Fiat Punto II FL 1.2 / 8V - Which starter to choose and what to follow
5907 18
Which starter model fits a 2003 Fiat Punto II FL 1.2 8V, and how can I identify the correct replacement without removing the old starter first?
The correct starter for this car is the DENSO C132, part number 63101018, rated at 0.8 kW [#16186323] If you are choosing a used replacement, match the OEM number and check the mounting and bendix tooth count, because Fiat starters can differ by these details [#16180628] The thread also notes that other suggestions like stronger GP/Hitachi units were discussed, but the exact identification for this car was confirmed by reading the starter nameplate on the vehicle [#16186323]
  • #1 16180406
  • #2 16180512
    kkknc
    Help: 1915
    Rate: 6709
    There were 2 before the MM or Bosch lift with a power of 800 or 900W. I don't know after the lift. The effect was that at -25 they did not ignite. If you are going to combine it better take the stronger one. Will be a good base. Only places not too rich.
  • #3 16180572
  • #4 16180617
    Eidems
    Help: 83
    Rate: 253
    I will connect to the topic, I have punto 2 before the lift, and at -15 the car had a hard time to start, but when it starts, it starts all day without any problems. What type of starter can I have? Born in 2000.
  • #5 16180628
    bizon_126
    Help: 108
    Rate: 566
    I have the same at 1.2 16V
    Today I fired from the tractor and it turns so poorly and made 1.5 years ago
    From what I read someone was installing the grande punto supposedly stronger
    The starters differ mainly in the number of teeth on the bendix and the power
    It would be good to read the number from the old one and then look for it
  • #6 16180635
    Eidems
    Help: 83
    Rate: 253
    For me, the problem with the battery is replaced with a new one 2 weeks ago. There is a thread on the Fiat forum, the guy probably mentioned everything he could and the problem still exists and I suspect that the starter is to blame and there are also opinions about the assembly with GP ;)
  • #7 16180715
    bizon_126
    Help: 108
    Rate: 566
    MM / denso starters do not have a planetary gear and hence such wonders in the cold with a 44Ah battery
    When I had a seicento, I put on the 62Ah battery, it fired without a hitch
    And since he drove a lot on the road, he recharged it anyway
  • #8 16180726
    Eidems
    Help: 83
    Rate: 253
    Okay, so what's the "antidote" to normal car starting? Replacing the starter with the GP one? A friend wrote that he was firing the battery from the tractor and so weak ...
  • #9 16180749
    kkknc
    Help: 1915
    Rate: 6709
    The ones that went to Scandinavia had 1.5kW. And it worked. You can always take a stronger one and make a hybrid. The head and the Będnix must match. And the rotor and stator more powerful. At home, like a few years ago, it was a stronger winter, unfortunately I had to give a farelka under the bowl for 15 minutes to heat the oil and fire. Later I put on the parking heater, with the exhaust pipe pointing towards the oil pan. And he fired. That's why I gave up on a more powerful starter.
    A larger or a second battery does nothing. Thick oil does not allow the engine to start up to the appropriate speed due to insufficient power of the starter.
  • #10 16180766
    andrzej20001
    Help: 1578
    Rate: 6669
    S114-903 or 903A Hitachi with gearbox. 80 PLN for all ...
  • #11 16180823
  • #12 16180854
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Novile wrote:
    I wonder what the Ruthenians drive in Vladivostok or Arkhangelsk?
    Either they don't put out the cars on the road or they use Webast with "in the morning".
    Secondly, this morning at my place -26'C and both cars standing outside dusted off as needed.
    Then the heater comes into operation and the car has a normal temperature after 5 minutes.
    Yes S114-903 has 3 brushes, including 2 plus ones, and a brush holder with a third brush, SBH 4006.
  • #13 16180858
    Eidems
    Help: 83
    Rate: 253
    Also fiats? So this starter will be the best choice ;) ?
  • #14 16180869
    Help: 1405
    Rate: 6430
    If you have a functional starter and battery, it will start at - 30 'C.
  • #16 16180898
    Eidems
    Help: 83
    Rate: 253
    Above you have the opinion that not necessarily, these starters are too weak.
  • #17 16180914
  • #18 16180915
    Eidems
    Help: 83
    Rate: 253
    andrzej20001 wrote:
    https://as-pl.com/c/all/s114-903
    The S114 has 4 brushes and a rotor like Opel's 1.7 cdti and is as strong as ... see in the parts. 1.4kw
    In the description, it has 0.8kw
  • #19 16186323
The discussion revolves around the starter motor issue in a 2003 Fiat Punto II FL 1.2 8V. The original poster seeks advice on identifying the correct starter model without disassembling the existing unit. Participants share experiences with various starter types, emphasizing the importance of matching specifications such as mounting, number of teeth, and power ratings. The DENSO C132 starter model 63101018, rated at 0.8kW, is confirmed as the correct part after the original poster investigates further. Users also discuss the performance of different starters in cold weather and suggest potential upgrades for better reliability.
