Yamaha Rx-E410 Receiver Repair: No Power On, Replaced Capacitors & Missing 5V - Need Help
djgala 3663 2
  • #1 19067893
    djgala
    Hi All,
    I try to repair this small Yamaha receiver but with fails.
    In the past I can repair some Yamaha RX-V receivers with the 22nF cap.
    I also replaced now but also not power on.
    I think the first problem I don't have an S10 10V I have only 4.8V, so also 5V is missing.
    I change on Main (2) board:
    C4
    C8
    C9
    C10
    Can help me someone?
    Thank you and sorry for my English
    • yamaha_rx-e410_810.pdf (8.07 MB) You must be logged in to download this attachment.
  • #2 20370581
    azaghorth
    Rate: 12
    *I think the first problem I don't have an S10 10V I have only 4,8V, so also 5V is missing.*
    Check the diode also on the 10V rail, plus the cap.
    The 5V rail is usually stand-by for the processor, without it the device won't turn on.
    Usually is a small transformer with diode bridge, cap and a 5V regulator like LM7805.
    Check all this if there are ok
  • #3 21359833
    bacamarte
    Olá, você tem tensão AC no transformador T1?
