Yamaha RX-V373 AV Receiver Won't Turn On: Reset, Burnt Smell, Power Supply & HDMI ARC Issues
chewa 11691 4
  • #1 16189031
    chewa
    I have a problem with the Yamaha RX-V373 AV Receiver. The receiver does not turn on. I tried to do a reset with a combination of keys (TUNE CONTROL, STRAIGHT, POWER [ON / OFF]) nothing helps, only it smells of burning, I suspect a burnt power supply but I prefer to make sure. The display does not light up and the receiver only makes a popping sound (such as when it is turned on) and then turns off. I also wanted to add that for some time the receiver on HDMI ARC was interrupting and it had to be turned off for about 5 days (perhaps from the HDMI cable).
    Thanks for your attention, best regards.
    kokapetyl
    Help: 1787
    Rate: 2101
    chewa wrote:
    Thank you for your attention,
    I took a moment to read your post.
    The conclusion is this.
    Scrap equipment or have it serviced.
    You won't do anything yourself, after your post I conclude that you have a poor idea of repairing equipment and electronics.
    Sorry to write that, but I think it's true.
  • #3 16190996
    chewa
    Thanks for the advice, but I'm unlikely to throw away a few hundred bucks worth of gear. Thank you again.
  • #4 16191009
    kokapetyl
    Help: 1787
    Rate: 2101
    chewa wrote:
    but probably not throwing away equipment worth a few hundred dollars
    It was by the way, I also gave a different solution.
    Unless you feel able to repair it yourself.
  • #5 16191035
    krakarak
    Help: 681
    Rate: 1846
    @chewa write what measurements you have already carried out, what have you determined and what parameters have you had a problem with interpreting? Where are you stuck?
    Just don't write us that all you did was sniff ...
    Here is the service manual and diagram: Link .
    Download, take measurements, write.
