Choosing a Long-Range Flashlight (150m+), Budget of PLN 130, Ideal for Rural Use
Kubeki69 10527 15
What flashlight should I buy for rural use if I need a real range of at least 150 m and my budget is about PLN 130?
For a real 150 m reach on about PLN 130, the thread’s best practical recommendation is a Convoy C8, ideally bought from AliExpress or Banggood rather than locally [#16770177][#16772973] At this price you should expect compromises in the driver and heat dissipation, and it’s worth adding extra money for a good charger and batteries [#16770177] If you can stretch the budget, a Convoy L2 from a modder such as krypton.pl was suggested as a better, more expensive option [#16770275]
  • #1 16768688
    Kubeki69
    Level 4  
    Rate: 18
    What kind of flashlight with a good range to buy, up to PLN 130. I live in the countryside and I will also need a torch with quite a large range. What do you recommend? Real range to be at least 150 m, maybe more and even better.
  • #2 16768705
    mick1
    Help: 47
    Rate: 118
    A few questions to start with.
    How much does max cost?
    How much should he hold?
    Is this supposed to be a searchlight or a wide light (at this distance it is rather a searchlight, but I prefer to ask)?
    What is it to serve (lans? Forest? Backyard?)
  • #3 16769357
    Kubeki69
    Level 4  
    Rate: 18
    Rather, a yard, sometimes shining on the field.
    Added after 10 [minutes]:
    It's about as if hunting.
    Added after 18 [hours] 36 [minutes]:
    I am asking for advice ;)
  • #4 16769934
    robokop
    Help: 1763
    Rate: 6372
    The headlamps powered with large batteries have so much. How much money do you have for this flashlight? Because soon it turns out that you want to buy Surefire or Mactronic for PLN 50.
  • #5 16769955
    Kubeki69
    Level 4  
    Rate: 18
    150 zlotys can be a little more, but for the range to be elegant so that 150m real :) A minimum of 150 m and it would not be a shit
  • #6 16770002
    robokop
    Help: 1763
    Rate: 6372
    Well, buy yourself a cool Chinese Ultrafire XM-L2 U2.
  • #8 16770177
    mick1
    Help: 47
    Rate: 118
    First of all - with such a small mirror, forget about long range. For example, you may have a convoy c8, but forget to buy it in Poland (aliexpress, banggod, something like that) and 150m effective range.
    Secondly - with flashlights for 100-150 PLN, forget about a good driver and heat dissipation.
    Thirdly, finally - add another PLN 100 for a good charger and links.
    And this auction, which you threw, it's probably the laser is worth more than a flashlight for free ;)
  • #10 16770275
    mick1
    Help: 47
    Rate: 118
    krypton.pl - I already have a few flashlights from this modder.
    Find him. Relatively (but more expensive) Convoy L2
  • #11 16770282
    Kubeki69
    Level 4  
    Rate: 18
    And this https://latarki.pl/produkty/latarki_profesjon...ack_eye_mx532lrc_o_mocy_420_lumenow/5683.html 420 lumens should reach 100 m no?
    Added after 26 [minutes]:
    http://solarforce.eu/latarka-convoy-c8-sterownik-taktyczny-turbo-1600lm-xpl-hi-v3-p-113.html Last question, this can handle 150 m reach? Let's see what kind of game is in the field. ?
  • #12 16772288
    Dziarski Hank
    Help: 246
    Rate: 934
    @ Kubeki69
    Look at the Olight flashlights.
  • #13 16772624
    Kubeki69
    Level 4  
    Rate: 18
    And this convoy c8 turbo can not do it?
  • #14 16772973
    mick1
    Help: 47
    Rate: 118
    You can not buy anything better for me at this price. I would take this C8.
  • #15 16774172
    Kubeki69
    Level 4  
    Rate: 18
    I ordered convoy in turbo mode with Xl-p v3 diode, we will see what range it will be
  • #16 16834304
    no1muzzy
    And happy colleague from this C8 Turbo?
The discussion revolves around selecting a long-range flashlight suitable for rural use, with a budget of PLN 130. Users emphasize the need for a flashlight with a real range of at least 150 meters, suitable for tasks like hunting and illuminating fields. Recommendations include the Ultrafire XM-L2 U2 and Convoy C8, with discussions on their effectiveness and potential purchase sources. Concerns are raised about the limitations of budget flashlights regarding build quality and performance, suggesting that higher-quality options may require a larger budget. Users also mention brands like Mactronic and Olight, indicating a preference for reliable performance in outdoor settings.
TL;DR: For long-range on a tight budget, a Convoy C8‑class thrower delivers about 150 m effective range; “add another PLN 100 for a good charger and links.” [Elektroda, mick1, post #16770177]
Why it matters: If you live rurally and ask “what’s the best budget flashlight for 150 m?”, this FAQ shows proven picks, trade‑offs, and buying tips for PLN 130–200 users.
