Question about a gas boiler - New house 116 meters, it is not known which boiler
KVIAT69 10197 18
What condensing gas boiler power and setup should I choose for a 116 m² house with underfloor heating, radiators, and domestic hot water from a drilled well?
For this house, the thread leans toward a lower-power condensing boiler, ideally a single-function unit with a separate hot-water tank of about 150–200 L, rather than an oversized 24–32 kW model [#16240937][#16241177][#16243923] One concrete recommendation is Termet Ecocondens, with cheap parts and easy service, because the price difference to premium brands is not expected to pay back in this class [#16240937] Another suggestion is Termet Victrix 24 TT 2 ErP with a tank, but the discussion notes that for such a small installation around 12 kW is enough and lower minimum power is beneficial for modulation and hot-water comfort [#16241177][#16243923][#16246816] Service availability matters more than the logo: choose a boiler with local factory/warranty support and access to parts, and De Dietrich MCR 3 24T+ or MCA 15 with iSystem was recommended if that service is available in your area [#16245881] Several replies also advise dividing the installation into zones with separate thermostats and valves for upstairs, downstairs, floor heating, and bathrooms, because underfloor heating and radiator circuits react very differently [#16240937]
  • #1 16240184
    KVIAT69
    At the beginning I would like to say hello to you and greet forum members. I am completely new here, sometimes I visited as a guest.
    I have a problem and confusion with the choice of oven:
    Factual status: house 116 meters from aerated concrete + 15cm graphite foam.
    Heating: gas + DGP fireplace with turbine and ventilation to the living room (with the kitchen open together 36.5 meters, the living room alone 23m) and the room downstairs (9.2m) - a total of 45.7 meters; and up to 3 rooms upstairs 36m. Downstairs there will be a floor, upstairs in the bathroom, hallway and wardrobe, floor, in three rooms, plate heaters.
    I will rarely smoke in the fireplace, I don't have time for it a week. I leave home 6.30 and come back 18.00, but weekends off.
    I have water from a drilled well, so you need to heat.
    What to choose Viesmann? Brötje? With tray, without? Single or dual function?
    I can spend for five to 8,000. zł. Energy efficiency, reliability and service are important.
    I am asking for any advice and thank you in advance.
  • #2 16240768
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    My friend, I recommend Dietrich with a tray and a dedicated controller.
    Knocks down on price and quality.
    I've been around the house for 3 years and it works great.
  • #3 16240839
    KVIAT69
    Thanks for the answer. What is your model and how is your performance?
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    Termet ecocondens + separate tank 150-200L CWU. 3600+ 1600+ any regulator (s) 150max. = 5350.
    The difference of PLN 2650 will not "make up" for any super boiler, because they are all comparable in their class. Cheap parts for it, available service. In 10-12 years you will still exchange for the next one so there is nothing to get excited about with brands.
    Instead of an expensive boiler, I would divide into zones with separate thermoregulators and valves: up, down, floor, bathroom (s) and here there will be savings due to the completely different reactions of underfloor heating and attic heaters especially.
    szach11
    Rate: 16
    Andrzej Lukaszewicz advises you well. In addition, the termet is also worth attention VICTRIX 24 TT 2 ErP + plus tank 160
    irus.m
    Heating systems specialist
    Help: 122
    Rate: 453
    For such a small Victrix surface, 12 kW = tank
  • #7 16245799
    szach11
    Rate: 16
    Lower power may also be his plus will be that it goes a little lower with modulation but it will heat the water in the tank twice as long so something for something. Comfort of hot water or slightly lower modulation.
    dobroslaw
    Help: 57
    Rate: 157
    The most important service is factory or warranty with access to parts, authorization alone is not enough, the company is secondary.
    If you have a service in the area, I recommend De Dietrich mcr 3 24t + and sense, if you want better control with the floor, but more expensive is mca 15 and isystem, storage, e.g. biawar, God's weapon, De Dietrich.
    Term Klima serwis De Dietrich Białystok
    białystok słowackiego 7, Białystok, 15-229 | Tel.: 500XXXXXX (Show)
    irus.m
    Help: 122
    Rate: 453
    Nonsense.
    you use the water in large quantities sporadically, and the boiler starts when the temperature of the water in the tank begins to fall. It does not wait when the hot water runs out in the tank.
