Opel Meriva A - Assistance - replacement of the angle sensor - calibration
saly 24498 14
After replacing the steering angle/torque sensor on an Opel Meriva A without ESP, does the power steering need calibration to start, and what should I check if I get C1500 "voltage out of range" immediately after replacement?
The sensor should be installed in its relaxed zero position, and calibration with a tester is the proper way to zero the angle and torque values in the controller; if it is fitted even slightly off or under pre-tension, the power steering may not start [#20899822][#20908065] Some users report that a correctly mounted sensor with no pre-load can work without calibration and should show a near-zero angle/force reading when the wheels are straight, but the mounting must be exact [#17449618][#20469750] If the fault changes to C1500 "voltage out of range" right after replacement and the assistance is still dead, the replacement sensor may be defective or not seated correctly [#21751802] With this setup, a used sensor is a lottery because wear or a bad unit can cause exactly this kind of problem [#21751802]
  • Used steering angle sensor likely faulty or uncalibrated
    #1 17449604
    saly
    Level 32  
    Help: 89
    Rate: 1003
    I have a question, I read a lot on the electrode, but I wanted to confirm whether after replacing the steering angle sensor, the power steering should start without calibrating the steering angle sensor. Is it necessary to calibrate after replacement so that the power steering starts? The car is without ESP.
    Before the exchange, I had a C1500 error with the description "Incorrect sensor signal". After replacing the steering angle sensor, I have a C1500 error with the description "Voltage out of range", the power steering does not start at all. Error right after running.
    The problem is that I have nothing to do to calibrate.
    I bought a used sensor and I suspect it was blown.
    szymitsu21
    Help: 343
    Rate: 1300
    If you mount it correctly, it should work even without calibration.
    See in the parameters the angle that is seen when the steering wheel is straight ahead.
    tomasz0703
    Help: 69
    Rate: 489
    It is not only about the angle but also the strength in NM
  • #4 17449670
    saly
    Level 32  
    Help: 89
    Rate: 1003
    Before starting, when the sensor tests the parameters, you can see how the force changes, as I tighten the steering wheels, the angle does not change. There is an error after boot and the parameters are already dead, they don't change.
    So the sensor is released.
    audic5
    Rate: 54
    hello, the torque and steering sensor must be perfectly mounted on the signs
  • #6 20469750
    saly
    Level 32  
    Help: 89
    Rate: 1003
    In fact, the sensor simply needs to be fitted perfectly, and no calibration is required. A correctly fitted sensor – without any pre-tension and secured in place during installation using the tool – will work correctly straight away. See the file below for instructions.
    VERSION WITHOUT ESP
    If you find this file helpful, please provide feedback by clicking ‘helpful’.
    • Meriva A Corsa B wspomaganie.png (323.19 KB) You must be logged in to download this attachment.
  • #7 20470554
    audic5
    Rate: 54
    hello, I never failed, the force of turning left or right was always different, it always calibrates kts bosch
  • Relax the force sensor before calibration
    #8 20470611
    saly
    Level 32  
    Help: 89
    Rate: 1003
    When you calibrate it, the force sensor must be slightly stretched anyway, otherwise you wouldn't calibrate how tight it would be. I had a sensor mounted in a state of stress of the force sensor, it did not want to pass calibration. And when everything is relaxed, it always goes without calibration.
    I have succeeded more than once. If you do not have a screwed steering wheel and nothing on the steering shaft is tightening, then I press the sensor and loosen the clip.
    Sometimes lifting the wheels helps.
  • Calibration is required after angle sensor replacement
    #9 20899822
    tomjey
    Rate: 94
    saly wrote:
    In fact, you need to install the sensor perfectly and calibration is not necessary.
    And that`s not true. The sensor has a pin that locks it in the starting position, but this is only a preliminary setting. Precise calibration is performed with a tester where the values of the angle and turning torque parameters are zeroed. These values are saved in the electronics in the controller. So what if we install the sensor perfectly (which is impossible due to its sensitivity) if the previous sensor could have been calibrated in a slightly changed position and there will be different values in the controller.
  • Torque sensor must be relaxed before calibration
    #10 20908065
    saly
    Level 32  
    Help: 89
    Rate: 1003
    I will agree with you that calibration will complete the whole. If the torque sensor is minimally misaligned then calibration cannot be done. The sensor needs to be relaxed and there is a pin for that.
    Maybe I misspoke that calibration is not necessary. With calibration the power steering works more optimally. I haven't installed it for a long time, but I remember that when I set the sensor right, the reading from the force sensor in the parameters was almost zero.
  • #11 21751640
    vokotibi
    Rate: 11
    I don't know which version of the Meriva this picture from post 6 is suitable for, but it is misleading. How is there supposed to be a lock for a straight steering wheel if it can't be mounted that way? Only calibration with a tester.
  • Angle sensor needs steering shaft loosened for installation
    #12 21751802
    enhanced
    Help: 963
    Rate: 883
    The power steering shaft in the legs has to be loosened, the sensor has to be fitted, as it will not go in otherwise than when the steering wheel is turned, and then the sensor has to be fitted again.
    It is not possible to insert the sensor simply.
    And buy the supposedly original one from Mexico, not the fake ones not much cheaper. At least that is what I have heard.
    Buying a used one is a lottery because it would have to be hardly used at all for the tracks not to wear out and it would work for a while.
  • #13 21753129
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    >>21751640 You will not calibrate a sensor inserted crookedly.
