BOSCH HEN43T053 - How to connect a built-in oven to electricity
lucasville 4701 4
  • #1 16196182
    lucasville
    Rate: 17
    Hello all.
    I bought a used built-in electric hob oven. Along with the oven I got a thick white power cord, but there is no normal "plug" on either side.
    Will there be someone good and tell you how to connect such an oven to a normal 230V contact?
    The cables in the plugs come out of the electric hob and plug into the oven, so there will be no problem with this.
    • BOSCH HEN43T053 - How to connect a built-in oven to electricity DSC_3127.JPG (428.86 KB) You must be logged in to download this attachment.
    • BOSCH HEN43T053 - How to connect a built-in oven to electricity 444997873_1_1000x700_zestaw-bosch-plyta-elektryczna-i-piekarnik-elektryczny-do-zabudowy-szczecin_rev001.jpg (63.96 KB) You must be logged in to download this attachment.
  • Electrician needed for 11.5 kW oven installation
    #2 16196206
    kokapetyl
    Help: 1787
    Rate: 2101
    It cannot be normal.
    Due to the power of 11.5 KW, appropriate installation is needed, does the contract with the electricity supplier take into account such power demand (11.5 KW + other household appliances)
    The apartment is powered by one or three phase.
    As you can see there are many questions, the best solution is to invite an electrician.
  • #3 16196225
    lucasville
    Rate: 17
    The installation is single-phase. Contracted power 3kW.
    I honestly thought it was an ordinary oven ... Just like another one I have at home.
  • #4 16196359
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    What is the old one at home and what other devices with high power consumption are there.
  • #5 16196365
    lucasville
    Rate: 17
    I'll check the oven when I get home and let me know in the afternoon.