    According to statistics, the boiler works on central heating about 2100 hours per year. And it is not indifferent to the correct operation (and finance) of small installations, whether the boiler has a P min - 1.8 kW, or, for example, 3 kW. Count the percentage difference.
    best regards
    pawelpiwowarczyk
    I put in my 3 cents. House 180m2 (120m2 heated, the rest unheated attic). Wall insulation 25cm graphite polystyrene, roof 35cm wool but, for example, metal "construction" doors, insulated and leaky, unfinished attic insulation in several places, etc.
    We don't live yet, we have been holding the house at 16-20 degrees since autumn (finishing works). Victrix 12KW boiler (+ 160l storage tank) so far without any automation installed (control is carried out via a knob on the pipe).
    The dial is set to "2.5" (scale from 1 to 9). The boiler works constantly. The outflowing water is 40 ° C. Radiators barely warm. At home today 17 ° C (outside -5 and wind). When the temperature was +5, I reduced the power to "2" because the house was too warm.
    This illustrates how monstrously oversized gas boilers are installed today. Their powers are the same as 10 years ago and the energy efficiency of homes has increased dramatically. It is not worth installing monsters after 24 or 32KW.
    The added value at low boiler output is the lack of the need to build a chimney for it (in our case it mattered).
    What's more (I go beyond the thread but I think it's interesting), because I wanted to turn off the floor in the kitchen, I turned off the central heating pump supplying the floor divider. Kitchen floor ... still warm. Only turning the valves on the kitchen circuit helped. Now I think that I was getting myself by putting on a separate pump driving the floor divider. A pump in the boiler would calmly drain the entire installation. And it seemed to me that comparing to installations that are promoted on forums and in the professional press, I have a simple one :-)
  • #11 16266551
    KVIAT69
    I received such an offer, please give me an opinion.
    There is such an option boiler Brotje WGB M Evo 20 kw (NOT LARGE?) - after discounts PLN 8,900
    Heater charging kit evb evo
    Rgb programmer
    Hot water heater 120l
    Diaphragm vessel co
    Diaphragm expansion vessel
    Materials and labor per m2 of underfloor heating: Tweetop-PERT-AL 16 '' pipe, edge tape, clips, 3 cm mat for floor
    5i-circuit underfloor heating manifold with valvex flow meters
    3-circuit floor heating manifold with valvex flow meters
    I am asking for opinions
    Cosmo 22kv60 / 140 radiator
    Cosmo 22kv60 / 72 radiator
    Cosmo 22kv 60/100 radiator
    Cosmo 22kv 60/80 radiator
    Thermostatic heads
    Radiator connection set
    LC switch 2
  • #12 16282652
    rogera
    Help: 6
    Rate: 61
    I propose a GB072 boiler with a capacity of 14kW from Buderus.
  • #13 16583825
    użytkownik593
    Hello everyone, I have a flat of 60m2 + hot water 80l, flat in an old, insulated tenement house for 1p, plastic windows, brugmam panel radiators, copper pipes, height 3m, what gas boiler needs? I now have a regular coal boiler but is fed up with this dust and stench in the apartment, what boiler do you recommend, what power?
  • #14 17130882
    KamilWysoki
    Like Andrzej and Szach11, I recommend Termet boilers. I have Termet Ecocondens Gold Plus and it works as it should. Polish brand, so there is no problem with the service. Although, fortunately, I didn't need their help yet. I have a single function condensing boiler.
  • #15 17130957
    BUCKS
    Help: 536
    Rate: 1086
    użytkownik593 wrote:
    I have a flat about 60m2 + hot water 80l, a flat in an old, insulated tenement house for 1p, plastic windows, brugmam panel radiators, copper pipes, height 3m
    In this case, I would realistically estimate approx. 80w / m2, which gives a constant power of 4.8kW to maintain 20 degrees in the room in the cold of -20 degrees. In other words, at 0 degrees it will be half of it, i.e. constant 2.4kW.
    If you want the boiler not clocked at around 0 outside, the minimum boiler output should be around 2kW, i.e. basically a 1-function boiler + hot water tank
    With 2-function boilers, the lowest power that can be obtained is usually a level of 3-3.5kW, so it will make a difference for you.
    Here the question remains to what temperature the water was heated at the coal boiler.
    Condensing gas boilers, and now only those worth buying like a low temperature of heating water. They have the greatest efficiency when the return will be 30 degrees.
    With coal-fired boilers, there is a tendency to maintain higher temperatures, and this may mean the need to maintain a higher temperature on the gas boiler so that the heaters give sufficient heat.
    If we would like to lower the heating water temperatures, this involves replacing the radiators with larger ones.
    In other words, replacing the boiler is one thing, but in extreme situations it may be useful to modernize the radiators, but this must be determined individually.