  • #14 21753231
    vokotibi
    Rate: 11
    Sorry, but maybe this drawing only applies to the version without ESP.
    In the version with ESP the sensor itself, the shaft in the column and the steering wheel has a cutter and it is not possible to fit this as or only as it fits, and on the straight with lock it does not fit.
  • #15 21754647
    saly
    Level 32  
    Help: 89
    Rate: 1003
    vokotibi wrote:
    Excuse me, but maybe this drawing only applies to the version without ESP
    In the first post it says that in the version without ESP.
Discussion about Opel Meriva A electric power steering after replacing the steering angle/torque sensor. The main issue is C1500 fault codes changing from “incorrect sensor signal” to “voltage out of range,” with the power steering not activating. The thread concludes that on the version without ESP the sensor must be mounted perfectly relaxed and aligned, using the locking pin/tool, and that calibration with a tester may still be required for proper zeroing of angle and torque values. A used sensor may be defective or worn, and incorrect installation or pre-tension can prevent calibration and steering assist operation.
TL;DR: After replacing a Meriva A steering angle/torque sensor, target a 0° angle and 0 Nm torque “zero” using a tester; as one expert notes, “Precise calibration is performed with a tester.” [Elektroda, tomjey, post #20899822]
Why it matters: This FAQ helps DIYers and techs fix no-assist issues (C1500) and decide when calibration is mandatory on ESP vs non-ESP cars.
Do I have to calibrate after replacing the sensor on a Meriva A without ESP?
If you install the sensor perfectly centered and locked, the electric power steering can work without calibration. Many techs still calibrate to fine-tune assist. Mechanical centering first, then test drive. Calibration improves optimal feel but isn’t always required on non-ESP cars. [Elektroda, saly, post #20469750]
Why is calibration recommended even after perfect mechanical alignment?
Calibration zeroes the stored references in the controller to 0° angle and 0 Nm torque. This matches the new sensor to the car’s ECU and ensures balanced assist. As one expert says, “Precise calibration is performed with a tester.” [Elektroda, tomjey, post #20899822]
What does DTC C1500 mean on the Meriva A EPS?
C1500 indicates sensor signal faults, including “Incorrect sensor signal” or “Voltage out of range.” When present at startup, the EPS disables assist and live parameters may freeze. Diagnose the sensor, wiring, and installation before attempting calibration. [Elektroda, saly, post #17449604]
How do I align the torque and angle sensor correctly?
Fit the sensor exactly on its alignment marks. The torque and steering angle elements must be seated without pre-load. Even slight misalignment will skew readings and may block calibration. Work slowly and verify straight-ahead before locking. [Elektroda, audic5, post #20468222]
Quick How-To: install and set zero on a non-ESP Meriva A
  1. Lock the column straight-ahead and secure the sensor using its pin/jig, avoiding any pre-tension.
  2. Seat the sensor on the marks, then lock it and recheck that readings sit near zero.
  3. Road-test; calibrate only if assist is uneven or readings drift. [Elektroda, saly, post #20469750]
Can I calibrate a sensor that was installed slightly crooked or under stress?
No. A crookedly inserted sensor will not calibrate. Remove stress, realign on the marks, and ensure the unit is relaxed at straight-ahead before retrying the calibration routine. [Elektroda, Strumien swiadomosci swia, post #21753129]
What’s different between ESP and non-ESP columns for this job?
ESP-equipped versions use keyed components (cutter) on the sensor, shaft, and wheel. You cannot mount them arbitrarily or rely on a simple straight-ahead lock as with some non-ESP setups. Plan on using the tester for final alignment. [Elektroda, vokotibi, post #21753231]
My test shows torque changes but the angle stays fixed. What does that indicate?
If torque reacts when you twist the wheel but the angle remains static—and a C1500 sets at boot—the angle sensing path is faulty or the unit is bad. Replace or refit the sensor before calibration attempts. [Elektroda, saly, post #17449670]
Do I need to loosen the intermediate shaft to fit the sensor?
Yes, loosen the power-steering shaft near the footwell. The sensor won’t insert in a simple straight-ahead position; you’ll fit while turned, then refit and align again. Use quality parts to reduce wear risks. [Elektroda, enhanced, post #21751802]
Which diagnostic tools can calibrate the Meriva A steering sensor?
Bosch KTS can run the calibration. Use it when left/right assist feels different or after sensor replacement. Follow prompts to zero angle and torque, then confirm values at center. [Elektroda, audic5, post #20470554]
Is buying a used steering angle/torque sensor a good idea?
Used sensors are a lottery. Internal tracks may be worn and only work briefly. Choose reputable “original” units and avoid low-quality clones, even if only slightly cheaper. [Elektroda, enhanced, post #21751802]
Any tricks if calibration keeps failing?
Remove any pre-load. Ensure the steering wheel and shaft aren’t tightening the sensor. Press the sensor home, release the clip, and lift the front wheels to reduce friction. Then rerun calibration. [Elektroda, saly, post #20470611]
What readings should I see at straight-ahead after correct installation?
Expect the force (torque) reading to sit near zero and angle close to 0°. That indicates a relaxed, correctly centered sensor, ready for or after calibration. [Elektroda, saly, post #20908065]
What exactly is the steering angle/torque sensor in this system?
It measures wheel angle and driver-applied torque. The controller uses these to deliver assist. During calibration, the ECU stores 0° and 0 Nm as reference baselines to interpret signals accurately. [Elektroda, tomjey, post #20899822]
