Satel Perfecta Alarm Integration: Controlling Roller Shutters (6x0.5mm2) with PIR Detectors
tomsg 10380 8
  • #1 17210962
    tomsg
    Rate: 11
    During the renovation, I bought the Satel Perfecta set. I ran 6x0.5mm2 wires to six PIR detectors. I read that you can control the roller shutters, but nowhere have the detailed connection instructions. I am only interested in closing all blinds at once when leaving and opening when entering the house. Following the advice of the alarm seller, I ran the same 6x0.5mm2 cable from the control panel to the roller shutter boxes. The seller also informed me about the purchase of a roller shutter with a relay or placing the relay in a box. The problem is now when no roller shutter seller knows what an alarm relay and a roller shutter with a relay are, and a specialist in assembling the control panel does not know how to connect the blinds. The control panel has 8 inputs and 4 outputs. Please help what relays and where to install, having a 6x0.5mm2 cable connected to the roller shutter boxes.
  • #2 17211084
    michualex
    Help: 82
    Rate: 134
    Universal wired flush roller shutter controller, type: SRP-05 / 12-24V, exta Zamel
    of course, connect it divinely and program it :)
    what the perfection is
    program the output 3 as Controllable and set the time, e.g. 2 seconds, and assign a key to control e.g. 1 - after disarming the alarm, you enter 1 + # and the shutters open.
    program the output 4 as above with the key, e.g. 0 or as an exit delay indicator - it will automatically close the blinds after entering the code, but you will not control the manual closing from the keyboard (I guess I'm not sure how to check, but the control probably only applies to outputs with the function No. 15 with controllable)
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #3 17212103
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    1.
    tomsg wrote:
    During the renovation, I bought a set
    2.
    tomsg wrote:
    Perfecta satellite
    3.
    tomsg wrote:
    As advised by the alarm vendor
    4.
    1. error number 1, the equipment is bought by the installer and takes responsibility for it, buying yourself is asking for trouble
    2. error no. 2 A control panel that is not suitable for controlling roller shutters.
    3. mistake # 3 the seller is not the right person to give such advice.
    4. mistake no. 4 choosing a "specialist" surely an electrician and a plumber and in his spare time a bricklayer, plasterer, acrobat.
  • #4 17212376
    djlukas
    Help: 94
    Rate: 266
    Not true.
    I often use perfect to control roller blinds centrally. The matter of a well planned installation and programming of the control panel.
  • #5 17212463
    kood
    Help: 259
    Rate: 443
    So what about this ?? Probably if someone insisted it would close or open the blinds.
    A well-planned system is the first thing to choose the right control panel, and if someone wants to control the roller shutters, when choosing Satellite, he does not use perfecte or verse, but an integre created for this purpose.
  • #6 17212608
    luk9753
    Help: 63
    Rate: 147
    Provided that there is an appropriate shutter control time relay, you can control any control unit, but only the integrated can control the roller shutters directly.
  • #7 17212635
    tomsg
    Rate: 11
    Thank you very much for the information. So I understand that the 6x0.5mm cable led to the box even at a distance of 20m is ok?
    The relay you specified is for 12-24V, the control panel also, and in the boxes for the blinds, apart from the 6x0.5mm cable, I have 3x2.5mm with 230V voltage. From the roller shutter box to the switch by the window 4x1.5mm2. So the shutter will run on 230V, only the control will be 12-24V from the control panel?
  • #8 17215985
    luk9753
    Help: 63
    Rate: 147
    Something like this, you have to put two relays into the box with a 12VDC coil and 230V working contacts (see relpol offer) and give impulses to the roller shutter relay (e.g. str-1 f & f), although if you do not build a central control, I recommend adding a pair of PLN- s for ROW-01, they work on the supli so you gain the ability to remotely control from the application level and set schedules.
  • Integra is the better choice for shutter control
    #9 17216027
    djlukas
    Help: 94
    Rate: 266
    I will not overpay just because Integra has this function as I can get the same result a little cheaper using my brain.
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues Collection of topics
    Outputs (programmable and not only) of control panels
    How the control panel alarm outputs work
    Connecting any detector to any alarm control panel - guide
    How to connect the siren to the alarm control panel - guide
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
The discussion revolves around integrating the Satel Perfecta alarm system with roller shutters using 6x0.5mm2 wiring connected to PIR detectors. Users seek guidance on controlling the shutters to open when entering and close when exiting the house. Recommendations include using a universal wired flush roller shutter controller (SRP-05) and programming the control panel outputs for shutter operation. Some users emphasize the importance of selecting the right control panel and relay for effective integration, suggesting the use of relays with 12-24V coils and 230V working contacts. The conversation highlights the need for proper planning and installation to achieve desired functionality.
