Iveco 3.0 HPT 2006 - Injection Rate Cuts Off, Error Codes 0085 005c 000b, ABS & Airbag Light
phupawelkulesza 27246 16
Why does my Iveco 3.0 HPT cut power around 80–90 km/h under load, and what might error codes 0085, 005c, and 000b mean when the ABS, brake, and airbag lights are on?
The reported fix was a leaking vacuum line to the PWM turbo solenoid, which caused the turbine/boost control to work incorrectly and produced the same power cut at 60–90 km/h under load; replacing that hose solved the problem [#19999149] The fact that the turbo actuator lever/rod did not move after switching on the ignition also points to a vacuum-control issue rather than the fuel-rail parts that had already been replaced [#17069131][#17071014] One earlier suggestion was the common-rail pump pressure regulator, because its micro-mesh can clog and limit fuel pressure under higher demand, but replacing it did not help in this case [#17066443][#17068073] Another reply said code group 85 may indicate an EGR valve fault, but the thread did not confirm that as the actual cause [#17066443]
  • #1 16918956
    phupawelkulesza
    Rate: 17
    Hello!
    I have a problem with Iveco 3.0 HPT 2006
    While driving, usually under a higher load, the injection rate flashes about 80-90 km. Blinks about 3 seconds, cuts off the power for a while and then it's ok. Sometimes the car will run empty 200-300km and nothing happens. I note that when accelerating the car even with the weight everything is ok, the problem starts when the car reaches a speed of about 80-90 km / h. but not always. Lottery in general.
    Replaced fuel filter, cleaned pressure sensor on the rail.
    Please, help me read errors from my computer:
    0085 005c 000b
    ABS, red brake light and airbag light up on the board.
  • #2 16967481
    phupawelkulesza
    Rate: 17
    I will add that this week I checked the injection, all good ..
  • #3 16993022
    vvaldek
    Help: 81
    Rate: 386
    Iveco may still have a fuel tank filter around the frame
  • #4 16996554
    phupawelkulesza
    Rate: 17
    I have already checked the filter, the pump in the frame is also replaced .. I really have no idea what could be .. The car has a light injection - almost no flashing, loaded, a big wind or even empty uphill the injection starts flashing about 4 sec cuts power and goes again ( i.e. with high fuel consumption) Please write if something comes to someone's head ..
  • #5 16996808
    vvaldek
    Help: 81
    Rate: 386
    make a transfer inquiry
  • #6 16996814
    phupawelkulesza
    Rate: 17
    attempt made, good transfers
  • #7 17037296
    phupawelkulesza
    Rate: 17
    Maybe someone will give me an idea ??
  • #8 17064498
    phupawelkulesza
    Rate: 17
    If there is anyone willing from the province Mazowieckie I can put a car,
    I will add that now at outside temperatures - 15 has worsened significantly, injection during driving 60-80 km / h can flash all the time and cut off power. When accelerating with a load is approx.
  • #9 17066443
    Hart3
    Help: 100
    Rate: 478
    phupawel ... in your place I would replace the regulator - (4) on the CR pump. You have a problem with the fuel system and the regulator is responsible for the pressure obtained. It has in its structure a micro mesh that likes to clog, which with greater demand for fuel results in the above symptoms. In diagnostics, the error in group 85 says about EGR valve failure if I associate it correctly.
    • Iveco 3.0 HPT 2006 - Injection Rate Cuts Off, Error Codes 0085 005c 000b, ABS & Airbag Light regulator CR.JPG (36.75 KB) You must be logged in to download this attachment.
    • Iveco 3.0 HPT 2006 - Injection Rate Cuts Off, Error Codes 0085 005c 000b, ABS & Airbag Light Pompa CR.JPG (55.54 KB) You must be logged in to download this attachment.
  • #10 17068073
    phupawelkulesza
    Rate: 17
    The regulator on the CR pump replaced - nothing helped .. Hands fall down
  • #11 17068428
    pp_pablo
    Help: 93
    Rate: 403
    The pump on the frame you put on the original or replacement. What fuel filter?
    Or maybe a valve / sensor on a strip ??
  • #12 17069131
    phupawelkulesza
    Rate: 17
    Yesterday, in addition to replacing the regulator on the pump, I replaced the fuel filter and the sensor on the intake manifold again.
    The pressure sensor on the rail was replaced earlier (no change), the pump in the frame is new and works well.
    We noticed that before the injection starts flashing, the car accelerates a lot less and the lever in the pear after turning the ignition does not rise ..
  • #13 17071014
    Hart3
    Help: 100
    Rate: 478
    I don't know what it means by you pear, I guess it's about regulating the turbine. To regulate the vacuum is a PWM controlled valve with EDC. There is a decent diagnosis.
  • #14 17071654
    phupawelkulesza
    Rate: 17
    The PWM controlled valve with EDC was replaced earlier
  • #15 17072984
    Hart3
    Help: 100
    Rate: 478
    Look how many elements have been replaced, isn't it easier to do a proper diagnosis and not predict the grounds.
  • #16 19389081
    Laweciarz1
    Buddy, I have the same problem, I have 3.0 170koni and I don't know what is, or maybe you managed to diagnose the fault, I will be grateful if you would write what was
  • #17 19999149
    zigfridsgusevs
    Hi!
    I have the same problem! Many parts changed. I figured out that the turbine is not working correctly. Problem solved by putting a new vacuum line to the pwm turbine solenoid. It's a little leaking.
