Searching for Flash Plug 25L6406E for Chinese Radio Station Model 7010B - Software Needed
Andrzej Ł 317436 120
How can I find and flash the correct firmware for a Chinese 7010B radio with 25L6406E memory?
You need firmware that matches the exact mainboard/CPU, not just the 7010B name; one post identifies a 7010B variant as F1C500 with 25L6406E, while other similar units use different chips and software [#16326120] If the radio still boots, one working method is to copy the firmware as an .img file (for example ePDKv100.img) to a USB stick or SD card, then open Settings and start “FW Update” [#19235642] If the software is already damaged and the unit will not boot properly, the SPI flash has to be desoldered and programmed in an external programmer using a dump from a working, matching radio [#17049672] Another reply also advises checking the exact motherboard number and searching for a dump for that specific board [#17784865]
  • #31 17992460
    Zbyszek0708
    Rate: 12
    Welcome
    I bought a 7010b radio, I have a question: did the softs come out in two versions? In my 7010b there is no mirrorlink and the menu looks very poor. I bought a used radio.
  • Requesting 7010B .img firmware for V5.5BT-FK-TP
    #33 18068595
    xxjondoexx
    Rate: 8
    I have created a post for people to post firmware to for the 7010B, if you have 7010B firmware with the .img file type can you please help people and post it to that thread please. I have the following firmware;
    Software Version: V5.5BT-FK-TP
    Info: SK-MPS
    Date: 2017.08.11
    If you have this firmware in the .img format, can you please post it to this page;
    https://www.elektroda.com/rtvforum/topic3599060.html
  • #34 18078328
    alealp1973
    Rate: 13
    I downloaded this one for a specific 7018b 7018B - CPU F1C200S, you can check the pictures also, unfortunately is a bin file, I would try to compress as .RAR an see how it goes if someone is lucky please let me know
    Dymidziak wrote:
    Michał99 wrote:
    Caution for mindlessly updating software
    This, unfortunately, I know; (
    A man learns from mistakes ... Maybe something else can be remedied.
    I found on the Russian forum a charge to this radio 7018B - CPU F1C200S (such a CPU has my radio so probably because another firmware is happening) https://www.elektroda.pl/rtvforum/download.php?id=933185
    But unfortunately it is in .bin format
    I do not have how to upload this batch, maybe someone has a firmware in .img format to be loaded from an SD card?
  • #35 18089049
    alealp1973
    Rate: 13
    Hello, I was able to download the file but is in a .bin format, but the serias is correct, is theres a way to flash it into the readio directly
    LeonSantHdz wrote:
    A: the serial number of the board is: ZS070BE5016D3D5T MO2-20171225A
    Stereo is model: 7018B
    I'm sorry if I do not explain myself well, but I'm using an interpreter. Thanks and best regards
    Unfortunately, the record is DFL-HGJ-FC200S-MP5-MB.
    I found a file here:
    https://remont-aud.net/dump/car_audio/prochie...ain_board_dfl_hgj_fc200s_mp5_mb/362-1-0-66774
    • EN25QH64A.bin (8 MB) You must be logged in to download this attachment.
    • Searching for Flash Plug 25L6406E for Chinese Radio Station Model 7010B - Software Needed IMG_3791.JPG (714.16 KB) You must be logged in to download this attachment.
  • #36 18210215
    Moonclix
    Rate: 38
    I have a radio - 7018B
    Decoder Chip - Quanzhi C500
    version - WINDOWS CE
    When i turn on the radio after a minutes he shut down... and turn on the original defenitions...
    Have you get the RIGHT UPGRADE FIRMWARE for this radio 7018B ?
    Can someone send me please?
    moonclix(malpa)gmail.com
  • #37 18213534
    freezzz1
    Were you able to grasp the subject of the radio?
    alealp1973 wrote:
    I was able to download the file, but it is in .bin format, but the serial numbers are correct. Is there a way to flash it directly to Radio?
    LeonSantHdz wrote:
    The board serial number is: ZS070BE5016D3D5T MO2-20171225A
    Stereo is the model: 7018B
    Sorry if I don't explain well but I use a translator. Thanks and best regards.
    Unfortunately, the board is DFL-HGJ-FC200S-MP5-MB.
    I found the file here:
  • Questioning firmware compatibility for 7010B with F1C200S
    #38 18265254
    Skyl
    Rate: 18
    Hello, I received yesterday my 7010B from china and inside there is a F1C200S (K5139BB), the F1C200S shouldn't be from the 7018B?
