Iveco Stralis Astronic Tachometer Maxed, Water Mode Red, Error Eurotronic B4 VCM, ECM, SRC
cioko605 9141 1
  • #1 16174007
    cioko605
    Hello, I have a problem with Iveco Stralis, the tachometer went to the max and the water mode is red, error eurotronic b4 vcm, ecm, retarder, src, does not start, after a while the immobilizer pops up to give the code, please give a hint, urgent, the car is in the parking lot. emeil cioko605(_at_)o2.pl
  • #2 16190431
    Przemcio1993
    Rate: 48
    Buddy, I don't know if it will help you now, but try to unplug the NOx sensor. It is from the exhaust and its driver is a flat plate attached to the battery switch. From this shallow you need to drink the ankle. Because from what you write, it makes a mess on CAN and therefore I prefer immo
