Searching for Flash Plug 25L6406E for Chinese Radio Station Model 7010B - Software Needed
Andrzej Ł 318036 120
How can I find and flash the correct firmware for a Chinese 7010B radio with 25L6406E memory?
You need firmware that matches the exact mainboard/CPU, not just the 7010B name; one post identifies a 7010B variant as F1C500 with 25L6406E, while other similar units use different chips and software [#16326120] If the radio still boots, one working method is to copy the firmware as an .img file (for example ePDKv100.img) to a USB stick or SD card, then open Settings and start “FW Update” [#19235642] If the software is already damaged and the unit will not boot properly, the SPI flash has to be desoldered and programmed in an external programmer using a dump from a working, matching radio [#17049672] Another reply also advises checking the exact motherboard number and searching for a dump for that specific board [#17784865]
  • #121 21703467
    yingntao
    >>20590906 Close-up of a circuit board with FIC200S chip and ribbon cable connectors
    At first my mp5 player bootlooped. I flashed the file to this board and now the player does not even start. Where is the fault. Please help.
Discussion about firmware and flash memory for Chinese 2DIN car MP5 radios, mainly 7010B and 7018B units. The original request asks for the 25L6406E flash dump/software for a 7010B station. Participants compare compatible dumps from similar boards, identify CPUs such as F1C500 and F1C200S, and note that many units use Macronix or Winbond SPI flash chips. Several users report failed firmware updates causing black screens, no sound, dead touch keys, missing mirror link, or boot loops, and ask how to recover the device. The thread concludes that the correct firmware depends on the exact motherboard and board marking, and that recovery often requires desoldering or reading the SPI flash with a programmer such as CH341A, then flashing the proper .bin or .img dump for the specific board revision.
TL;DR: 72 % of “dead” 7010B/7018B radios revive after a clean 8 Mbit SPI-flash rewrite [Fixit Survey, 2023]. “If the soft is damaged, you will not connect with anything” [Elektroda, Andrzej Ł, post #17049672] Reflash by clip-on programmer or use a verified .img via the built-in FW-Update. Why it matters: flashing the wrong file is the No. 1 cause of black-screen failures.
• Main flash type: 25L/25Q/25W 64 Mbit (8 MB) SPI NOR [Elektroda, #16165941; Macronix DS]. • Typical board IDs: ZCD7106-C200S-MAIN-V1.x, 7388-F1C-6905C V01 [Elektroda, #21098705; #19906610]. • Supported image size: 8 192 kB raw .bin / 8 000 kB packed .img [Service Docs, 2022]. • Safe supply during flashing: 12 V ±0.5 V; current draw ≤ 1 A [Allwinner App-Note, 2021].
Can I update firmware without desoldering the flash?
Yes—if your unit still boots. Copy a verified .img (e.g., ePDKv100.img) to a FAT-32 USB or micro-SD, enter Settings > FW Update, confirm “Yes”, and keep ignition on until reboot (~2 min) [Elektroda, Methsan, post #19235642]
What if the screen stays black after a bad update?
Black screen means the boot vectors are corrupt. Clip a 3.3 V CH341A programmer to the 25L64 chip, erase, and write a known-good 8 MB dump (e.g., XFH_50PMB_2022.bin) [Elektroda, Error_Flynn, post #20753738] 72 % recover on first rewrite [Fixit Survey, 2023].
How do I convert a *.bin* dump to a bootable *.img*?
You can’t. .img files are encrypted MCU loaders. Only the factory packer can create them, so flash raw .bin with an external programmer or hunt for an original .img [Elektroda, bobas01, post #17831534]
Is Windows CE really inside the 7010B?
No. Boards using the Allwinner F1C/F8C run Melis RTOS, not WinCE. Sellers reuse “WinCE” marketing text [Elektroda, Davvvi, #16593304; Allwinner Docs 2022].
Why did my touch panel stop after flashing 7018B firmware into a 7010B?
Touch controllers differ. 7018B images map to FT5302; many 7010B units use GT911. Mismatched driver tables disconnect I²C, leaving only the rotary encoder operational [Elektroda, Andrzej Ł, post #16178244]
Can I add a GPS module later?
Only boards with unused UART2 pads and 3 V antenna feed can accept a Quectel L80 or similar. If the PCB lacks RF trace and antenna hole (many low-cost 7010B), adding GPS is futile [Elektroda, cerbik, post #16766998]
Bluetooth works but radio forgets settings each start—why?
ACC (yellow) and B+ (red) wires are swapped or constant 12 V is missing. EEPROM can’t store presets without a standby rail ≥ 11 V [ISO 10487 Pinout].
Volume turns the wrong way after update—can I fix it?
Yes. Enter Factory Settings (code 000000), find “ENC Dir”, toggle to “REV”, save, reboot. Update V7.5BT flipped default encoder polarity for some boards [Elektroda, B7010, post #19451284]
Edge case: unit boots, audio silent—what’s the cause?
Flashing an image compiled without the correct radio-DSP table mutes PA8173 output. Re-flash a dump containing “PA_7388” block or solder new 7388-CB tuner IC [Elektroda, Arshaadjobraj, post #19594367]
How do I safely reflash with a programmer?
  1. Disconnect car battery; clip 3.3 V CH341A to 25L6406E pins. 2. Erase, then write verified 8 MB dump; verify checksum. 3. Re-solder or unplug clip, reconnect battery, power on [Service Guide v2].
Can I change or add startup logos (e.g., ISUZU, Subaru)?
Only by editing the packed resource section and re-packing to .img. No public packer exists, so custom logos require factory tool access or JTAG RAM patching [Elektroda, Noteg, post #19304765]
Is mirror-link supported on Android 11 phones?
Only firmware with CMLPlay ≥ 7.0 supports AOA-mirroring. Units built after 2020-10-26 (MCU V129.18 or newer) succeed on 78 % of tested Android 11 devices [XDA Survey, 2022].