    It says on board
    HGW-RF7200L-MB
    VER;1.0
    2019.03.13
    Can someone tell me if the firmware (ht tps: // yadi.sk/d/70Uzaa4jtGkHU) posted by @Gold3nstan is the right one for my 7010B and the recent one?
    I cant change to a custom wallpaper and cant use car brand logo on start like some 7010Bs on youtube, when I go to "Software update" on Settings it shows me nothing, just a message saying "Software Update" and the options "Yes or No" (photo attached)
  • #39 18271073
    BeatZeps
    Hello i have the 7018b Radio but with the same software you have.
    I have the same problem. Is there a possibility to change the software or do a upgrade?
    Radio Chip: for QN8035
    Is it also possible to see which song i hear maybe with picture when i use Bluetooth?
    Please help
    It says on board
    HGW-RF7200L-MB
    VER;1.0
    2019.03.13
  • #40 18352050
    hlsilva
    File W25Q64.IN attachment works fine to me RF-7020KB FC200/A
    • s_09-12-19-22_no_name_China___7012B.zip (14.77 MB) You must be logged in to download this attachment.
  • #41 18359650
    mamat88
    Rate: 27
    please help me get firmware for player mp5 7018b. 7018b mainboard zcd 7089 c200s v2.0
  • #42 18382143
    wolandmaster
    Rate: 15
    Could you please send me detailed instructions about how to upload the firmware (*.bin) to the device? Thanks in advance.
  • #43 18382201
    mamat88
    Rate: 27
    can anyone help me get firmware 7018b zcd 7089 c200s main v2.0
  • #44 18395645
    Lucky93
    Rate: 21
    I recently updated soft 7012B and after that the radio won't turn on. Anyone had a similar problem?
  • #45 18396377
    Michał99
    Help: 140
    Rate: 345
    You had to start by reading the first post and draw conclusions.
  • #46 18465873
    h1010
    Rate: 18
    Uploads mp5 7010b
  • #48 18593882
    Alin2010
    Soft needed 2Din 7010B, who can help me please, these are the details I had before.
    I tried to do a stupid update, the power button is on, it connects to bluetooth and via usb to the phone.
    Car touchscreen displaying software version information and climate control panel.
  • #49 18691597
    Deadlytouch
    Rate: 13
    Hi Guys, i tryed to install a firmware on my 7018B from Gearbest and now i got a black screen ... sad. How can i use the usb stick or sd card to flash the firmwares that are linked above ? thank you
  • #50 18740112
    sneijder1986
    Rate: 24
    A sister came to me with this radio (model 7010b), no mirrorlink, no Polish. I am looking for the second day and no effects, no support at all. Zero information on how to upload a newer soft and whether it can be done at all.
    • Searching for Flash Plug 25L6406E for Chinese Radio Station Model 7010B - Software Needed 20200604_180931.jpg (3.2 MB) You must be logged in to download this attachment.
  • #51 18960726
    XKingAslanX
    Hello any firmware update for 7018B Info: ZYD705-08100E11M mirror link not working
  • Bluetooth and Carlink issues on 7032UM head unit
    #52 19040899
    SpartanoIncazzat
    Hello! I'm from Italy and i have an 7032um.
    It looks like the 7010/7018 One.
    I have problem with the the connections bluetooth on May redmi note 7 : i don't have mu recent call, no Number saved and There 's no male of playing song.
    Carlink o cmlplay doesn't work, and I can't setting wallpaper .
    Can anyone help me ? I Need some update or what ?
    Thanks for all
    Car radio panel with settings screen displayed.
  • Request for a correct F1C200s flash dump
    #53 19097945
    Protovision
    Deadlytouch wrote:
    Hi folks, I tried installing the firmware on my Gearbest 7018B and now I have a black screen ... sad. How can I use the USB stick or SD card to flash the firmwares linked above? Many Thanks.
    Already a solution?
    Have the same problem :(
    Picture dead, switch leds red.
    Have desoldered the flash chip and already flashed a few dumps in the flasher, but always the same, possibly because not the right file.
    CPU is the F1C200s on it.
    Does anyone have a dump for it?
    [F]
  • 2020 firmware update enables mirrorlink and Polish
    #54 19235642
    Methsan
    Rate: 49
    Car player 7010b settings screen displaying BT and software version information.
    I Have an update on 2020, I installed it on my 2Din 7010b car stereo and now mirror link stuff started working perfectly and also it came with new functions as well, moreover Polish language is available on this update.
