[Solved] Beko DIS5831 Dishwasher: Won't Start, Water Filling, Program Running, Propellers Not Working
maczo82 4806 5
  • #1 16959925
    maczo82
    Rate: 18
    I know there were many topics on this subject, but I couldn't find anything specific about my dishwasher. The problem is that when it is started, it takes water, the program runs, i.e. the time is measured and the propellers do not start. I read that it may be the pump's fault, but how to get to it and what to do, I will add that I cleaned the filters. Please help.
  • #2 16960307
    maciejesiu
    Help: 5
    Rate: 30
    Most likely it is a pump, but you have nothing to disassemble this dishwasher, call the service if you do not know how to go about it. The pump is a magnetic pump and it is very emergency in terms of bearing, there are no bearings, only bushings, which wear very quickly.
  • #3 16960710
    maczo82
    Rate: 18
    I thought so, thank you for your help and you don't know how much such a pump costs?
  • #4 16960746
    maciejesiu
    Help: 5
    Rate: 30
    About 360 PLN in the north store.
  • #5 17012520
    maczo82
    Rate: 18
    The pump failed, the exchange did the trick
  • #6 17012524
    maczo82
    Rate: 18
    Pump replacement
