UPC Optical Fiber vs Orange: Damaged Coaxial Cable in New Apartment - Installation Issues
MrBeo 11868 14
Why would UPC refuse to install internet in an apartment when the coax cable is already present and seems intact, and what is likely causing the modem registration problem?
The short cable sticking out of the wall was probably not the real problem; the more likely causes were a damaged connector/cable, an old apartment termination that no longer met current requirements, or a signal/provisioning issue in the building [#18877159][#18878399] One reply noted that older UPC installations were often done under different standards, while current setups depend on proper shielding and compression connectors, so the installer may have refused to take responsibility for a borderline installation [#18878399] Another point was that a damaged connector can still look fine externally, and a fitter may only see the modem’s status/parameters, not necessarily use a separate meter [#18877159] In the end, a second installer connected everything without cutting into the wall, and it turned out the whole building had parameter problems that another team had to fix [#18880461] The final diagnosis was therefore not a bad apartment cable, but a building-wide issue with the UPC signal/parameters [#18880461]
  • #1 18876176
    MrBeo
    recently rented a new apartment. Immediately after moving, I wanted to embrace the Internet. I checked what internet providers are available to me. It turned out that I can get optical fiber from Orange or UPC. UPC already had wiring in the apartment itself, in addition, I saw that the previous tenant had a UPC modem at home. As for Orange, the nearest box is on the mezzanine, so bringing it to the apartment would be much more problematic. It would require the approvals of the Cooperative etc. The choice was therefore obvious and fell on the UPC. So I ordered a fiber-optic internet service from them - I know that it is not strictly optical fiber - in addition, the package included a basic TV package, it was impossible to omit it, although I do not care about it.
    After a few days, the fitter showed up and started the installation. Initially, everything went smoothly for him, but after a while he said that he had a problem with registering the modem, that the parameters shown on the phone were incorrect. He informed me that the Internet could work on the parameters that showed him, but it was physically impossible to register the modem, so he had to withdraw from the installation. He told me he thought it was the damaged coax cable coming out of the wall to blame.
    As far as I understood it, the copper wire coming out of the cable is far too short and therefore cannot properly connect the modem. In addition, he cannot cut the cable and earn it again, because the cable itself coming out of the wall is, in his opinion, too short (I can't measure it now, but I think that 3-5cm of cable comes out of the wall).
    The fitter informed me that the least invasive option I have would be to chuck a piece of wall around the cable, pull it out, and earn it again. However, it doesn't give me a 100% chance it will work. Another, more reliable option would be to replace the entire cable in the apartment. However, the owner of the apartment will never agree to this, and it does not suit me either, it would be easier to arrange Internet Orange.
    But in general the whole situation seems very strange to me. The previous tenant had UPC internet, and did not mention any problems related to it. And now it suddenly doesn't work and a damaged cable is to blame?
    What do you think about it? After returning to the apartment, I will throw in pictures of the cable itself coming out of the wall.
  • #2 18876198
    badboy84
    Help: 1197
    Rate: 1485
    I do not believe ... is it really the installation of 2 connectors on the cable and the use of the so-called barrel, i.e. a connector, surpassed this fitter? In that case, I would contact UPC itself and ask why the service was not performed.
  • #3 18876218
    MrBeo
    UPC itself also seems to be acting rather slowly. Installation was Friday. The fitter informed me that the sales representative would definitely be in touch on Monday. As no one answered until 1pm, I tried to contact UPC myself. Through the hotline, I was able to connect with the technical department, there I received information that they are already sending an e-mail to my sales representative with a request to contact me. I was expecting a call on the same day. Of course, no contact so far.
    I know that maybe I am looking for a terribly impatient client, since I am irritated by the lack of immediate contact. But it seemed to me that today's level of customer service, especially in such corporations, should be slightly higher.
  • #4 18876276
    internick
    Level 36  
    Help: 273
    Rate: 555
    And this wire is not "freshly" cut? Maybe the previous tenant "cleaned up" to take, for example, 4m of cable.
    It's such a technology that cable attenuation matters.
    There are technicians here, because they repeatedly ask for indications from UPC modem-routers and refer to the situation.
    Weak cable, high attenuation and such 250 Mb / s will not fly anymore. The predecessor may have had some old offer, e.g. up to 30 Mb / s and Mu worked.
  • #5 18876283
    MrBeo
    I don't think the previous tenant could actually clean that up. But it is an option.
    He lived there for a year, I'm not sure if UPC could have had such weak internet on offer at that time.