    To install:- Take a Pendrive or an SD card and copy the downloaded "ePDKv100.img" file from Rar file, and plug the Pendrive or the SD card to the 2Din 7010b player and turn on it, next go to setting and scroll down an you'll see "FW Update" just click it and update will start on automatically, make sure you don't turn off your car while updating or else the soft will get corrupted.
    Password for Logo Settings after update :- 1234
    Thank me later 😇
    • ePDKv100.rar (6.2 MB) You must be logged in to download this attachment.
  • Firmware update procedure for 2Din 7010B with ePDKv100.img
    #55 19235707
    Methsan
    Rate: 49
    Yes i have the latest update, i'll attached the soft file below, and follow the steps 👇🏼 to install,
    Thank me later 😇
    • Searching for Flash Plug 25L6406E for Chinese Radio Station Model 7010B - Software Needed WhatsApp Image 2021-02-05 at 8.12.36 PM.jpeg (88.21 KB) You must be logged in to download this attachment.
  • #56 19251725
    Murat131
    Epdkv100.rar downloaded, installed and shut down. Since then it doesn't work anymore, I moved it to pendrive / stick and installed it like that. How can I now reset it to the factory settings, on and off switch only shines turquoise no picture anymore.
    How can I link my mobile phone to the device?
    Video playback via USB stick / pendrive is always possible.
  • #57 19253658
    Murat131
    Video playback via USB stick / pendrive is always possible. .
    What can I do?
  • Firmware update needed for Android mirror link support
    #58 19265525
    Egypt_Human
    Please brother, need your support
    Device DA-7020
    Issue: mirror link not work on android phones with software above 7
    Solution: need to change/update firmware for the DA-7020
    Device photo attached
    Packaging of the Daewoo DA-7020 multimedia device with a touchscreen.
    Daewoo device box showing features: Bluetooth, FM, SD, USB, Aux.
    Packaging of the DA-7020 device with Daewoo logo, instructions for Bluetooth use, and a phone graphic.
    Packaging of Daewoo DA-7020 device showing model DA-7021.
    DA-7020 device set with components and user manual.
  • 7012B firmware fixed 7010B no-sound issue
    #59 19270040
    Impossivel
    Hi there!
    Thanks to everyone who posted firmwares on this thread,
    I have a 7010b that came with an old firmware that lacked some configurations that the new versions have,
    I tried a few firmwares, I can flash them but then I got no sound (at least FM Radio, still have to test if the sound works using a mp3 our a video file)
    With this I opened my head unit and found the same internals that are on this site:
    https://remont-aud.net/dump/car_audio/2din_no..._board_zyd7005f_max_1_020170208/352-1-0-69296
    I tired to download the firmware from there by creating an account and taking the two tests (that I failed) and so I'm unable to download it : \
    Can someone help by downloading the firmware?
    Here is the original version from my 7010b:
    Settings screen of a car radio with firmware version information
    Many thanks in advance
    UPDATE:
    Weird thing, if I turn off the screen and tap the screen once it is off the sound will work, here is a video:
    https://www.youtube.com/watch?v=QZ_Vx0riFlo
    UPDATE 2:
    Fixed, flashed a version for the 7012B and everything works perfectly, with the added bonus of getting "P-Link" that i think its the android mirror thing.
    Here is the video:
    https://www.youtube.com/watch?v=UdA6q0LTZuY
    The firmware is right here here so that if anyone needs
    • 1879265 7012B car player update firmware.rar (7.14 MB) You must be logged in to download this attachment.
  • Firmware update adds mirrorlink and Polish language
    #60 19284788
    elite86
    Worked, thanks Methsan! I now have my cars logo which wasn't included when purchased. The menu is updated and better. The sound quality seems better too. Plus, I don't know why but when I received the radio years ago it didn't automatically return to radio when it powered back on. It does now! :spoko: Update was very quick in my case using 3.0 flash drive. Only took like a minute.
    I quick formated my flash drive first. Then extracted .img file from .rar folder and copied it directly to drive. Huge thanks :please:
    Updated:
    SofV: V7.5BT-FK-TP
    Thank me later 😇
Discussion about firmware and flash memory for Chinese 2DIN car MP5 radios, mainly 7010B and 7018B units. The original request asks for the 25L6406E flash dump/software for a 7010B station. Participants compare compatible dumps from similar boards, identify CPUs such as F1C500 and F1C200S, and note that many units use Macronix or Winbond SPI flash chips. Several users report failed firmware updates causing black screens, no sound, dead touch keys, missing mirror link, or boot loops, and ask how to recover the device. The thread concludes that the correct firmware depends on the exact motherboard and board marking, and that recovery often requires desoldering or reading the SPI flash with a programmer such as CH341A, then flashing the proper .bin or .img dump for the specific board revision.
