[Solved] Astra H 1.3 Cdti: Addressing P0243 Boost Pressure Regulation Error & Power Drop at Low Revs
mc2_ 11544 9
Why does my Astra H 1.3 CDTI lose boost at low revs and throw P0243 boost pressure regulation fault with a negative control deviation?
The most likely cause is incorrect turbo geometry/actuator adjustment after regeneration or a boost-system leak, not the MAP sensor or pressure regulator. Check the boost system for airtightness, the turbo linkage/rod for binding or misadjustment, and the EGR valve because if it sticks open there will be no boost [#16698263][#16729087] Do not adjust the turbo rod by hand on the car; verify the actual boost with a pressure gauge and, if peaks are real, inspect for a cracked intake manifold, a leaking EGR cooler-to-manifold connection, or a clogged catalyst that can act like a bleed-off valve [#16729413] The thread also notes that the ECU software update was already done, so software was not the solution here [#16727577] After the rod was adjusted, the peaks disappeared for a while, but the fault returned, which supports the idea that the actuator/turbo setting was still not correct or that the problem appears only under certain driving conditions [#16727577][#16729259]
  • Suspect intermittent boost pressure drop causing P0243
    #1 16698244
    mc2_
    Rate: 10
    Astra H 1.3 Cdti: Addressing P0243 Boost Pressure Regulation Error & Power Drop at Low Revs Astra H 1.3 Cdti: Addressing P0243 Boost Pressure Regulation Error & Power Drop at Low Revs Hello,
    I have a problem with the recharging process - there is a sudden drop in the measured value. After a few such peaks down, error P0243 boost pressure regulation appears. Control deviation negative. Turbine already replaced, MAP sensor new, pressure regulator too.
  • #2 16698263
    3piroman666
    Help: 25
    Rate: 57
    Airtight system? Turbine replaced with a used one or regenerated? Check that the turbine bar is not cutting and that the control cables are not worn somewhere, for example. The EGR valve may also jam and be opened then there will be no recharging.
    Best regards.
  • Unexpected boost drop suggests a control issue
    #3 16698265
    mc2_
    Rate: 10
    [Quote = "3piroman666"] Hi.
    Airtight system? Tight.
    Turbine replaced with a used one or regenerated? Regenerated, already second from another specialist.
    Check that the turbine bar is not cutting and that the control cables are not worn somewhere, for example. The EGR valve may also jam and be opened then there will be no recharging. It's all checked.
    I am most surprised by this "peak" down. This is the first time I see something like this ...
  • Suspected turbo actuator or variable geometry misadjustment
    #4 16698289
    3piroman666
    Help: 25
    Rate: 57
    Nom, this peak can be a falsification, this is not the moment where the error occurs, as I understand correctly, the red diagram is the pressure that is to be and always occurs after the shadow is exceeded, as if the turbine would let go. Is there a turbine with a geometry change or a relief valve? Someone did not accidentally spin the barbell at the turbine and it is not badly adjusted? because she is late and then breaks through as if there was something wrong with the control itself
  • #5 16698420
    adrian1201
    Help: 128
    Rate: 416
    And something was not buried in the software sometimes?
  • #6 16727577
    mc2_
    Rate: 10
    Rather not, they updated the soft in the ASO to rule it out. We suspected that the pressure was too high, so after adjusting the barbell the peaks stopped appearing, but after 400 km the error returned again. I'm waiting for the patient and we'll see, but you can see the problem is still ...
  • #7 16729087
    3piroman666
    Help: 25
    Rate: 57
    First, see if the same error continues and it is still about the boost pressure, if the peak has stopped appearing, you can see it was probably incorrectly set after regeneration, from experience I will add that if someone has already turned the regulation on the car or during regeneration it was incorrectly set, the correct regulation on the car it may take a while, it is difficult to correctly hit one turn of the nut and a test drive from the computer and observation of the parameters, maybe the turbine is still incorrectly set and reloads under some conditions while driving.
  • #8 16729259
    mc2_
    Rate: 10
    The peak is gone but the turbine is still reloading. Same error. I tried to trigger it and finally succeeded once at full throttle from 1st to 3rd gear. During normal use, it appears after a mileage of 300-500 km, I suspect that only then the driver registers the charging discrepancy long enough to save the error.
  • #9 16729413
    tzok
    Help: 3175
    Rate: 6546
    Adjusting the "barbell" only on the machine, turning it in the car is asking for problems. With these peaks, the first thing I would do is hook up the pressure gauge and check if they really are. If they were, I would bet on a cracked manifold - above some pressure the crack "opens" and works like a bleed-off valve (but it would whistle). In my Punta (the same engine), the problem was the connection of the exhaust gas cooler / EGR with the intake manifold (such a corrugated aluminum tube). The second option is a clogged catalyst.
  • #10 17597128
    mc2_
    Rate: 10
    Replacing the driver partially reduced the problem. But charging wasn't perfect anyway ...
The discussion revolves around a recurring P0243 boost pressure regulation error and power drop at low revs in an Astra H 1.3 Cdti. The user reports a sudden drop in measured values during the recharging process, despite replacing the turbine, MAP sensor, and pressure regulator. Responses suggest checking the airtightness of the system, the condition of control cables, and the EGR valve. There are indications that the issue may stem from incorrect turbine geometry settings or a cracked manifold. The user notes that after adjusting the barbell, the peaks stopped, but the error returned after some mileage. Further troubleshooting includes checking for pressure gauge readings and potential clogs in the catalyst.
