Best High-Power LED Searchlight Options Under PLN 200: Adjustable Light Angle, Diodes
Schizma. 6744 6
  • #1 16186279
    Schizma.
    Rate: 19
    Recently, I came to the conclusion that it would be nice to have a decent flashlight, because currently they do not give as much light as I need many times, my knowledge about these portable light sources unfortunately ends with old incandescent lamps, since the LED came in I have never delved into it how they work and how to assess their power by the diode markings, in general I am a layman in topic, getting to the heart of the topic.
    I am looking for a high-power flashlight, preferably with adjustable light angle, I have read that the type of flashlight I am interested in is "searchlights".
    I can spend up to PLN 200 on a flashlight and I do not necessarily want to buy from Polish distribution, on Allegro I was interested in this flashlight, it is sold with various diodes, about which I totally know nothing, I hope you will assess whether it is worth it and possibly suggest something more appropriate, thank you in advance and best regards.
    here's the flashlight I mentioned:
    http://allegro.pl/latarka-mysliwska-szperacz-cree-xr-e-q5-3-x-aku-i6527363256.html
    http://allegro.pl/latarka-mysliwska-szperacz-xm-l-t6-l2-bailong-808s-i6603703271.html#thumb/1
    http://allegro.pl/latarka-policyjna-led-cree-...i6001704199.html?bi_s=ads&bi_m=p5&bi_c=108832
  • #2 16186309
    Qbuś
    Help: 380
    Rate: 876
    Here link ask and read.
  • #4 16186329
    Schizma.
    Rate: 19
    on this forum I have already tried to create a topic several times, unfortunately due to some problems with the activation of the account I am not able to add posts, I finally quit and wrote here hoping that I will find someone with similar knowledge
  • #5 16187363
    Piotrek#G
    Help: 83
    Rate: 303
    The flashlights you provided links to are just g @ # well worth the trouble. Try to answer the questions:
    - What is the flashlight to be used for?
    - What range of light are you interested in?
    - PLN 200 for the flashlight itself or the whole set - flashlight, batteries, charger?
    - What flashlights do you have that you write about that the amount of light is not enough for you?
    I understand that you are considering shopping in foreign stores?
  • #6 16188815
    Schizma.
    Rate: 19
    PLN 200 I think I would like to spend on the whole set, although if I find something much better at a little higher price, I can always add PLN 50, the current flashlights I used did not exceed PLN 60, so there is probably no point in exchanging anything, the flashlight will generally be used for everything, be it evening forest walks or exploration of buildings, I'm just looking for something that will not fail in an emergency and the light will be strong enough
    as much as I consider buying in foreign stores, as for the range, it is hard for me to determine what it should be, so I was looking for something that will have a regulation of the light beam, although this is not required
  • #7 16192724
    Piotrek#G
    Help: 83
    Rate: 303
    Torches with beam adjustment let go. If you do not see problems when ordering in foreign stores, then you should manage to assemble some nice equipment.
    For such purposes, he would aim at a small lantern, with a neutral-colored diode and a fairly wide uniform light distribution.
    Of those that I can recommend:
    http://www.banggood.com/Convoy-S2-Aluminum-Alloy-XM-L2-7135x8-LED-Flashlight-p-954829.html with diode in XM-L2 T6 4C or 3B version
    http://www.banggood.com/Convoy-M1-7135x8-3-5M...Groups-700lumens-LED-Flashlight-p-908985.html diode as above
    http://www.banggood.com/Convoy-M2-7135-8-2-Gr...es-White-LED-Flashlight-Upgarde-p-909341.html diode as above
    www.banggood.com/Astrolux-S1-XPL-1600LM-7-4modes-LED-Flashlight-18650-18350-p-1012721.html
    http://www.banggood.com/Astrolux-S41-4x-Nichi...1600Lumens-Mini-LED-Flashlight-p-1054876.html + extension http://www.banggood.com /Astrolux-S41-Astrolux-S1-LED-Flashlight-18650-Body-Tube-p-1054468.html
    http://www.banggood.com/BLF-A6-XPL-1600LM-7-4modes-EDC-LED-Flashlight-p-991823.html
    http://www.gearbest.com/led-flashlights/pp_362637.html?wid=21 has a built-in charger, so there is one item to buy. The downside is that the built-in connector may not be as tight as the others I gave.
    Or maybe a headlamp? It's easy to use as manual, and irreplaceable for jobs that require free hands.
    www.banggood.com/Nitecore-HC30-XM-L2-U2-1000LM-Neutral-White-Headlamp-Flashlight-p-1052920.html
    http://www.gearbest.com/led-flashlights/pp_391921.html
    A charger, e.g.
    http://www.gearbest.com/chargers/pp_272183.html?wid=21
    http://www.gearbest.com/led-flashlights/pp_368027.html
    https://www.fasttech.com/products/0/10001919/...er-ml-102-universal-usb-smart-charger-version
    And cells, e.g. Panasonic NCR18650B on allegro available below PLN 20 / pcs.
    As you can see, some of my suggestions cost nearly PLN 200 or even above, but you can easily find discount codes that significantly reduce their price. You can search for codes here:
    http://budgetlightforum.com/node/42825
    http://budgetlightforum.com/node/37267
    http://www.swiatelka.pl/viewtopic.php?t=18953&postdays=0&postorder=asc&start=930
The discussion revolves around finding a high-power LED searchlight under PLN 200, with a preference for adjustable light angles. The user expresses a need for a flashlight that provides sufficient brightness for various activities, including evening walks and exploration. Recommendations include several models from foreign retailers, particularly from Banggood, featuring diodes like XM-L2 and Nichia 219B. The user is open to purchasing a complete set, including batteries and chargers, and seeks advice on the best options available within their budget.
