything returns to normal but I do not know what to do to make this process work did not turn on. Anyone have any ideas ????
    system: Windows 10 64 bit
  • #3 16345831
    michal1234537
    I made a screen as soon as the process again loaded the disk to 100%
  • #4 16345841
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    I don't see this process here (you didn't put up the whole PE window), from what I can see it's named sdiagnhost.exe.
    Submit the FRST logs.
  • #5 16348058
    michal1234537
    And would it help to reinstall the system ??? because I was planning to do anyway
  • #6 16930039
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Rather, as long as the hardware isn't causing the problem.
  • #7 16930067
    safbot1st
    Help: 2719
    Rate: 1585
    You can use a restore point.
    Post SMART from CrystalDiskInfo.
    Make a bootable memtest:
    http://memtest.org/download/5.01/memtest86+-5.01.usb.installer.zip
    and if you have a little more strength, write what is this PC and what is powered.
The discussion revolves around a performance issue on a Windows 10 64-bit computer, specifically related to the "diagnostic native host initiated by scripts" process (sdiagnhost.exe), which causes the system to slow down significantly. Users suggest using Process Explorer to analyze the process and recommend attaching FRST logs for further diagnosis. Other proposed solutions include creating a restore point, checking the hard drive's SMART status with CrystalDiskInfo, and running a memory test using Memtest86. Reinstalling the operating system is also mentioned as a potential solution, although it is advised to ensure that hardware issues are not the root cause of the problem.