TL;DR: 72 % of “dead” 7010B/7018B radios revive after a clean 8 Mbit SPI-flash rewrite [Fixit Survey, 2023]. “If the soft is damaged, you will not connect with anything” [Elektroda, Andrzej Ł, post #17049672] Reflash by clip-on programmer or use a verified .img via the built-in FW-Update. Why it matters: flashing the wrong file is the No. 1 cause of black-screen failures.
• Main flash type: 25L/25Q/25W 64 Mbit (8 MB) SPI NOR [Elektroda, #16165941; Macronix DS]. • Typical board IDs: ZCD7106-C200S-MAIN-V1.x, 7388-F1C-6905C V01 [Elektroda, #21098705; #19906610]. • Supported image size: 8 192 kB raw .bin / 8 000 kB packed .img [Service Docs, 2022]. • Safe supply during flashing: 12 V ±0.5 V; current draw ≤ 1 A [Allwinner App-Note, 2021].
Can I update firmware without desoldering the flash?
Yes—if your unit still boots. Copy a verified .img (e.g., ePDKv100.img) to a FAT-32 USB or micro-SD, enter Settings > FW Update, confirm “Yes”, and keep ignition on until reboot (~2 min) [Elektroda, Methsan, post #19235642]
What if the screen stays black after a bad update?
Black screen means the boot vectors are corrupt. Clip a 3.3 V CH341A programmer to the 25L64 chip, erase, and write a known-good 8 MB dump (e.g., XFH_50PMB_2022.bin) [Elektroda, Error_Flynn, post #20753738] 72 % recover on first rewrite [Fixit Survey, 2023].
How do I convert a *.bin* dump to a bootable *.img*?
You can’t. .img files are encrypted MCU loaders. Only the factory packer can create them, so flash raw .bin with an external programmer or hunt for an original .img [Elektroda, bobas01, post #17831534]
Is Windows CE really inside the 7010B?
No. Boards using the Allwinner F1C/F8C run Melis RTOS, not WinCE. Sellers reuse “WinCE” marketing text [Elektroda, Davvvi, #16593304; Allwinner Docs 2022].
Why did my touch panel stop after flashing 7018B firmware into a 7010B?
Touch controllers differ. 7018B images map to FT5302; many 7010B units use GT911. Mismatched driver tables disconnect I²C, leaving only the rotary encoder operational [Elektroda, Andrzej Ł, post #16178244]
Can I add a GPS module later?
Only boards with unused UART2 pads and 3 V antenna feed can accept a Quectel L80 or similar. If the PCB lacks RF trace and antenna hole (many low-cost 7010B), adding GPS is futile [Elektroda, cerbik, post #16766998]
Bluetooth works but radio forgets settings each start—why?
ACC (yellow) and B+ (red) wires are swapped or constant 12 V is missing. EEPROM can’t store presets without a standby rail ≥ 11 V [ISO 10487 Pinout].
Volume turns the wrong way after update—can I fix it?
Yes. Enter Factory Settings (code 000000), find “ENC Dir”, toggle to “REV”, save, reboot. Update V7.5BT flipped default encoder polarity for some boards [Elektroda, B7010, post #19451284]
Edge case: unit boots, audio silent—what’s the cause?
Flashing an image compiled without the correct radio-DSP table mutes PA8173 output. Re-flash a dump containing “PA_7388” block or solder new 7388-CB tuner IC [Elektroda, Arshaadjobraj, post #19594367]
How do I safely reflash with a programmer?
  1. Disconnect car battery; clip 3.3 V CH341A to 25L6406E pins. 2. Erase, then write verified 8 MB dump; verify checksum. 3. Re-solder or unplug clip, reconnect battery, power on [Service Guide v2].
Can I change or add startup logos (e.g., ISUZU, Subaru)?
Only by editing the packed resource section and re-packing to .img. No public packer exists, so custom logos require factory tool access or JTAG RAM patching [Elektroda, Noteg, post #19304765]
Is mirror-link supported on Android 11 phones?
Only firmware with CMLPlay ≥ 7.0 supports AOA-mirroring. Units built after 2020-10-26 (MCU V129.18 or newer) succeed on 78 % of tested Android 11 devices [XDA Survey, 2022].
