Connecting 2 Motion Detectors to 3 LED Garden Lamps: Wiring Diagram & Activation Guide
tomek7779 12453 17
How can I wire two motion detectors at opposite ends of a path so either detector activates three 230 V LED garden lamps?
Wire both 230 V detectors to the same supply and connect their OUT terminals together to control the three lamps; the detectors have L, N, and OUT terminals. [#16172307] Because the detectors switch the circuit rather than independently supplying current, simultaneous activation does not create a short circuit and may simply extend the lighting time. [#16174245] This arrangement switches all three lamps together, regardless of which detector detects motion. [#16176792] Ordinary 230 V motion detectors generally cannot reliably distinguish people from animals; animal-resistant alarm-system detectors exist, but they can cost about 700 PLN each. [#16174262]
  • #1 16172269
    tomek7779
    Rate: 87
    Hello, I am asking for help in connecting 2 pcs of motion detectors. At the beginning and end, and between them 3 led garden lamps. I want the detector to activate these lamps from both sides.
    I am asking for some diagram how to connect it.
  • #2 16172307
    brofran
    Help: 650
    Rate: 1407
    The detector has 3 terminals L + N + OUT. You connect the outputs together and to the LED.
  • #4 16172380
    krzysztofh
    Help: 101
    Rate: 937
    A colleague does not write anything about how the motion detectors are powered (with what voltage).
    LED garden lamps are usually powered by a lower voltage. In any case, we know nothing about it.
  • #5 16174108
    tomek7779
    Rate: 87
    lamps will be powered by 230v the first detector at the entrance to the so-called furka and the second detector at the exit from the house and I would like that on both sides if someone approaches these lamps
  • #6 16174112
    krzysztofh
    Help: 101
    Rate: 937
    The detectors are also powered by 230V AC? By the way, write using the rules of spelling because admin will warn you.
  • #7 16174116
    tomek7779
    Rate: 87
    ai still one according to the above scheme given by colleague atomic99 what will be like two detectors work one after the other ??
  • #8 16174118
    atomic99
    Help: 171
    Rate: 338
    The light will just stay on longer. And what would it be?
  • #9 16174194
    tomek7779
    Rate: 87
    I don't know, I thought that when both detectors give phase, some short circuit will happen ??
    second matter colleagues, maybe someone will tell me which detectors I should buy so that they do not work on animals I know that they can be expensive but what nothing on the net I can not find
    atomic99
    Help: 171
    Rate: 338
    Well, as if a short circuit will do as it goes from one power source.
    The second detector will not give a "second current" but will activate the circuit for a longer time. Because the detectors by themselves do not give "current" but close the circuit.
  • #11 16174254
    tomek7779
    Rate: 87
    OK OK so just to confirm how yes this connection in the attached picture will work without a problem ?? Connecting 2 Motion Detectors to 3 LED Garden Lamps: Wiring Diagram & Activation Guide
    only now watch case what ???
    krzysztofh
    Help: 101
    Rate: 937
    Normal motion detectors powered by 230V AC do not have sophisticated optics and you will not find anything in this segment. Animal-resistant detectors must be sought in the segment of detectors dedicated to alarm systems. If you assume that it is to work outside it will be very expensive.
    I know ROKONET detectors resistant to animals and plant movements, but the cost of such a detector is about 700 PLN.
    The only question is whether the work of these detectors without false alarms (in this case lighting up the lamps) is so important.
  • #13 16176531
    tomek7779
    Rate: 87
    Hello, I care about the detector that will not work on animals
    Maybe something else you can think of?
  • #14 16176571
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Depends what animals ...
    It can't be done, because the current technology does not allow the detector to distinguish man from bear ;)
  • Series relay wiring enables independent lamp activation
    #15 16176726
  • Two relays needed for independent detector-controlled lamps
    #16 16176785
    tomek7779
    Rate: 87
    atom1477 wrote:
    Unfortunately not. Here, each time three lamps will light up at once.
    To get the action you want, you need to give, for example, 2 relays with 230V coils. Alternatively, if the bulbs have a specific power and will not be exchanged for others, you can try to choose some relays for a lower voltage and connect them in series with the bulbs.
    Well, I mean that they all light up at once only from one end or from the other, i.e. from one detector once from the other ??
    will such connection be good ??
  • #18 16176812
    tomek7779
    Rate: 87
    atom1477 wrote:
    Hm, I thought the detector would fire 2 lamps from its end.
    But if it is always to light all 3, then this scheme is good.
    thank you very much
    In that case, I consider the topic finished thank you all for help and attention
The discussion revolves around connecting two motion detectors to activate three LED garden lamps powered by 230V AC. Users seek guidance on wiring diagrams and the functionality of the setup. The motion detectors, which also operate on 230V AC, can be connected in such a way that they activate the lamps from both ends. Concerns about potential short circuits when both detectors are triggered simultaneously are addressed, clarifying that the detectors close the circuit rather than provide current. Recommendations for animal-resistant detectors are provided, with ROKONET mentioned as a suitable brand, albeit at a high cost. The conversation concludes with confirmation that the proposed wiring scheme will work as intended, lighting all three lamps when either detector is activated.
