Unable to Access 4GB USB Memory Bar After Failed CDFS Partition Removal Attempt
Regos 27855 16
How can I restore a 4GB USB flash drive with an SMI SM3257ENLT controller after a failed attempt to remove its CDFS partition and it is no longer detected properly?
Use a newer SMI Mass Production Tool for the SM3257ENLT controller, because older versions may fail with “flash id not found in ForceFlash.set” or not see the drive at all [#14460429][#14460474][#14460851] The thread’s working fix was to download the newer Transcend-branded SMI package from usbdev.ru, specifically TRANSCEND-SM32X-PV1.1.64-BY-USBDEV-O0311, which unpacks to sm32Xtest_V2.5.41_v4_O0127 [#14540017][#14577114] That version was reported to work with the Samsung ECD788BF flash used in this type of stick [#14577114] One user also reported that updating to the latest SMI MPTool on an SM3257ENLT restored almost the full capacity of a misreported drive and fixed errors [#17967648]
  • #1 14460379
    Regos
    Rate: 26
    I tried to delete a CDFS iii partition it was an error. I tried to do something smi_mptool_v2.5.27_v8 but I don't know how to handle it completely. I don't see it as a drive on my computer. I am asking humbly for some help, there is nothing important on it and even though the flash drive is tiny (4gb), I feel sorry to write it off immediately because it is nice.
    First, data from ChipGenius
    Description: [F:]Urządzenie pamięci masowej USB(USB MEMORY BAR)
    Device Type:        Mass Storage Device
    Protocal Version: USB 2.00
    Current Speed: High Speed
    Max Current: 100mA
    USB Device ID: VID = 090C PID = 3000
    Device Vendor: Silicon Motion,Inc.
    Device Name: SM3255AA MEMORY BAR
    Device Revision: 0100
    Product Model: USB MEMORY BAR
    Product Revision: 1000
    Controller Vendor: SMI
    Controller Part-Number: SM3257ENLT - ISP NONE
    Flash ID code:      ECD788BF - Samsung - 1CE/Single Channel [TLC] -> Total Capacity = 4GB
    Unable to Access 4GB USB Memory Bar After Failed CDFS Partition Removal Attempt Unable to Access 4GB USB Memory Bar After Failed CDFS Partition Removal Attempt Unable to Access 4GB USB Memory Bar After Failed CDFS Partition Removal Attempt
  • #2 14460429
    melanchel
    Help: 154
    Rate: 380
    SMI MPTool V2.5.14 v1 M0225 this one can come up.
  • #3 14460474
    Regos
    Rate: 26
    Hmm now it showed the message "flash id not found in forceflash.set"
  • #4 14460536
    melanchel
    Help: 154
    Rate: 380
    Maybe it's 27nm Samsung? And this is SM3257ENLT v2.5.06 :?:
    Finally, SMI MPTool V2.03.49 v1 K0929 :?:
  • #5 14460851
    Regos
    Rate: 26
    SM3257ENLT v2.5.06 - flash id not found in ForceFlash.set
    SMI MPTool V2.03.49 v1 K0929 - does not see the ehhhh drive at all
  • #6 14460878
    Wysuszek
    Help: 9
    Rate: 14
    Try WinSetupFromUSB 1.4 and click FBinstTool ... it usually saves my pendrive if I mess too much on it and after formatting with the force function I have it ready as when I connect to the computer for the first time.
  • #7 14460950
    Regos
    Rate: 26
    Unfortunately, he can not see about it at all, I tried all the additional options in it and they do not see the same :(
  • #8 14535287
    wycz3s
    Rate: 12
    I have a very similar problem, although the opposite I have I need to create a CDFS partition on a similar USB stick.
    The obstacle is the FLASH memory chip, unknown to the SMI Mass Production Tool program, in my and your case it is SAMSUNG ECD788BF
    Data from ChipGenius
    USB Device ID: VID = 090C PID = 1000
    Controller Part-Number: SM3257ENLT - ISP 141218-AA-
    Flash ID code: ECD788BF - Samsung - 1CE / Single Channel [TLC] -> Total Capacity = 4GB
    memory information from SMI MP
    I found the latest version of the SMI program on flashboot.ru
    flashboot.ru/files/file/445/
    it's posted on February 26, but it doesn't recognize memory either.
    In the program folder there is a ForceFlash-XXXXXX.SET file where X depends on the version,
    for another USB memory with the previous version of the flash memory with the symbol SAMSUNG ECD798DE the definition of the FLASH chip is as follows:
    A591 = Samsung, 16Gbit (8KP) (256Page) (19nm), K9AAGD8U0B (TWIN + 2Plane + 4Ext-intlv)
    Samsung, 16Gbit (8KP) (256Page) (19nm), K9AAGD8U0B (TWIN + 2Plane + 4Ext-intlv) = EC, D5,98, DE, 94, C5,2,2,2,1,1,4,2E, F0,0,0, FF, FF, 1,60,60,1,8,1,1,41, C1,2.0, FF, 0.46.0 ,,,,,,
    EC, D7.98, DE, 94, C5_0 = 592
    A592 = Samsung, 32Gbit (8KP) (256Page) (19nm), K9ABGD8U0D (Single_DG)
    Samsung, 32Gbit (8KP) (256Page) (19nm), K9ABGD8U0D (Single_DG) = EC, D7.98, DE, 94, C5,2,0,2,0,0,8,5E, F0,0,0, FF, FF, 1.60, 60, 1.8, 1.1, 41, 1.2, FF, 0.46.0 ,,,,,,
    where EC, D7.98, DE, 94, C5 coincide with this memory information from the SMI MP tool
    still looking for a solution, best regards
    pidar
    Help: 1569
    Rate: 3590
    There are new versions of soft for SMI on the Colleague's website tagievara and here I will add selected firmware for Samung 19nm, which I was also looking for:
    • SM3257ENLTISP-ISPSA19nm___BIN.zip (187.34 KB) You must be logged in to download this attachment.