What’s the best long‑range flashlight around PLN 150?
The community pick is a Convoy C8‑class thrower. It balances price, beam distance, and practicality for rural yards and fields. One expert put it plainly: “You can not buy anything better for me at this price. I would take this C8.” That aligns with the 150 m effective‑range target discussed in the thread. If you can stretch the budget slightly for batteries and a charger, the overall setup performs far above typical “bundle” kits. [Elektroda, mick1, post #16772973]
Will a Convoy C8 actually reach 150 meters?
Yes—expect about 150 m effective range from a C8‑class thrower. The key is its focused beam and reflector geometry, not just lumen rating. This makes it well‑suited to scanning fields and yard edges without wasting light on near‑field flood. As the expert advice noted, small reflectors limit range; the C8’s profile hits the needed distance while staying affordable. [Elektroda, mick1, post #16770177]
Can I buy the Convoy C8 in Poland, or do I need to import?
A user pursued a Polish seller listing for a Convoy C8 with an XP‑L HI V3 option. That indicates domestic availability can exist, though stock varies. If you buy locally, verify the exact driver, emitter bin, and warranty terms. Importing remains common, but a local purchase simplifies returns and shortens delivery. [Elektroda, Kubeki69, post #16770194]
Do lumens equal range for rural use?
No. Beam distance depends more on reflector size and emitter type than raw lumens. A compact light with high lumens but a small reflector will throw poorly. The guidance here was clear: with a small mirror, forget long range. Choose a thrower‑style head if you need 150 m identification. “Range is about optics first.” [Elektroda, mick1, post #16770177]
Is 420 lumens enough to reach 100 meters?
It can be marginal unless paired with a true thrower optic. A 420‑lumen flooder will light near objects but struggle at 100 m. The thread emphasizes reflector size and beam focus over lumen count for distance work. Prioritize a thrower head; otherwise, apparent brightness won’t translate into reach. [Elektroda, mick1, post #16770177]
How much should I budget for batteries and a charger?
Add about PLN 100 for a quality charger and good cells. Cheap bundles often include weak chargers and questionable cells that limit performance and longevity. A proper charger protects your investment and sustains consistent output on high modes. “Add another PLN 100 for a good charger and links.” [Elektroda, mick1, post #16770177]
What’s the difference between a thrower and a flooder?
A thrower concentrates light into a tight hotspot for distance (ideal for 150 m). A flooder spreads light wide for close‑range tasks. For yards, fields, or hunting‑style scanning, pick a searchlight/thrower beam. The expert framed it as searchlight versus wide light at distance needs. [Elektroda, mick1, post #16770177]
Is a cheap Ultrafire XM‑L2 U2 a good idea?
It’s not ideal for reliable long‑range use. Low‑cost lights often ship with weak drivers and poor heat dissipation, which throttle output. That undermines throw and runtime, especially in turbo. Prioritize proven hosts like the C8 with known drivers and emitters. [Elektroda, mick1, post #16770177]
Are “laser gratis” or gift‑bundle listings trustworthy?
Treat them cautiously. One expert noted the free laser might be worth more than the flashlight itself. Such bundles divert budget from core components like the driver, cell, and thermal design. Focus on reputable hosts and buy cells/chargers separately. [Elektroda, mick1, post #16770177]
What emitter did the buyer here choose?
They ordered a Convoy with an XP‑L V3 diode and turbo‑mode driver. That combination targets tighter throw and higher candela than standard domed emitters. It aligns with the 150 m distance goal for rural tasks. [Elektroda, Kubeki69, post #16774172]
Any brand alternatives mentioned besides Convoy?
Yes. Olight was suggested as an alternative line to check. Availability, cost, and specific models vary, but Olight offers several throw‑capable options that could meet rural needs. Compare beam profiles and carry formats before buying. [Elektroda, Dziarski Hank, post #16772288]
Quick buying guide: how do I choose fast?
  1. Define range need (150 m) and pick a thrower head, not a small‑mirror flooder.
  2. Set budget: ~PLN 150 for the light, plus ~PLN 100 for charger/cells.
  3. Avoid bundle gimmicks; select a proven host and quality power components. [Elektroda, mick1, post #16770177]
Will the C8 let me spot game in an open field?
Expect identification around 150 m with a C8‑class thrower when conditions are clear. The focused hotspot aids eye‑shine detection and terrain scanning. For wider context, pair with a lower mode or a secondary flooder. Keep expectations aligned with reflector size. [Elektroda, mick1, post #16770177]
Did the original buyer report satisfaction after purchase?
A follow‑up asked whether the buyer was happy with the C8 Turbo, but no satisfaction update appears in the thread. If you own this setup, consider adding your field results to help others. [Elektroda, no1muzzy, post #16834304]
