IBO BETA 25-40 / 180 Pump: Issues with Power Consumption and Tech ST-431N Controller Settings
pszczolap 7161 6
  • Pump power doubled from 23 W to 45 W on first gear
    #1 16176662
    pszczolap
    Rate: 64
    For several months I have had a BETA 25-40 / 180 pump in my installation
    It is connected to the Tech ST-431N controller.
    They pump the water from the buffer tank and after passing through the 3D valve feed water to the house - to radiators and to the floor.
    The pump until yesterday went perfectly on the 1st gear - it consumed about 23W.
    has been charging 45W since yesterday in gear 1. Nothing can change the settings, disconnection from the power supply for the whole night also did not help.
    The only thing that reduces speed is closing the valve in front of the pump.
    But this is not the way to control pump power.
    How can you reset this pump so that it changes your thinking?
  • #2 16189718
    W0jtek92
    Help: 469
    Rate: 1258
    Hello, are all filters clean? Maybe there is a non-return valve that burns stupid?
  • #3 16189746
    pszczolap
    Rate: 64
    I was also just thinking about filters and unscrewed the mesh one but it was clean.
    I switched the pump to Auto and also went to max, i.e. 45W. So before the pump and behind the pump I closed the ball valves and set it to 22W.
    But why has she been walking normally in normal 1st gear so far?
  • #4 16190002
    W0jtek92
    Help: 469
    Rate: 1258
    It's hard to create, something is on, can you ask for some photos of this installation?
  • Resetting the pump’s self-learning memory after valve closure
    #5 16190015
    pszczolap
    Rate: 64
    Standard CO installation.
    The water goes from the 1000l buffer and goes to the 3D valve, where it is mixed up with the return water. Then valve, filter and pump. Then the valve and then to the radiators and floor.
    Until now, everything worked fine on this pump.
    When I close the valves before and after the pump, it's OK too.
    The main question is: How to reset the pump memory because it is supposedly self-learning?
  • #6 16190230
    ls_77
    Help: 500
    Rate: 947
    pszczolap wrote:
    ... I closed the ball valves before and after the pump ...
    Do not "stop" on the ball valves. They work 0-1 (open-close). With slight choking, it can "flush" the ball seals and later the valve will not close.
    As for the pump is a strange thing - but I will not say it here - I do not like electronic pumps :|
  • #7 16254987
    pszczolap
    Rate: 64
    The pump is affected only by closed valves - it is a pity that it is not known to reset it so that it will forget about the current settings :(
The discussion revolves around issues with the IBO BETA 25-40 / 180 pump connected to a Tech ST-431N controller. The user reports an unexpected increase in power consumption from 23W to 45W while operating in gear 1, despite attempts to reset the system and clean filters. The installation involves a standard central heating setup with a buffer tank and a 3D valve. Users suggest that closed valves may be affecting the pump's performance and express concerns about the pump's self-learning feature, which may need to be reset to restore normal operation.