    It was a nightmare to find it out :)
✨ The discussion revolves around issues experienced with an Iveco 3.0 HPT 2006 vehicle, specifically related to the injection system, which intermittently cuts off power while driving at speeds of 80-90 km/h. The user reports error codes 0085, 005c, and 000b, alongside illuminated ABS and airbag lights. Various components have been replaced, including the fuel filter, pressure sensor, and regulator on the common rail (CR) pump, but the problem persists. Suggestions from other users include checking the fuel tank filter, replacing the regulator, and diagnosing the vacuum line to the turbine solenoid. One user resolved a similar issue by replacing a leaking vacuum line. The discussion highlights the complexity of diagnosing fuel system problems and the importance of thorough diagnostics.
TL;DR: In this Iveco 3.0 HPT case, 1/1 confirmed fix was a leaking vacuum line; "Problem solved by putting a new vacuum line to the PWM turbine solenoid." [Elektroda, zigfridsgusevs, post #19999149]
Why it matters: This FAQ helps Iveco 3.0 HPT owners diagnose injection cut-outs and warning lights without expensive guesswork.
Quick-Facts
What do error codes 0085, 005c, and 000b point to here?
In this thread, group “85” was read as an EGR valve-related fault. That insight directed checks toward air and vacuum controls. The discussion focused on boost control and vacuum regulation rather than injectors alone. Treat these codes as starting points for diagnosis, not final proof. Verify live data and actuator control before replacing parts. “You have a problem with the fuel system,” one expert noted, tying pressure control and EGR/boost to the symptom. [Elektroda, Hart3, post #17066443]
How was the injection cut-out finally fixed in this case?
A member resolved it by replacing a leaking vacuum line feeding the PWM-controlled turbine (turbo) solenoid. The leak reduced boost control authority under load and triggered the injection warning with power loss. Quote: “Problem solved by putting a new vacuum line to the pwm turbine solenoid.” This single change ended the intermittent cut-outs after many part swaps. [Elektroda, zigfridsgusevs, post #19999149]
Why does the problem appear around 80–90 km/h under load?
At that speed, aerodynamic load and modest grades raise boost and fuel demands. The poster reported the injection light flashing for about three seconds with a brief power cut near 80–90 km/h. That pattern suggests control instability from vacuum or boost regulation, not constant fuel starvation. Checking the vacuum line and PWM turbo solenoid is warranted before deeper fuel system work. [Elektroda, phupawelkulesza, post #16918956]
Does cold weather make the symptom worse?
Yes. The owner noted significant worsening at about −15°C, with frequent flashing between 60–80 km/h. Cold can stiffen rubber lines and reveal minor vacuum leaks, aggravating boost control. Inspect brittle hoses and connections during winter conditions. Replace any hardened or cracked vacuum tubing and recheck driveability before replacing major components. [Elektroda, phupawelkulesza, post #17064498]
Which parts were replaced but didn’t cure it?
Documented replacements included: CR pump regulator, fuel filter, intake manifold sensor, common-rail pressure sensor, and the frame-mounted pump. Despite these, the fault persisted until the vacuum line fix. Statistic: at least five components were changed before the root cause was found. Prioritize testing over swapping to save time and cost. [Elektroda, phupawelkulesza, post #17069131]
Is the common-rail (CR) pump regulator the culprit here?
Not in this vehicle. The owner replaced the CR pump regulator with no improvement. That result shifts attention to control-side issues such as vacuum plumbing and the PWM turbo solenoid. Always corroborate with commanded versus actual rail pressure logs before calling a regulator bad. Replace only after confirming inability to track pressure targets under load. [Elektroda, phupawelkulesza, post #17068073]
What does the “PWM turbine solenoid” do on this Iveco?
It modulates vacuum to the turbo actuator using a PWM signal from the engine controller (EDC). That vacuum controls turbine vane or wastegate position, governing boost. A leak upstream of the solenoid reduces available vacuum, causing underboost and protective power cuts. “To regulate the vacuum is a PWM controlled valve with EDC,” a contributor explained. [Elektroda, Hart3, post #17071014]
What is the “pear” the owner mentions?
In this context, “pear” refers to the turbo’s vacuum actuator that moves with applied vacuum. If the lever does not rise at key-on, vacuum supply or control is suspect. Check the actuator for smooth travel and verify the vacuum line and PWM solenoid function. Restore proper vacuum before replacing actuators or turbos. [Elektroda, phupawelkulesza, post #17069131]
Quick 3-step: how do I check for the vacuum-line leak to the turbo solenoid?
  1. Inspect all vacuum hoses to the PWM turbine solenoid for cracks, loose fits, or oil-softened sections.
  2. Replace suspect hose with fresh vacuum line of correct diameter and secure with clamps.
  3. Road-test under load to confirm the injection light no longer flashes or cuts power. “Problem solved by putting a new vacuum line...” [Elektroda, zigfridsgusevs, post #19999149]
What did “make a transfer inquiry” mean in the thread?
The member suggested checking fuel transfer/flow. The owner replied the “attempt made, good transfers,” indicating fuel delivery tests passed. That result de-emphasized the low-pressure fuel side and redirected attention to boost and vacuum control. Use flow checks to rule out supply issues before moving on. [Elektroda, phupawelkulesza, post #16996814]
Does replacing the frame-mounted pump help?
Not here. The frame pump was new and reported to work well, yet the symptom persisted. If a new pump does not change rail pressure stability or the flashing injection light, inspect control-side elements like vacuum lines, solenoid valves, and boost leaks. Avoid repeated pump swaps without data logs. [Elektroda, phupawelkulesza, post #17069131]
What’s the smartest order of diagnosis to avoid parts cannoning?
Start with code readout, then log boost and rail pressure versus targets under load. Smoke-test or visually check all vacuum lines and the PWM turbo solenoid before replacing hardware. An expert cautioned: “Look how many elements have been replaced, isn’t it easier to do a proper diagnosis.” Follow a test-first approach. [Elektroda, Hart3, post #17072984]
