Beko DFN6837 S Dishwasher - The program does not start, the valve cannot be hear
oloelektro 15861 4
  • #1 16531452
    oloelektro
    Rate: 54
    The program does not start, you cannot hear the pump, nothing is displayed, only the program to be started and nothing ..
    I am looking for modes I turned on the RESET button and then ON / OFF it displays RESET.
    if I turn on the Hourglass Button and then ON / OFF then you turn on some .. I: Ft
    Entering service mode for self-test and error display
    #2 16531634
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3362
    Service mode:
    Turn off the machine, press the two upper buttons and under it on the left side of the display, i.e. "program" and "half load", hold down the keys, turn on the machine, wait about 4 seconds, the inscription Sft will appear, press start / stop and the machine will run in self-test mode . On the display P1 P2 etc. After the third and probably the seventh step, press start / stop to move the machine to the next one. During this test, lasting up to 10 minutes, the machine will check the components and display errors.
    Good luck!
  • #3 16531805
    oloelektro
    Rate: 54
    I did as you wrote the machine went through 8 programs, but does not display errors, ends with 8 and blinks sft and -> |
  • #4 16532069
    peter falk
    Help: 1158
    Rate: 3362
    So maybe do a memory reset?
    Turn off the machine, press start / stop, hold down, turn on the machine, wait 4 seconds, all icons should light up, turn off the machine.
    I have no more ideas :(
  • #5 16532637
    oloelektro
    Rate: 54
    I checked the water drain pump and it works ... I will check the main water valve. They are on 230V?
    Added after 35 [minutes]:
    The valve is also ok. And the dishwasher still silence ... Is the control module?
