Beko DIS1520 Dishwasher Water Pump Issue: Not Pumping Out, Hot Water & Agent Added
ekipa 28299 6
  • #1 16959884
    ekipa
    Rate: 21
    Today, my dishwasher has a fault like in the subject. After pouring hot water from the kettle and the agent, the water is still standing. What to check Dear colleagues? Greetings.
  • #2 16960797
    maciejesiu
    Help: 5
    Rate: 30
    Check the end of the drain hose if it is clogged, and with the mole it hurts you ... Pour the water out of the washing compartment by hand, put the dishwasher back, unscrew the casing that is placed on the bottom of the dishwasher, unscrew the pump and check if there is any foreign body in it e.g. glass, lemon stone etc ....
  • #3 16963244
    ekipa
    Rate: 21
    The drain hose is unobstructed, the drain pump has been removed and tested today (it spins easily). The water is still standing and the cap for the dishwashing cap (there is also a sensor) does not open. Is there a chance that the control board is damaged? Programs can be selected without a problem ...
  • #4 16964274
    maciejesiu
    Help: 5
    Rate: 30
    And the wires coming out of the pump to the module checked? He may be broken
  • #5 16965852
    ekipa
    Rate: 21
    The wires are ok. The same plugs and contacts without patches, etc. I am worried that during the program the capsule does not fall out either ... All the wires from the elements are not meeting the controller. There are 2 capacitors on the PCB, but they look like new. I have run out of rational ideas.
  • #6 16967449
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    Rational thinking does not consist in representing given views, but on proper reasoning and justification, which is not visible here. Therefore, it may be time for the character of the forum to perform and carry out all measurements on the PCB and visualization in real world of your electronics. The purpose of bringing your activities (measurements, results, etc.) closer to your work :D
  • #7 17773130
    Moris10
    Help: 9
    Rate: 28
    I solved a similar topic, so I will write a few words. The symptom was that the dishwasher did not pump out the water. Both during program activation and during reset. The pump was ok, connected to 230V. The first diagnosis is the triac on the disc. However, its replacement does not fix the problem. The pump operates after activating the anti-flood valve. A frayed cable between the controller on the door and the control board at the bottom of the dishwasher turned out to be a defect.
The discussion revolves around a Beko DIS1520 dishwasher experiencing a water pump issue where water remains stagnant despite attempts to clear it using hot water and detergent. Initial troubleshooting included checking the drain hose for clogs and inspecting the pump for foreign objects, which yielded no results. The user confirmed that the drain pump spins freely and the drain hose is unobstructed. Concerns were raised about the control board potentially being damaged, as the detergent cap does not open during operation. Further suggestions included checking the wiring from the pump to the control module, which was found to be intact. A similar case was referenced where a frayed cable between the door controller and the main control board was identified as the defect, leading to the pump not functioning correctly. The discussion emphasizes the need for thorough electrical measurements and diagnostics on the PCB to identify the root cause of the malfunction.
