UPC Installations: Required 10mm Diameter Coaxial Cable vs. 6.9mm Alternative (RG6, 75 Ohm)
fiodor20 18459 6
  • #1 16202369
    fiodor20
    My problem is that the UPC technique insists that the cable for their installations must have a diameter of about 10mm. This is too much for me, because I will have a problem with placing it in the skirting board. I received data on the email that it must be: "antenna cable (coaxial) - RG6 designation, cross section above 10 mm, resistance 75 Ohm.".
    I found a cable with such a specification, which has a diameter of 6.9mm - which would already be ok for me.
    The question is whether the UPC technician is right and the cable must be 10mm in diameter and it can not have, for example, 6.9mm?
  • #2 16202453
    scotch
    Help: 78
    Rate: 148
    A colleague can buy such a cable and installers to install. The only question is what in the event of a failure? The company will find "damage due to the fault of the subscriber due to materials used by the customer and installed at his request" and then the colleague will be worried about what to do with it. Maybe I will anticipate questions such as: this is not possible, as the company cares about the client, etc. It may be brutal but true and used by many companies - my materials, my assembly, my warranty. For the materials provided by the client, the company will not take responsibility. I am confident that in the event of a disruption in reception will say, "Mr. on our side everything is fine for the apartment well "
  • #3 16202469
    fiodor20
    The fact, unfortunately, that may be the reason for not accepting the complaint. Therefore, I would like to make sure that this cable has the same parameters or if someone has already used a similar method ;)
  • #4 16202533
    scotch
    Help: 78
    Rate: 148
    Electrical parameters certainly do, but in such situations it is also about mechanical strength. The rest, as I wrote above and the willingness of installers and the company that provides the signal.
  • #5 16278779
  • #6 16278789
    VooVoo
    Help: 215
    Rate: 266
    Maybe such something: tc6 / ccs / trishield / 80
  • #7 16288565
    Darek.S
    Help: 216
    Rate: 975
    I have not met with an RG6 cable with a diameter of over 10mm. Yes, the diameter (and even greater) has RG11 cables, but such is used in long buses and in the apartment I think it is an exaggeration. Therefore, Triset, I dare say, that the cheaper RG6-Cu from Dipol would also be OK
✨ The discussion revolves around the UPC's requirement for a coaxial cable with a diameter of approximately 10mm for installations, which poses a challenge for the user due to space constraints. The user found a 6.9mm RG6 coaxial cable that meets the electrical specifications of 75 Ohm but is concerned about potential warranty issues if the cable does not meet UPC's diameter requirement. Responses highlight the importance of mechanical strength and compliance with UPC's standards, suggesting that using a cable with a smaller diameter may lead to complications in case of service disruptions. Recommendations include using higher-quality cables like Triset to ensure reliability and avoid warranty disputes.
