Yamaha MCR-840 R-840 - The amplifier does not turn on, and the DVD does.
thesilent 26274 8
  • #1 16304119
    thesilent
    Rate: 14
    My five-year-old Yamaha Pianocraft MCR-840 has a problem. Initially, it happened that the R-840 amplifier segment did not turn on immediately. Only after some time did it startle and turn on. There is no problem with the DVD segment. Now, however, the amplifier cannot be turned on at all, it is completely dead. Before I start digging and measuring, I hope that someone has already had a similar problem and will give me some clues.
  • #2 16304814
    SERVICE-AV
    Help: 728
    Rate: 899
    Any power measurements?
  • #3 16305758
    thesilent
    Rate: 14
    I checked that there is a live Graetz bridge at the input on the StandBy PCB. After the bridge, there is almost 400 V rectified. I got a schematic diagram and a diagram of this board. I will have to analyze step by step where the error is. The tower does not start with either the button or the remote control. Completely zero reaction.
  • #4 16472640
    oldgrom
    If you have a schematic of the power supply board, I recommend checking the C13 capacitor and R14 resistor. I used the scheme from 69 pages SERVICE MANUAL R-840 / NS-BP300. Best regards and good service successes.
  • #5 16473319
    thesilent
    Rate: 14
    I have already repaired it, it was the capacitor that was damaged. This is typical for these amplifiers.
  • #6 16566750
    krzkoz
    Rate: 15
    Dear Colleagues, you are "DEBESTS" - you helped me too, THANK YOU.
    First, I set out ambitiously and scientifically with an oscilloscope in my hand. I was so confused that I postponed the work until the second day. And I remembered about the electrode and, of course, C13 - the job took 5 minutes.
  • #7 16722500
    piotro222
    Rate: 11
    I also had the above-mentioned problem. I admit that I am a total novice when it comes to electronics. I found a topic, bought a capacitor with parameters 22nF/630V and gave it to an electronics technician for soldering. Costs: PLN 2.5 - capacitor, PLN 10 - soldering.
    Thank you and best regards.
    • Yamaha MCR-840 R-840 - The amplifier does not turn on, and the DVD does. 20170926_192850.jpg (6.42 MB) You must be logged in to download this attachment.
  • #8 16789391
    wilczar
    Hello, I had similar symptoms - first the receiver did not turn on from time to time, then permanently. I sent it to a service center in Wrocław for repair - below is the receipt - because my soldering skills could cause irreparable damage ;) . Unfortunately, when the amplifier came back on, the sound in the treble range is distorted - you can obviously hear the drums - something as if I was listening to a low-quality MP3. Dear colleagues, do you know what could have gone wrong? I will give the amplifier back, but it would be great if I could direct the service gentlemen - because I am afraid that they will not pay attention to the sound.
  • #9 18843854
    kkulik
    I also had this problem. I bought a capacitor (1.5 for 5 pcs + shipping). I soldered it and it works.
    Thanks a lot!!!
✨ The Yamaha Pianocraft MCR-840's R-840 amplifier exhibits a failure to power on, while the DVD component remains functional. Initial symptoms included intermittent power issues, which escalated to a complete shutdown. Users suggested checking the power supply board, specifically the C13 capacitor and R14 resistor, as common failure points. Several users reported successful repairs by replacing the faulty capacitor, which is a known issue with this model. One user experienced additional sound distortion post-repair, prompting further inquiries about potential service issues.
