Renault Megane II CC - Central locking from the fuel filler flap how to get?
more90 7338 3
  • #1 16183214
    more90
    Rate: 14
    Hello, the fuel filler flap in the Renault Megane II cc is frozen. I tried with warm water but it didn't work because it holds the lock. I want to open it manually, but I don't know where the lock is located, does any of you have any orientation? thank you in advance.
  • #2 16183424
    lz11980
    Level 19  
    Help: 31
    Rate: 203
    The flap lock is located above the wheel arch, unfortunately you have to get from the trunk, you need to gently remove the upholstery and there you have a flap lock.
  • #3 16183726
    zfv
    On the right side under the cover
  • #4 16184129
    more90
    Rate: 14
    Today, when I was looking, I saw only a cabrio lock .. maybe it's even lower. Do you mean the bacon on the right or the middle too?