    wycz3s
    Rate: 12
    pidar is right, the latest version of SMI MASS PRODUCTION TOOL has recently appeared on the website http://www.usbdev.ru, albeit with the transcend logo. But it's not a problem.
    http://www.usbdev.ru/files/smi/transcendsmbyusbdev/
    file TRANSCEND-SM32X-PV1.1.64-BY-USBDEV-O0311 7 019 274 bytes
    after unpacking
    Works with the bone described earlier
    ECD788BF - Samsung
    Samsung K9ABGD8U0E
    Thank you very much for help.
  • #11 14584077
    Regos
    Rate: 26
    Gentlemen,
    Thank you very much! I followed the topic, but did not have physical access to this flash drive (departure). Today I tried and the patient came back to life.
    Merry Christmas
  • #12 14804858
    tapaz
    Witam
    Padł mi pendrive podaję odczyt z CheckUDisk V5.4
    Name: USB Flash Memory (USB2.0)
    VID&PID: Vid_0930&Pid_6545
    Speed: high speed
    Vendor Description:
    Product Description:
    Serial Number: 001CC0EC34B2EC212632004D
    \\.\PHYSICALDRIVE2
    \\?\usbstor#disk&ven_&prod_usb_flash_memory&rev_pmap#001cc0ec34b2ec212632004d&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
    VendorID:
    ProductID: USB Flash Memory
    Czy jest możliwość reanimować?
    Pozdrawiam
    Product Revision: PMAP
    Logic Driver: J:\ (Total Space: 0.00 MB, Free Space: 0.00 MB)
  • #13 16861394
    jaca121212
    Rate: 13
    Hello, I have a problem with the pendrive I do not know how to upload and what a soft firewall should be for this pendrive is described at this link I do not want to write everything from scratch
    Link
  • #14 16861524
    coperfild
    Help: 291
    Rate: 1697
    It should work.
    • Sm3257en SMI MPTool v2.03.37 software.rar (2.12 MB) You must be logged in to download this attachment.
  • #15 16866379
    jaca121212
    Rate: 13
    Nothing has changed after I uploaded this file. And wgl can someone write briefly how to load these files in this program.
    Volume: F:
    Controller: Silicon Motion SM3257 ENBA
    Possible Memory Chip (s):
    Samsung K9ABGD8U0E
    Memory Type: TLC
    Flash ID: ECD788BF 90C6
    Flash CE: 1
    Chip F / W: ISP NONE
    MPTOOL Ver .: 0.00.00
    VID: 090C
    PID: 3000
    Manufacturer: Silicon Motion, Inc.
    Product: SM3255AA MEMORY BAR
    Query Vendor ID:
    Query Product ID: USB MEMORY BAR
    Query Product Revision: 1000
    Physical Disk Capacity: 0 Bytes
    Windows Disk Capacity: 0 Bytes
    Internal Tags: 8VAG-ASEJ
    USB Version: 2.00
    Declared Power: 100 mA
    ContMeas ID: 357B-02-EE
    Microsoft Windows 7 SP1 x64 Build 7601
    http://www.antspec.com/usbflashinfo/
    Version: 8.9.0.605
  • #16 17967648
    pdurka
    Rate: 16
    maybe it is worth updating to the latest version, ie smi mptool, and the SMI MPTool V2.5.27 v8 M1004 version for the SM3257ENLT controller.
    it's worth doing it, because I bought a used 4gb flash drive and it should be 8gb, after uploading the latest version, almost 8gb was recovered and in 4gb housing and it's free from errors! it's from a different version of the controller, I even bought a new 8gb mini flash drive and it should be 16gb only a new version of the controller and it is 11gb, but this is not the end, maybe there will be a new version and it will be possible to recover close to 16gb.
  • #17 18854957
    Denver786
    Rate: 9
    Hello, I have such a bug
    Unknown device in device manager (error while requesting device description).
    USB flash drive driver, what driver should I download?
    Thanks a lot
    Added after 38 [seconds]:
    USB flash drive could not be found.
    Plug in a USB flash drive and restart the utility.
    Added after 34 [seconds]:
    usbdriveinfo
    Added after 45 [minutes]:
    I have such a 32GB SD card, unfortunately it is recognized as 8MB, what should I do?
    Max Current: 500mA
    USB Device ID: VID = 0BDA PID = 0129
    Serial Number: 20100201396000000
    Device Vendor: Generic
    Device Name: USB2.0-CRW
    Device Revision: 3960
    Manufacturer: Generic-
    Product Model: xD / SD / MS
    Product Revision: 1.00
    Controller Part-Number: Unknown
A user encountered issues accessing a 4GB USB Memory Bar after attempting to remove a CDFS partition. Despite using various versions of SMI MPTool, including V2.5.27 and V2.5.06, the device was not recognized, and error messages indicated that the flash ID was not found. Other users suggested tools like WinSetupFromUSB and provided links to newer versions of SMI software that might help recover the drive. Ultimately, one user reported success in reviving their USB drive after following the discussion and using the recommended tools.
