Locating Starter Relay in VW Passat B6 FL 2010 1.6 tdi with P3052 and P3088 Errors
blayders 8859 2
  • #1 16198215
    blayders
    Help: 7
    Rate: 73
    Ignition switch ok, bolt ok, starter turns briefly. The engine computer crashes P3052 and P3088. Where can I find a starter relay ??
  • #2 16198275
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, either the engine compartment or under the driver's cockpit.
  • #3 16198440
    blayders
    Help: 7
    Rate: 73
    I am counting on more accurate data, I guess. From the symptoms that I have noticed, the relays are ticking once slowly and quickly in the wheel arch module (voltage stabilization).
    Added after 2 [hours] 34 [minutes]:
    The problem is solved, the contact in the cabin of the starter control cable is out of order.