    The undeniable advantage of gas is cleanliness and lack of service, because we set the temperature on the regulator and the rest happens somewhat automatically ;)
    At a friend's, in recent frosts, 2 bags a day went, or 50kg, and someone has to pour it in, because it won't do itself, and then cleaning the boiler from ashes, etc. so if in a house with a separate boiler room you can turn a blind eye to it in the apartment playing with coal is a past for me and I hope that they will not come back again.
  • #16 17131181
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Condensation occurs up to a temperature of 50 degrees on the return, and this means that the supply can reach up to 70. Such conditions, when water is given to radiators with a temperature of 70 degrees, usually occur several nights a year (and it happens that in a given heating season this does not occur), and in average then usually there is 40-45 degrees on the power supply and on return to 30-35). So do not overdo it with the size of the radiators, because then it may be that the summer radiator will cause a sauna in the apartment. One more thing. it is better to choose a radiator as low and long as possible, than high and short, because warm air is lighter than cold and always goes up, so the heat source should be as low as possible (especially since each radiator is warmer hot than down), especially since it freezes first of all from the feet (and at the same time sweat may flow from the back).
  • #17 17131294
    BUCKS
    Help: 536
    Rate: 1086
    You wrote it in a different thread and I wrote you back but you do not draw conclusions, so I will repeat.
    What do you think the condensation will be at 50, and what at 30 degrees on the return. For this simple reason, boiler manufacturers give the highest efficiency for a return of 30, not 50 degrees.
    and on average then there is usually 40-45 degrees on the power supply and on return to 30-35)
    If someone uses a coal-fired boiler in the apartment, I rather doubt that he would maintain such parameters.
    If on coal it needed to maintain high temperatures then after replacing the boiler will also have to maintain them at a high level, i.e. it will use the advantages of condensate to a lesser extent.
    Apart from condensation, I personally prefer lower heating water temperatures, because then I feel better comfort than when the heating water is hot and the radiator also becomes hot.
    So do not overdo the size of the radiators
    I am not exaggerating, I just pay attention to this detail and signal that it requires an individual assessment for a particular case.
    it is better to choose a radiator as low as possible and long
    I have one heater, 90 cm high, because I could only go to height, not length, and the others are 60 cm high, and I do not confirm the problems you are writing about.
    I do not freeze from below, nor do I pour sweat on my back. Maybe because I am not sitting by the radiator, the heaters are not hot and I do not make a sauna to walk in a short sleeve. For me it is quite optimal and normal. However, if someone wants to walk barefoot, they should mount a floor if it is possible.
  • #18 18394391
    francora
    I recommend De Dietrich 24KW dual-function with a closed combustion chamber = radiators + flooring, kitchen and bathroom via RTLa, a total of 100m2 - a reliable 13 years of continuous operation and connected in an up-down emergency system if it fell.
  • #19 18394730
    BUCKS
    Help: 536
    Rate: 1086
    sounds more like advertising than reliable advice.
    Currently, boilers with a closed combustion chamber and with an open one are a thing of the past, and only condensing boilers remain, which also have a closed combustion chamber, but as to durability, it is generally estimated that as such a new boiler will last 10 years it will be good, maybe some will survive several years but there is no such guarantee.
    In addition, now the boilers have electronic pumps, which have the reputation of not very durable devices, so your 13 years of reliable operation has nothing to do with current boilers and the current situation.
    It is worth remembering that the boiler should be selected according to the estimated energy demand, so what matters is its minimum power, which you have not boasted about what your boiler has.
    My boiler with an open combustion chamber is 14 years old, which does not mean that it is the best choice, because with a minimum power according to technical data at the level of 9.1kW (80/60) it is a poor choice for modern, energy-saving buildings with a living area of 100m2 and in terms of thermal comfort it doesn't work well in my 100 m2 non-insulated.
✨ The discussion revolves around selecting a suitable gas boiler for a new house measuring 116 square meters, constructed from aerated concrete and insulated with graphite foam. The user seeks advice on brands and models, emphasizing the importance of energy efficiency, reliability, and service. Recommendations include various models such as Dietrich, Termet Ecocondens, and Brotje WGB M Evo, with suggestions for single or dual-function boilers and the inclusion of storage tanks. Participants highlight the significance of proper sizing to avoid oversized installations, the benefits of zoning with separate thermostats, and the need for reliable service access. The conversation also touches on the importance of heating water efficiently, especially given the user's specific heating needs and lifestyle.
