Best Motherboard for Intel Core i5 7600k, GTX 1050Ti, ATX Be Quiet 730W, GoodRAM 2x4 DDR3 1333MHz
piter1925 5484 9
Which LGA1151 motherboard can I use with an Intel Core i5-7600K while keeping my existing GoodRAM 2x4 GB DDR3 1333 MHz memory?
If you want to keep DDR3 RAM with an i5-7600K, you need a 100-series LGA1151 board that explicitly supports DDR3, such as ASUS Z170, Gigabyte GA-Z170M-D3H / GA-Z170-HD3 DDR3, or ASRock Z170K4/D3 [#16271652] These boards may also need a BIOS update or confirmation from the store that they already support the i5-7600K [#16271652] However, several replies warn that 1333 MHz DDR3 is very slow for this platform and that buying a K CPU plus an OC board while keeping old RAM makes little sense [#16272334] [#16275309] The thread also suggests that if you do not plan to overclock, it is better to switch to a non-K CPU and a cheaper B250 board like the MSI B250M PRO-VD, then put the savings into DDR4 RAM [#16275385] For budget, one reply says a 200-300 PLN motherboard should be enough [#16272210]
  • Seeking an LGA1151 motherboard supporting DDR3 memory
    #1 16271477
    piter1925
    Hello. I would like to choose a motherboard for the Intel Core i5 7600k processor. (I don't think LGA 1151 does :D ?) The GTX 1050Ti is probably a graphic purchase and the ATX Be QUIET is included! 730W PURE POWER BQT L7-730W. The disc must match the frame I have because I do not want to change GoodRAM 2x4 DDR3 1333 Mhz in dual channel. It would be nice if it had 4 slots on the frame but it is not a necessary requirement :) greetings
  • #2 16271548
    Kaspri_
    Hello!
    How much money do you plan to spend on this motherboard?
  • #3 16271567
    piter1925
    A few hundred but within reason. Any suggestions with prices? Poles poor onions xD are known
  • DDR3 Z170 boards may require BIOS updates
    #4 16271652
    woodpecker0
    Help: 29
    Rate: 91
    So how much does this limit of reason think to you? For me it could well be PLN 1600 for ASUS MAXIMUS IX FORMULA - you have to specify, poverty, we will not guess how much you managed to collect.
    And above all, what is the intended use for this computer? If only games (loose proposal) can give up this processor in favor of one with a blocked multiplier (well, unless you have already bought or just want to "play" in OC) then you do not have to buy a plate for OC and can buy yourself saved money DDR4 memory do you add to your graphics card or something ...
    edit ...
    If you insisted on a motherboard with socket 1151 but with DDR3 memory support, not DDR4, there is not much choice, on morele.net I found so much (I probably missed one link):
    Spoiler:
    As these are boards on the 100 series chipset, it seems that you would also need to buy a BIOS update service, quoting a fragment of the topic with ready-made computer kits "BIOS update necessary or confirmation from the store that the sent disk will support the i5-7600K processor"
    https://www.morele.net/plyta-glowna-asus-z170...ata3-usb-3-0-microatx-90mb0mr0-m0eay0-858844/
    https://www.morele.net/plyta-glowna-gigabyte-...hdmi-dvi-d-sub-matx-ga-z170m-d3h-ddr3-770681/
    https://www.morele.net/plyta-glowna-gigabyte-...0-satae-sata3-hdmi-dvi-d-sub-atx-ga-z170-hd3- DDR3 Skylake-765617 /
    https://www.morele.net/plyta-glowna-asrock-z1...ing-k4-d3-z170-ddr3-sata3-usb-3-0-atx-771552/
  • #5 16271779
    piter1925
    Your suggestions are accurate. I thought so about the price plus or minus PLN 400. Rather, I would like to play newer games like ac syndicate far cry primal etc. Unless I need one with a locked multiplier + this is a block for locked procks which probably are cheaper things
  • #6 16272146
    Kaspri_
    What parts have you already purchased for a new machine?
    Choosing such a processor as you suggested, it is a processor under OC (Overclocking). If you want to buy it because it has the option of overclocking, and you will not use it, it makes no sense. It just misses the point.
    But we assume that:
    You want to overclock the processor. Then you need to realize that you need to buy the right motherboard for overclocking processors. That's not all you will have to invest in better cooling, because stock won't provide you with the right working temperature. Noi the processor will burn.
    I have had an i5 4690k processor for over 2 years. Its stock clocking is 3.5Ghz. I managed to turn it up to 4.6Ghz. Above this value, the processor was not so stable and its temperature exceeded 80 * C at 100% load. Thanks to this, I increased its power by about 30%, it could be felt with demanding games and programs. Wherever high computing power is needed.
  • #7 16272210
    Rafik_ck
    Help: 19
    Rate: 84
    The album costs PLN 200-300 and that's enough for you.
  • #8 16272334
    rzymo
    Help: 206
    Rate: 322
    piter1925 wrote:
    Hello. I would like to choose a motherboard for the Intel Core i5 7600k processor (...) The board must match the frame I have because I do not want to change GoodRAM 2x4 DDR3 1333 Mhz in dual channel
    Do you realize that you are hurting yourself with such slow memories? (performance of course ;) )
  • #9 16275309
    bolekis
    Help: 200
    Rate: 264
    I am not sure if the standard DDR3 will fit. To this generation probably only DDR3-LV and this is not always the case. Anyway, it makes no sense to buy a new processor with an unlocked multiplier, plus an OC plate and insist on old memories. DDR3 for sale and change to DDR4.
The discussion revolves around selecting a suitable motherboard for the Intel Core i5 7600k processor, considering compatibility with the GTX 1050Ti graphics card and GoodRAM 2x4 DDR3 1333MHz memory. Users express concerns about the limitations of DDR3 memory and the potential need for a motherboard that supports overclocking, given the unlocked nature of the i5 7600k. Suggestions include considering a motherboard with an LGA 1151 socket that supports DDR3, although the consensus leans towards upgrading to DDR4 for better performance. Price considerations range from PLN 400 to PLN 1600, with specific recommendations like the MSI B250M PRO-VD for a more budget-friendly option.
