LG G3 Display Fades Out with Touch Functioning: Possible Causes & Solutions after Falling on Stove
kasarama 5610 3
  • #1 16200974
    kasarama
    The phone fell on the stove and the original display was listed on the website. The first two displays were of low quality - there were white spots, the third would probably have the same problem, but at the time of connecting the phone to the car charger, the screen went out, and more precisely it gradually faded in the form of crossbars. From that moment on, the display dimmed after minutes or seconds of use, sometimes leaving the image of the last screen dimmed. At that time, the touch was working. The website has probably ordered a (fourth) display of better quality. After receiving the phone from the site, the problem occurred again. I suppose the screens are not damaged, since all of them react so. What can the problem lie in? If the charger is wrong, can you replace any parts? (I have the impression that the screen has the greatest difficulty with loading when loading)
  • #2 16201012
    hacker_ice
    Help: 36
    Rate: 101
    Since the service fixes your phone and there is still a problem with it, I advise you to report to the site that was burying it. It looks like there is a problem with the motherboard. I understand that the service gives him a guarantee if they exchange something in it, since the problem is with the screen and fix the screen, I advise you not to do anything but give it to them and let it be their worries, not yours. You pay them for it and if they did something that it is worse then they should fix it.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #3 16201028
    raptowny13
    Help: 22
    Rate: 50
    The wine is most likely in a cheap Chinese display. There remains a replacement for the Original. Return to the website as a colleague wrote above.
    ASPOL
    Świątniki 61, Pabianice, 95-200
  • #4 16489581
    kasarama
    The service ordered an "original" display and this one did not work either. Phone for losses. greetings