  • #6 18876301
    internick
    Level 36  
    Help: 273
    Rate: 555
    Someone mentioned that at 3 cm there is no problem with inserting the plug. Yes, it is probably possible: https://www.dipol.com.pl/zlacze_f_nakrecane_stalowe_5_5_mm_100szt__E8020.htm
    But if they use this type of compression: https://www.dipol.com.pl/zlacze_komprescyjne_f_113_master_na_pkuje_triset-113_E80342.htm, it's already a problem, because you won't go to Praga.
    Going further, however, the fitter probably put something on since he connected the modem. I can't imagine that he put a bare cable into the modem socket and "measured" the parameters.
    On the other hand, I don't install it, but don't UPC fitters have meters? Only the parameters are previewed in the modem?
    Or is it just a conflict at the address? There is another modem in the system in the "hanging" style and it is not possible to add another one.
    Don't be discouraged just try to explain it.
  • #7 18876534
    MrBeo
    UPC Optical Fiber vs Orange: Damaged Coaxial Cable in New Apartment - Installation Issues UPC Optical Fiber vs Orange: Damaged Coaxial Cable in New Apartment - Installation Issues UPC Optical Fiber vs Orange: Damaged Coaxial Cable in New Apartment - Installation Issues UPC Optical Fiber vs Orange: Damaged Coaxial Cable in New Apartment - Installation Issues
    Exactly 6 cm of cable comes out of the wall itself, including the connector. The core itself coming out of the cable is actually quite short, when I looked at it on the net, it is usually much longer. There is also a splitter in the photo, which was used by the fitter, the splitter was connected to the cable from the wall, while the cable itself was connected to the modem.
    However, he checked the parameters on a smartphone, I have not seen him use any other devices.
  • #8 18876567
    internick
    Level 36  
    Help: 273
    Rate: 555
    The main vein is usually cut flush with the collar and it works. It sticks out for you, so that's not the problem. The plug is definitely intact. You can see the paint or putty streak. If he cut the plug, he would rather not put on another one. He probably logs in via WiFi to the modem-router and views the parameters.
  • #9 18877159
  • #10 18877172
    MrBeo
    I see. In that case, in fact, there is probably nothing else to do but wait what the next UPC service technicians will tell me. The owner agreed to cut up a fragment of this wall around the cable. So let them try.
    There is the problem with Orange, which I wrote about at the beginning, a box on the mezzanine, no cables in the apartment. So it would have to be pulled into the apartment. I know that this is not a major problem and the service will deal with it quickly. The problem will be rather the issue of the consent of the cooperative to perform work in the stairwell.
  • #11 18877187
  • #12 18878399
    KOCUREK1970
    Help: 3844
    Rate: 5456
    @MrBeo
    This terminal looks as if it was installed several years ago, and then there were different speeds and other requirements for the installation itself in the customer's premises (tightness and ingress). It is not surprising that the installer resists, because he is responsible for the installation of the service with his head (and finances) and no one wants to be under the influence.
    The apartment could be renovated, the cable may have been damaged during the renovation, there may also be a problem with the input of the cable itself and the signal to the apartment.
    With plastered cables, God knows what is there, what class the cable is (requires triple shielding), the plugs should be compression.
    And something must have been a problem before, because why would the fitter install a splitter only for the modem, if he left the second output loaded with a resistor.
    Since there is only an internet service, no splitter is used.
  • #13 18878424
    MrBeo
    I see. Tomorrow the fitter comes again to try to connect. They have permission to tear apart a fragment of the wall, so if it proves to be enough, it will all end well. If not, he will resign from UPC. I don't want to play with puttying the whole apartment after replacing the cable.
  • #14 18878516
    KOCUREK1970
    Help: 3844
    Rate: 5456
    The new op, Orange will put its wires anyway, in plain sight, and will drill into the wall to guide the fiber through.
  • #15 18880461
    MrBeo
    Another fitter came today, he did it the first time. With the cables everything was ok, there was no need to cut anything or punch or anything like that.
    As for the problem with the parameters, it turns out that the whole building has them, another team will come to take care of it.
    So far, the internet does not reach even half of the purchased 500mb / s, but the fitter said that the modem is updating, in addition, my network card in the laptop has a good 8 years, so I will have to buy an external one or replace the current one.
    Anyway, everything works. Thank you all for your support. greetings
✨ The discussion revolves around installation issues faced by a user who opted for UPC's internet service in a new apartment, where existing coaxial cables were damaged. The user initially chose UPC due to pre-existing wiring but encountered problems during installation, including modem registration failures. Responses highlighted potential issues with cable attenuation, connector integrity, and the previous tenant's modifications. The user expressed frustration with UPC's customer service delays. Eventually, a second technician successfully completed the installation without needing to cut or modify the wall, although the internet speed was still below expectations. The user was advised to consider upgrading their network card for better performance.
