HP EliteBook 8440p Laptop Not Detecting 8GB Micro SDHC Card with GOODRAM Card Reader
ppp47676 6858 4
  • #1 16190088
    ppp47676
    Rate: 22
    Hello, I have an HP EliteBook 8440p laptop and a GOOD RAM card reader. The thing is that I received the 8GB micro SDHC micro card in the set and after inserting it into this laptop it does not detect it at all. Amazingly, after inserting the same 2GB micro SD card reader everything is ok. How to solve this problem?
  • #2 16190095
    dt1
    Admin of Computers group
    Help: 7320
    Rate: 8306
    Welcome. If this is an old reader, it may not support SDHC / SDXC cards, only old SD cards. Check with another SDHC card if the reader works, if not then the solution to the problem will be buying another reader that supports such cards.
    Kasek21
    Help: 4981
    Rate: 3549
    Check after installing this driver: ftp://ftp.hp.com/pub/softpaq/sp45001-45500/sp45112.exe
  • Installing the HP driver restored SDHC card detection
    #4 16190358
    ppp47676
    Rate: 22
    So if it may not support, why did I get this reader included with this card ??
    Added after 14 [minutes]:
    Thank you for your help, it works after installation :D
  • #5 16190438
    Kasek21
    Help: 4981
    Rate: 3549
    You didn't get the reader just an SD adapter.
    A new driver was needed for your built-in reader to correctly recognize the SDHC card.
