RTC Sections: Exploring Functions, Essential Signals, VCCRTC, RESET# & SRTCRST#, and Coin Cell Role
Gurmeet singh 8931 0
  • #1 16138586
    Gurmeet singh
    RTC section and its working conditions .
    RTC:
    It keeps track on storing the time, date and user’s system settings , and provides the timing , Even when there is no external power on the board (means the G3 mechanical off state) unless the on board 3.3v coin cell not removed.
    Working and essential signals of RTC.
    1. VCCRTC . VccRTC powers PCH RTC well which is mostly connected to the LDO output 3.3v of 3/5v regulator .which is generated before pressing the power button . and a 3.3v internal battery is used for VCCRTC too. (such as coin cell).
    2. RESET# and SRTCRST#. These signals are used to clear the system settings or in simple words we can say, to clear cmos settings . these signals are active when low and can b asserted by removing the RTC coin battery or by shorting the cmos clear jumperth. These signals are also fed from the same source of VCCRTC but through resistor dividers to make these signals high and to store system settings.
    3. RTCX1 and RTCX2. Basically ICH/PCH uses a internal timer IC having 256 byte of RAM which keeps track on date, time and system settings. Ich/pch uses a crystal circuit to generate a low swing sine wave of 32.768Khz at RTCX1 pin as input to the internal oscillator, and this input signal is amplified and driven back to the crystal circuit through RTCX2 pin of ICH/PCH with the same frequency of 32.768 Khz but with little higher amplitude due to amplification . thats why when we check the crystal pins with multimeter we found little difference in voltage at both pins. And it is the first check point whether the oscillator circuit of ICH/PCH is initialized or not .
    4. Sus_clock. The RTCX1 input is amplified for the purpose to drive internal logic of ICH/PCH
    And generates a free running full swing square wave of same frequency of 32.768 Khz as
    Clock output for system use . this output of ICH/PCH is known as SUS_CLOCK.
    SUS_CLOCK is the sure short way to check whether the RTC section is working properly or not by checking the wave form.
    Thats why we requires the DSO/CRO to check signals at motherboard as RTCX1, RTCX2 and SUS_CLOCK have the same frequency of 32.768 Khz if we check with frequency meter but the difference is the wave form (shape of the wave).
    5. INTRUDER#. This signal is used through a switch to find out the cover of the system is open or closed . we have seen in some branded systems , COVER OPEN SYSTEM HALT message, which is generated by this low signal . this signal is also a part of the RTC well. This signal is also kept high through VCCRTC.
    6. INTVRMEN. ICH/PCH have some internal voltage regulators and to enable these internal linear regulators an enable signal is also provided by this RTCVCC as INTVRMEN ( internal regulator enable)
    These all signals are the part of RTC WELL and must be present to turn on the board. In the absence of any of these may cause not powering up the board .
    Rtc crystal x1 pin .
    Pure sine wave of 32khz.
    Output of rtc section to the crystal pin x2 .
    Same frequency of 32 khz but difference is amplitude . Little high amplitude due to amplification .
    Sus_clk output of rtc section . After pressing pwr btn . Full swing square wave of same 32khz .
