Effects of Installing a Blow Off Valve on Passat B5 1.8T Performance
Showbiz32 5118 3
  • #1 16194230
    Showbiz32
    Rate: 81
    As in Title :) Will installing blow off on Passat b5 1.8T reduce its performance?
  • #2 16194741
    manta
    Help: 463
    Rate: 1533
    Correctly selected no, but it shortens the life of the turbine.
  • #3 16194745
    MrMalo82
    Rate: 42
    Such a thing is nonsense, unless chiseled 1.8T.
    There will be a turbo-lag, there may be errors from the controllers and even engine flooding, because everything will start to change, because there will be actions with pressure. What else is soft at the tuner and some mods.
    In addition, when you buy some crap, you can get a turbine.
    I do not recommend it, but do as you see fit, especially there will be no drops in high power, but the reaction may be delayed because the turbo will fly again, it will not be as if in "Standby" as in the series.
    blow off releases the pressure.
  • #4 16194917
    Showbiz32
    Rate: 81
    OKAY :) thanks for advice ;)
