Passat B7 2.0 TDI relay - Looking for a relay for the Passat B7
kubuswujo 23790 4
  • #1 16192920
    kubuswujo
    Rate: 71
    Hey!!
    I have a damaged relay box in the Passat B7 2.0 TDi 150HP 2011. Kombi.
    I bought a second bundle of wires with a plug and relays but in this new one is missing which is in position R4.
    On the photo I hold both plugs on the left, old on the right new one.
    I have indicated the arrow for which relay I mean.
    Could someone tell me what relay I need to buy?
    I would love to know what it is, I can not find such information anywhere.
    As if someone needed this nuemr part of the plugin:
    7NO 937 311
    maybe it will help me find the right relay
    Thanks in advance!
    Cuba
    • Passat B7 2.0 TDI relay - Looking for a relay for the Passat B7 IMG_20170103_175132.jpg (1.67 MB) You must be logged in to download this attachment.
  • #2 16192974
    SQ9MEM
    Help: 119
    Rate: 279
    And in the old you do not have relays? By the way, looking at the damage, the donor's car had to be on a nice bell.
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Search for relay No. 53 - will match even from Golf 3, this relay has many uses.
    In the picture marked what should be there.
    From the picture you can see that this new box has no contacts for this relay so you have to translate them.
    This box appeared in various cars, so it's worth paying attention to the 433 relay, because in yours it can be number 100.
    433 has 5 legs and leg 87 connected to D and is up to 50A.
    100 has 4 legs and is up to 70A.
    So pull out what's left of yours and see how many feet it has.
    457 is from glow plugs.
    Colleague proposes to read more carefully and with understanding.
    This damaged box is from the author's car and the whole is from a different car.
  • #4 16195171
    kubuswujo
    Rate: 71
    @ SQ9MEM Thank you very much !!!!
    You are super!!
    Exactly that's what I meant, I immediately buy relays, so mine is damaged.
    By the way, could you tell me where you found this information I would not have to (knock) next time ask on the forum?
  • #5 16285529
    kubuswujo
    Rate: 71
    I am refreshing the topic I have a car but the car has no support, under vcds I made the adaptation of the kata skre passed ok but on the counter is still glowing red steering wheel icon and error in the driver
    About the intalation break to support.
    I went under the mask and there are three plugs all ok. Two thick cables have plus and minus 12V.
    As you know, I had a broken box of relays and fuses. And I suspect that I can not tell you what message is responsible for the pump and which fuses (cables coming to the fuses) check.
