8GB 2Rx4 PC3L-10600R-9-10-E1: Troubleshooting Server Memory & Compatibility Issues
skorakora 9228 7
  • #1 17169966
    skorakora
    Rate: 25
    I found an 8GB RAM memory (I used to buy it from a guest there)
    Because I needed an additional 8GB of RAM, I added III ... it didn't move
    The computer does not turn on
    Entering the memory model, I found only a similar server one
    On the memory it says:
    8GB 2Rx4 PC3L - 10600R - 9 -10 - E1
    HMT31GR7BFR4A - HS T2 AE
  • #2 17169977
    dt1
    Admin of Computers group
    Help: 7320
    Rate: 8306
    Welcome. by searching by model you can find out that this is ECC memory, so it is not suitable for ordinary consumer discs. In the designation 10600R - the letter R stands for Registered type memory. So it's ECC Registered memory.
    For typical home boards you need memory without ECC and unbuffered (Unbuffered / Unregistered) - usually they do not have additional markings. Check the specifications of your motherboard which memory it supports.
  • #3 17169982
    skorakora
    Rate: 25
    Normal ones like I'd like to put in a typical computer (2X 4GB DDR3 are included)
    So probably will not support (HDD diode flashes cyclically as I add this memory)
    EDIT:
    So this is sewer memory from what I understood
    the motherboard is Gigabyte GA-970A-DS3P FX
  • #4 17169997
    Robert B
    Help: 2027
    Rate: 1412
    skorakora wrote:
    flashing cyclically HDD diode as I add this memory
    Are you inserting modules on the computer turned on ???
  • #5 17170001
    dt1
    Help: 7320
    Rate: 8306
    Let's hope not :)
    skorakora wrote:
    Normal, like I'd like to put in a typical computer
    Ordinary DDR3, but not ECC, which you are trying to add.
    Let's assume that yes, people associate the ECC RAM mechanism only with servers. It can therefore be assumed in a simplified way.
  • #6 17170857
    skorakora
    Rate: 25
    Yes, I add memory on a turned off computer after starting the only thing you do is flash the LED cyclically
    2 I put 2X memory there
    DDR3 4GB PC3 - 10600 DIMM
    PS: I mean that the computer does not turn on when I have this 8GB bone added, because without it the computer works normally
  • #7 17171183
    Kasek21
    Help: 4981
    Rate: 3549
    This is it, right?
    This is ECC memory and the disc does not support it.
  • #8 17171752
    skorakora
    Rate: 25
    Yes, that's right.
    Thanks for the help
The discussion revolves around troubleshooting compatibility issues with an 8GB RAM module labeled as 8GB 2Rx4 PC3L-10600R-9-10-E1, which is identified as ECC Registered memory. The user attempted to add this memory to a Gigabyte GA-970A-DS3P FX motherboard, which does not support ECC memory, leading to the computer failing to power on. Responses clarify that typical consumer motherboards require unbuffered (unregistered) DDR3 memory without ECC. The user confirmed that the computer operates normally without the ECC RAM installed.
