Using NC + Nagravision Card with Matrix Reborn Module on TV - Experiences?
goldi11 6345 11
Can I use an old NC+ CAMELEON/Nagravision card in a TV’s CI slot with a Matrix Reborn-type module, and do I need to program the module?
You need the correct CI module for that CAMELEON/Nagravision card; the CONAX module will not work and the TV can show a card error instead [#16187912][#16187961] Search auction listings for the proper module that supports this card, because one reply says this is the required solution [#16187961] Another option is to skip the module and buy a used decoder instead, which was suggested as cheaper and simpler [#16187961][#16188121] One example given was an Ariva 150 for about PLN 120 used [#16188121]
  • #1 16187798
    goldi11
    I recently got a card from a friend NC + that I would like to use, unfortunately I do not have a decoder for it. It is an old card with the word CANAL +, which should not be paired with the decoder. I read somewhere on the Internet that NC + uses CONAX encryption, I bought the appropriate module and unfortunately ZONK. After consultations on the website, I found out that the old cards do not use CONAX but Nagravision encryption.
    I am looking for a suitable module and found http://www.pasaz.v10.pl/modul-ci-matrix-reborn,p13012489.html
    Taught by experience, I would like to ask you first :)
    The only information that I found on the internet concerns placing these modules in set-top boxes, not directly on the TV, or someone used this module? Can you confirm to me if it has everything you need to just put it on a TV with a card and make it work? Do I still have to program it somehow? I've seen such threads even on this forum ...
  • #2 16187836
    telesat1
    Help: 104
    Rate: 258
    What do you want to watch with this card and this module?
  • #3 16187855
    goldi11
    I would like to watch all the available channels in the package .. I guess you are asking whether SD and HD are right? I do not see information that this module does not support HD, but I also do not know the information that it supports :(
  • #4 16187864
    telesat1
    Help: 104
    Rate: 258
    goldi11 wrote:
    I would like to watch all the available channels in the package.
    What package and which sender?
  • #5 16187866
    goldi11
    However, I found information that they do not work :(
    Do you know any cheap module that supports Nagravision and HD?
  • #6 16187869
  • #7 16187871
    goldi11
    Extra + package in NC +
  • #8 16187873
  • #9 16187912
    goldi11
    Boy, I didn't think this information was needed for my inquiry :)
    In the NC + management system my card is visible as CAMELEON CARD, do you need the number too? The card is active until March 2017, bills paid.
    Taka: http://img2. Sprzedażmy.pl/540x405_2-x-karta-cyfra-cameleon-na-umowe-w-nc-sprzet-satelitarny-dolnoslaskie-legnica- Sprzedaż-68361237.jpg
    The TV is a Philips 48pfs8109 / 12
    After inserting the card into the CONAX module which is inserted into the CI connector on the TV
    http://allegro.pl/modul-ci-conax-cam-technisa...3NjdmOWZlOWEzZDJjMjE5YjYzODQ0OWQwZWRiYmU0NA==
    in the interface menu the card has the status Card Problem - Incorrect Card - or some similar message
  • #11 16188092
    goldi11
    A bit pricey actually. Rather, she will not decide :(
    And as for the decoder, which one do you recommend?
  • #12 16188121
The discussion revolves around using an NC+ card with a Matrix Reborn module on a TV. The user initially attempted to use a CONAX module but discovered that the old NC+ card operates on Nagravision encryption. They seek advice on compatible modules and whether the Matrix Reborn module can be directly used with a TV. Responses indicate uncertainty about the module's support for HD channels and suggest alternatives, including purchasing a decoder. The user mentions their card is active and linked to the Extra + package, and they provide details about their Philips TV model. Recommendations for decoders include the Arive 150, which is suggested as a cost-effective option.
