Damage to the card digit + - damaged card or inserted incorrectly
leszekppp 19755 16
Why did my Cameleon card stop working in any decoder after I removed it from the splitter, and could it have been damaged or inserted incorrectly?
The card was probably not physically damaged by being taken out of the splitter; more likely it lost authorization, was affected by the splitter/power supply, or simply needed replacement [#16186389] [#16189303] Check the card in the decoder’s menu: in Pace look at the “Receipt and mail permissions” tab for validity dates, and in Nbox/OSCAM look at the logs or card recognition status [#16186389] [#16186052] If the card is not read at all, the practical fix in the thread was to get a replacement Cameleon card from the distributor, which restored operation [#16188287] Pulling the card while the device was on was mentioned as a possible trigger, but the splitter is theoretically designed for this, so a bad splitter power supply or static discharge was also suggested [#16186451] [#16189303]
  • #1 16185898
    leszekppp
    Rate: 273
    Hello, I need urgent help, I have a camelon card of the old digits, wanting to check the decoder nbox enigma 2 I took out the card from the splitter and back I put it into the splitter no decoder has no programs, I put in turn to every decoders including the original pace pvr 500 and the card does not want to act. What could happen?
    I will add that a week ago I got a new pace of pvr but then the card worked on nboxes and today does not work in any decoder.
  • #2 16185942
    simhak
    Help: 109
    Rate: 336
    Works in Nbox?
    The decoder sees the card?
  • #3 16185968
    leszekppp
    Rate: 273
    It does not work in N-Boxes.
  • #4 16185998
    simhak
    Help: 109
    Rate: 336
    Well, I know this after editing the first post.
    Does oscam recognize the card?
  • #5 16186031
    leszekppp
    Rate: 273
    I do not think he recognizes it because silence, neither image nor sound.
  • #6 16186052
    simhak
    Help: 109
    Rate: 336
    Check in the os90 or webiff logos.
    It is possible that the wrongly configured oscam "cooked" the card.
  • #7 16186067
    leszekppp
    Rate: 273
    I will not check, because I do not know it, and how "cooked" it is some rescue? Do I have to replace it and the splitter for ditching? But everything has worked so far
  • #8 16186389
    Darek.S
    Help: 216
    Rate: 978
    You can check the card in Nbox by entering its address in the search engine: 8888. There is a lot of information in the interface. But with Pace, you can check the card roughly. The menu contains the "Receipt and mail permissions" tab. The authorization dates are displayed there. Maybe the card just lost them. Then the phone to the side of the card in Pace's on the program 11 TVP1HD
    Although, on the other hand, when this post displays such a message, the cards do not read. And that's how I used to - it helped to chip and flannel (from poverty to pants: wink :)
    And from what I know, Cameleon, if you have Pace, they should exchange it for Cameleon, so the splitter can stay.
  • #9 16186451
    leszekppp
    Rate: 273
    I think that maybe I released it by pulling it from the splitter, because I pulled it out while on. And will they now exchange it for Cameleon, will they give it a steaming and I will not distribute it with a splitter? The rubbing, unfortunately, did not help. :-(
  • #10 16186494
    Darek.S
    Help: 216
    Rate: 978
    leszekppp wrote:
    And will they now exchange it for Cameleon?
    A friend distributor has a Cameleon for exchange. PS I hope you put a good card - sorry if I offended but I used to discuss half a hour with a friend (doctor gynecologist) and put the card in reverse. He went after a half-year absence on the plot and the decoder put up the opposite ... :|
  • #11 16186561
    leszekppp
    Rate: 273
    I definitely put the card well, and where is this familiar distributor?
  • #12 16186734
    Darek.S
    Help: 216
    Rate: 978
    To be sure, check the card in another decoder, eg Ferguson. Since you have from Pace NC it probably belongs to Cameleon. Because I did not hear that kaymans went to Paka. And these Cameleons should have each distributor of their own circumstances. Otherwise, they must replace all equipment. You just have to drive to the distributor with the equipment (Pace Cameleon) and exchange it.
  • #13 16186781
    leszekppp
    Rate: 273
    I do not have Ferguson, a week ago they exchanged me pace pvr, and now this card, a bit strange. If I exchange the decoder and the card for others, I can forget about splitters already?
  • #14 16186836
    Darek.S
    Help: 216
    Rate: 978
    leszekppp wrote:
    a week ago they exchanged pvr for me, and now this card, strange little.
    All subscribers who have Philips / pace 250Gb or without a disk exchange for those with a 500Gb disk, so nothing strange. And the card ... you mentioned that you could help ...
    leszekppp wrote:
    If I exchange the decoder and the card for the other, then I can forget about the splitters?
    It's a fact. Therefore, contact a nearby distributor (preferably by phone). what is the possibility of exchanging the card itself. You do not want to change the decoder. She is grandma, grandma is 80 years old and she got used to it :wink: . And for sure go with the card itself ...
  • #15 16188287
    leszekppp
    Rate: 273
    I was given a cameleon card :-) everything is ok again :-) . As usual, thanks for the advice.
    One more question, was it possible for me to damage the card by pulling it on the included splitter, is it not possible?
  • Check splitter power supply and possible static discharge damage
    #16 16189303
    Darek.S
    Help: 216
    Rate: 978
    I did so many times and nothing happened. And in both splitters and decoders. Theoretically, it is adapted to this. And practically it can be different. Maybe you had the load on you (because you stroked the cat or sweater you had: wink :) . To be sure, I would check the splitter power supply.
  • #17 16189521
    leszekppp
    Rate: 273
    You can be right, he's horrible at home now, where I can not touch it, shoots a spark, including my dog :-) . Thanks again.
The discussion revolves around a user experiencing issues with a Cameleon card that previously functioned correctly in various decoders, including the Pace PVR 500 and Nbox Enigma 2. After removing the card from a splitter and reinserting it, the card failed to work in any decoder, leading to concerns about potential damage or incorrect insertion. Responses suggest checking the card's recognition by the oscam software and verifying configurations. Users recommend testing the card in different decoders and contacting a distributor for possible exchanges. Ultimately, the user successfully obtained a new Cameleon card, raising questions about whether the card could have been damaged during the removal process.