TL;DR: UPC install failures often come from signal attenuation; even 250 Mb/s service struggles—"such 250 Mb/s will not fly anymore." This renter-focused FAQ covers quick coax fixes, activation checks, and when to escalate to building service. [Elektroda, internick, post #18876276]
Why it matters: It helps renters diagnose no‑sync installs fast without needless wall work, and decide between keeping UPC or switching to Orange fiber.
Why did the UPC installer say my modem couldn’t register?
Modems fail activation when upstream or downstream levels are out of spec at the building. A second visit revealed a building‑wide parameter issue. A network crew needed to handle plant adjustments before full performance. Ask support to open a building‑level ticket. [Elektroda, MrBeo, post #18880461]
Can a 3–6 cm coax stub still take an F‑connector?
Yes. Screw‑on F‑plugs can fit short stubs, even near 3 cm. Compression connectors often require more slack for proper seating and tooling. If slack is tight, extend with a barrel coupler rather than chasing the wall. [Elektroda, internick, post #18876301]
How do I extend a too‑short coax without opening the wall?
Use a barrel coupler and two F‑connectors.
  1. Fit an F‑connector to the wall stub and another to a short jumper.
  2. Join both with an F‑F barrel coupler.
  3. Connect the jumper to the modem or splitter and test sync. [Elektroda, badboy84, post #18876198]
Do I need a splitter if I only ordered internet?
No. “Since there is only an internet service, no splitter is used.” If a splitter remains with a terminator on the spare port, it likely masked a signal or sealing issue. Ask for a direct feed to the modem. [Elektroda, KOCUREK1970, post #18878399]
The previous tenant had UPC. Why am I having trouble now?
Older terminations may not meet current tightness and ingress requirements. Renovation might have damaged the hidden cable. Technicians expect triple‑shield coax and compression plugs today. Low‑speed legacy plans tolerated more loss than current higher tiers. [Elektroda, KOCUREK1970, post #18878399]
How are signal “parameters” checked—do techs really use a phone?
Yes. Installers often join the modem’s Wi‑Fi and view signal pages on a smartphone. That confirms levels and registration without separate meters. If levels look poor, they escalate rather than guess at connectors. [Elektroda, internick, post #18876567]
How long should the center conductor be at the F‑connector?
Trim it flush with the connector collar. “The main vein is usually cut flush with the collar and it works.” If the pin protrudes, length is not the culprit. Focus on signal quality and termination type instead. [Elektroda, internick, post #18876567]
Could an address or “ghost modem” conflict block activation?
Yes. An unclosed device tied to your address can prevent adding a new modem. One scenario cited a “hanging” modem that blocks registration. Ask support to remove previous equipment from the account and node. [Elektroda, internick, post #18876301]
Can a building‑wide issue block my clean apartment wiring?
Yes. A second installer restored local connectivity but flagged building parameters for a network crew. Local fixes help, but plant issues cap throughput until resolved. Request a building ticket if neighbors see similar problems. [Elektroda, MrBeo, post #18880461]
Why is my 500 Mb/s plan testing under half on day one?
Initial modem firmware updates can limit speed temporarily. An older laptop NIC can bottleneck throughput. One case noted an eight‑year‑old adapter and sub‑250 Mb/s on a 500 Mb/s plan. Re‑test using a newer NIC or USB 3.0 adapter. [Elektroda, MrBeo, post #18880461]
What cable and connector spec should I request from UPC?
Ask for triple‑shield coax and compression F‑connectors to control ingress. These meet today’s higher speed and sealing expectations. Better terminations reduce future activation issues and noise. [Elektroda, KOCUREK1970, post #18878399]
What’s the best way to escalate after a failed install?
The field visit becomes a service failure. “The installer treated this situation as a failure… and passed the problem on to the service.” Request a service team appointment, not only sales follow‑up. [Elektroda, Anonymous, post #18877159]
Can the connector be swapped without breaking the wall?
Often yes. Skilled techs can re‑terminate or re‑dress the stub cleanly. “You may be surprised how it can be elegantly done.” Approve wall access only if more slack is truly required. [Elektroda, Anonymous, post #18877187]
If I switch to Orange fiber, what should I expect at install?
Expect visible, surface‑mounted fiber inside and drilling for wall pass‑throughs. Orange will route its cable in plain sight unless you preplan concealed paths. Confirm co‑op permission for stairwell work first. [Elektroda, KOCUREK1970, post #18878516]
